oem brakes not enough
Discussion in 'Prius c Care, Maintenance and Troubleshooting' started by TRDtaco, Mar 7, 2013.
  1. TRDtaco
    TRDtaco New Member
    since day one i have noticed that my brakes dont have a bite to them.. in other words its not stoping. I find my self using the e-brake and recently i figured out about the "B" gear; started using that instead to break..
    any advice on how to improve breaking.. any braking upgrades??
  2. usnavystgc
    3,159
    990
    Tucson, AZ
    Are you serious? If your car is not stopping, you need to take it in for warranty service? There should be no reason to use the B gear in normal driving nor should there be any need to upgrade the brakes.
    A car that won't stop is dangerous. Do not drive this car if it is as you say.
    RocMills likes this.
  3. TRDtaco
    TRDtaco New Member
    yeah i made an appointment to get it checked out for this weekend..
  4. B2FiNiTY
    B2FiNiTY Active Member
    979
    227
    This is one of the more interesting threads here... please let us know what they say.
  5. MotorcycleGoat
    MotorcycleGoat Junior Member
    51
    23
    Yes, I'll be watching this one also. I about put the sales-lady's face in the dash when I was test driving the thing. At slow speeds, my C4 stops NOW. At higher speeds I have noticed they don't have as much "bite"...almost fade as they heat up at all. But, they still work as I would expect.
    RocMills and ztanos like this.
  6. ETC(SS)
    7,563
    TRD...huh?
    Riiight,
    This is either a warranty problem, or what I call a dead short between the seat and the steering wheel.
    Either way?
    It's reeeeeeal easy to figure out. Take it to a dealer and they'll be able to very quickly determine whether or not there is a problem and if this problem is caused by a defect or abuse.
    I don't have any stick time in the Trial-Sized Prius, but I deeeeeeeeeeply suspect that there is nothing wrong with the OEM brakes as designed.
    Whether or not there was an assembly problem with your particular car is what the trip to the dealer will determine.
    Face it...the car only weighs 2500# and it's riding on 15" rims!! There's prooooobably enough rubber between your butt and the road to bring this car to a stop....even with the rear drums. Besides....this isn't what you would call an over-powered car. Some of the reviewers would suggest that it's not even an adequately powered car....but the numbers suggest that it's got enough grunt under the hood to at least pull interstate duty.
    The "C" after all...stands for CITY.
    In fact.....the brakes seem to be one of the few things that some of the automotive geek reviewers didn't fuss too much about:
    "The regenerative brakes are particularly impressive, having shed most of the sponginess that hampered earlier systems, leaving only a hint of grabbiness [sic] during stop-and-go traffic." -- Automobile Magazine (2012)
    The bottom line is that if you're having to use your e-brake or the "B" mode to slow/stop the car then either you or the car (or both) have no business on public roads until somebody figures out what the problem is....because rest well assured......there is a problem! :eek:
    frodoz737, cwerdna and xs650 like this.
  7. ztanos
    ztanos All-around Geek!
    3,339
    1,150
    40
    Cumming, Georgia
    I did the same thing, only with my wife... she wasn't too happy, until I let her test drive it and she did the same thing. :LOL:
    MotorcycleGoat likes this.
  8. 2015Prius2
    2015Prius2 Member
    150
    67
    Did somebody put sandpaper on your toilet seat?
    mtbiker53 and MotorcycleGoat like this.
  9. Klaatu
    Klaatu Junior Member
    32
    17
    New Jersey
    ETC(ss),
    Relax, I think that you may have one to many cups of coffee this morning. You sound like Rand Paul.
  10. ETC(SS)
    7,563
    ^Coffee and filibusters don't mix well, since you have to stay on the floor of the Senate to keep the floor. Unless you're wearing underwear made by Pampers, it's just not going to work out very well.
    However (comma!) you're right.
    I only meant to be a smarta$$, not a harda$$,
    This is an excellent medium for information but not quite as well suited for having a conversation.
    I offer humble apologies to the OP!
    xs650, RocMills and MotorcycleGoat like this.
  11. SquallLHeart
    SquallLHeart The Techie Guy
    826
    247
    San Jose, CA
    no problem with my brakes here..
    are you a new prius driver? there's regen braking, and then the actual friction brakes..
    shifting to "B" should only be used under certain circumstances.. slowing down normally is not one of them.
  12. Mr Incredible
    Mr Incredible Chance favors the prepared mind.
    955
    506
    Neb
    I think the OP has a brake fetish.
    The C brakes aren't anything like my Z28 brakes, but they work better than my truck brakes. The brakes are doing different duty than normal brakes, so don't have the same feel during use.
    I guess it's what you're used to, but not having "bite" seems to asking a bit much from what the C was designed for. I know they're good enough to keep me from crashing. They seem "bitey" enough for me.
  13. Mr Incredible
    955
    506
    Neb
    Another question might be where the OP drives. On the plains? In the mountains? Do you ask a lot of your brakes no matter what it is you drive?
    If you slam brakes on as a matter of course you bought the wrong car, or you need to rethink your driving habits.
    Just my opinion, of course...
  14. bisco
    52,862
    another question might be, "what happened to the op"?:p
  15. B2FiNiTY
    979
    227
    it's always such a big tease with these kinds of threads :cautious:
  16. JimboPalmer
    12,470
    6,879
    Greenwood MS USA
    You do not have to ever come back to spread Fear, Uncertainly and Doubt. Just posting it may convince some gullible folks that Prius has bad brakes. No amount of truth stops FUD.
  17. dbcassidy
    dbcassidy Toyota Hybrid Nation, 8 Million Strong
    1,581
    290
    Middlesex County, MA
    Yep, OP and that darn "brake fetish" will do it every time! :LOL:
    DBCassidy
  18. Mr Incredible
    955
    506
    Neb
    Time to do a FUD walk.
  19. usnavystgc
    3,159
    990
    Tucson, AZ
    Or a FUD walkdown
  20. ETC(SS)
    7,563
    Neeeeext....
