OEM Ground Effects Kit + side body moldings
Discussion in 'Gen 3 Prius Main Forum' started by 15SuperPrius, May 18, 2019.
  1. 15SuperPrius
    15SuperPrius Member
    174
    65
    FL
    Hi all,
    Being that most accessories for the gen 3 have been discontinued, and searching has not yielded much, I thought I’d post the question here: does anyone have an OEM ground effects kit and/or the side body moldings in blizzard white for sale? Or does anyone know where I could source them? So far all the places that turn up when I perform a Google search no longer have them.
    Thanks!
  2. kenmce
    kenmce High Voltage Member
    1,552
    525
    NY
    If by "ground effects kit" you mean one of those setups where colored lights shine on the ground under the car. then no, I don't believe Toyota ever made such a thing. If you mean some kind of fancy molding then you can probably find one here, althought I think not OEM.
  3. orenji
    orenji Senior Member
    5,887
    3,488
    Persona edition has a kit. You may have to find one off a wreaked car. Another Kit was and is still available is the 5Axis kit which some Toyota dealers sold installed on cars.
  4. 15SuperPrius
    15SuperPrius Member
    174
    65
    FL
    Thank you; I’ve seen the 5 Axis kit and I don’t like it as much as the OEM kit. Unfortunately, the OEM one is no longer made and I have yet to find any leftover kits. I’ll keep looking to see if I get lucky.
  5. Grit
    Grit Senior Member
    6,577
    4,231
    Wilkes Land
    Thats underglow.
