OEM Cross Bars / Roof Rack
Discussion in 'Prime Accessories and Modifications' started by kepani, Aug 3, 2020.
  1. David9962000
    David9962000 Member
    141
    68
    2020 Prius
    Anymore feedback on, MPG, wind noise and car wash with these?
  2. Tips
    Tips Member
    128
    66
    Grand Forks, B.C. Canada
    2020 Prius Prime
    About 2-3 mph lose with them on the car! Worth removing when not being used, for sure!
    MTN and Prim.e.xample like this.
  3. LightningBolt
    LightningBolt New Member
    27
    Rhode Island
    2020 Prius Prime
    At first I didn't mind the wind noise, but after a while it started to annoy me. It becomes noticable above around 45 mph. At 65 to 70 mph it is a considerable whistling racket.
  4. RJC
    RJC Junior Member
    Mishawaka IN
    I am thinking about buying a set. I noticed there are two types. The 150 lb capacity and some lower profile bars for the same price with a 100 lb capacity. Has anyone tried the 100 lb bars out?
  5. m8547
    m8547 Senior Member
    951
    631
    Colorado
    2018 Prius Prime
    I'm seeing both 100 and 150lbs for the same part number depending on where I look (unless I'm missing something). Check out the links to different sources in this thread. For Sale - Toyota Roof Cross Bars for 4th Gen - New | PriusChat
    I'm looking to sell my brand new, never used crossbars. If you're interested let me know. I'm moving soon, and I don't want to take them with me.
  6. Mikhail Bond
    Mikhail Bond Member
    138
    66
    Socal
    why remove them. They look great and the mileage difference is negligible. plus, if you ever pull into a homedepot and decide, hey I need some lumber today, just keep some straps in the back...
  7. SciRunner
    SciRunner Junior Member
    48
    23
    Charm City, USA
    Just installed the OEM crossbars. The wind noise people speak off sounds like wind buffeting at highway speeds. It doesn’t sound bad at all.
    The drag and “slowness” when accelerating beyond 65 mph is really obvious compared to driving the day before without them on (due to science!).
    It only takes less than 5 minutes to remove the crossbars and ~20 mins to put them on the roof properly. The supplied torque limiter Allen key is something you want to keep in the glove box.
  8. thew
    thew New Member
    Detroit, MI
    2021 Prius
    L Eco
    Bumping an old thread--does anyone know the how long the useable area of the OEM crossbars are from one side of the roof to the other? I'm looking at buying a pair to carry a canoe on the roof of my Prius but want to make sure they're wide enough.
  9. ManitobaDon
    ManitobaDon Junior Member
    Winnipeg, Manitoba, Canada
    Hi All,
    Our slightly used 2020 Prime Upgrade (5075km when purchased) had the OEM racks on it. We drove from Montreal, Quebec to Waterloo, ON on both the secondary highways and the 407/401. Maybe a bit of noise at 125 km on the 407 but nothing to write home about. I did take them off in Waterloo for the trek back to Winnipeg, Manitoba, but I was more concerned with FE, but these are pretty slick so fe drop would've been negligible.
  10. Rolla01
    Rolla01 Junior Member
    Vancity
    2020 Prius Prime
    Finally talked to one dealership and was able to find the part number: 90467-06207
  11. MScelery
    MScelery Junior Member
    83
    25
    Mississippi
    This is probably a seriously dumb question for people here, but I’ve never had crossbars before so hopefully someone can help me out.
    -How would I carry 2x4s on these crossbars without them slipping forward and back?
    -Further, what accessories are available for these things? How do I know what fits?
    But, primary question for my immediate needs is the one about the 2x4s. Have a small project to tackle at home and would like to use my Prius.
  12. xliderider
    xliderider Senior Member
    8,140
    3,280
    Honolulu, HI
    Cargo tie downs, straps, bungee cords, or good old fashioned rope.
    But by your question, I'd be a little sceptical that you would be able to secure the load using the above methods properly, and securely.
    Improperly secured loads can fall off the vehicle causing damage to vehicles following you, injury and death. So take it seriously and get someone who knows what they are doing to help you.
  13. xliderider
    8,140
    3,280
    Honolulu, HI
    Depending on the length of the 2x4 lumber and the quantity, you can fold down the rear and front passenger seats and transport up to 8ft long lumber inside the Prius.
  14. MScelery
    83
    25
    Mississippi
    Lol. I get the response and don’t take offense to it. However, I’ve used tie downs plenty of times (was a Z71 owner prior to Prius). I’ve just never had a situation where I was strapping to the top of a vehicle on bars that only run side to side. It seems like that would leave too much motion when braking and accelerating if it was just simply tightened and secured with ratchet straps. Maybe I’m just overthinking it.
  15. xliderider
    8,140
    3,280
    Honolulu, HI
    The roof racks don't have a very good weight rating, put too much weight on them and you risk denting the thin sheetmetal. And, as you stated, the top heavy loads also can put extra force on the roof rack when subjected to acceleration forces whenever the vehicle changes speed or direction.
    As mentioned earlier, put the load in the car. Then you don't have to worry about overloading the roof or rack. You will need to worry about the load shifting inside the car though.
  16. MScelery
    83
    25
    Mississippi
    Yeah. For this project I would do that. But I just want to learn how to use these bars since I have them. I installed a trailer hitch for my bikes but I’d like to use the bars for cargo and other stuff on trips.
    As for the lumber, I was just curious if it was possible, and if so which tie down pattern would actually secure it. Maybe that would have been the better way to word the question.
    Thanks for the responses.
  17. python777
    python777 Junior Member
    Alexandria, VA
    Hi all, I was wondering if anyone tried to mount these on Prius III 2014. I’m aware that these racks are for 2018 and up, but I found a nice deal locally and I wanted to see if it’s possible to mount them on my car without too much modification.
    thanks!
