Oem head gasket or aftermarket which is better?
Discussion in 'Gen 3 Prius Main Forum' started by johnnychimpo, Jan 12, 2021.
  1. Bill Norton
    Bill Norton Senior Member
    2,157
    735
    MONW, Ks.
    But the OEM head gasket is what gave you trouble in the first place.
    When that fateful day comes to my Gen3, it's getting an American Made Fel-Pro replacement head gasket.
  2. Eddie25
    Eddie25 Active Member
    497
    209
    MI
    That's always kinda been my opinion on the matter. There's no way in hell I would use the actual original HG. Supposedly it's been updated, but it sounds like they just covered the whole thing with the black material that goes bad on the original so I still would want something that appears to work well with no 'coating' whatsoever. Also, I've never dealt with a dealership that knows anything about anything so I'd probably get old stock or something.
  3. Mendel Leisk
    41,469
    I’m wondering, if you installed say a Felpro gasket, eight o’clock day one, then ran it for 200k miles, without touching the EGR, would it fair any better?
    maybe it would, but on the other hand, it might be a shooting-the-messenger case?
  4. rjparker
    rjparker Tu Humilde Sirviente
    10,159
    6,316
    Texas Hill Country
    Trying to find just one thing is the problem with the egr and head gasket material theories. Yes they contribute. No because it is more a function of excessive carbon from rings and cylinder cooling design not fixed till gen4. Uneven cylinder cooling also impacted by thermal cycling. Thermal cyling is the straw that broke the camel's back. All resulting in small self sealing warpages. Don't forget the same engine in a Corolla has not been nearly as bad.
    Look up Root cause analysis.
    Bill Norton likes this.
  5. Bill Norton
    2,157
    735
    MONW, Ks.
    That would be a good test!
    Because it's just a theory that keeping the EGR system clean will make the head gasket last like it does in other engines.
    My theory is: Disconnect the EGR so there is never a chance of having uneven flow of EGR gasses at the individual cylinders.
    Haven't gone out to the car and done that yet.(n)
    What's the worst that can happen? I now have a Corolla engine under the hood? I now get X less MPG?
    Both questions take time to show any results,,, so,,,,,:whistle:
    Maybe it's the 'Thermal Cycling' theory and neither will change the life of the head gasket.
    Brabus82 likes this.
  6. taxidriver50005
    taxidriver50005 Active Member
    204
    170
    GB
    Excel
    Well my OEM gasket failed at 350,000 miles so I don't really see that as a quality issue.
    Bill Norton and ASRDogman like this.
  7. Bill Norton
    2,157
    735
    MONW, Ks.
    Incredible! You must be the record holder!!
    Are you the original owner and know the complete maintenance history of your car?
    Is so, could you share?
  8. Eddie25
    497
    209
    MI
    I mean, look around. It's a major failure point and they almost all fail the same way, it's clearly not that high quality. A few examples don't dis-prove that.
    You just can't over-heat a prius, like ever. So if your water pump fails and you don't immediately stop driving, your head gasket is done. My old Saturn over-heated like 10 times and never had head gasket issues. I think it actually is purely just a quality thing. Keep it cool and you'll be OK. Still seems crazy to me to put in a non-updated OEM head gasket.
  9. Mr. F
    Mr. F Active Member
    388
    257
    Washington
    The fact that something fails is not necessarily an indication of its quality. Put through enough loading cycles, any solid material will eventually fail due to fatigue, and a head gasket is no exception. Whether or not the failure is premature could, however, be taken as an indication of quality.
    In a Prius the ICE starts and shuts down multiple times during a single drive cycle, whereas in a Saturn (or other non-hybrid) it remains operational throughout. In both vehicles the HG expands when the ICE turns on, and contracts when it turns off, so one can easily imagine the Prius HG going through at least an order of magnitude more expansion/contraction cycles than one on a Saturn.
    Once a sufficiently large number of Saturns have completed more than 1,600,000 miles on their original HGs, it might be fair to come back and knock the OEM Prius HGs that fail after 160,000.
  10. Zeppo Shanski
    Zeppo Shanski Active Member
    300
    159
    Chicagoland
    I’m just sayin’ ...
    [<<. Who makes OEM Toyota gaskets?
    ISHINO STONE® – Corteco Ishino Corporation of Japan – has been manufacturing gaskets since 1932 and tier-1 OEM supplier to Toyota, Honda and other Japanese auto manufacturers. >>]
  11. Eddie25
    497
    209
    MI
    Fair enough, but then wouldn't other hybrids also have major issues with failing head gaskets? Do they? I'd be willing to bet that 3rd Gen Prius with a higher quality gasket would last much longer... But sure it's all conjecture.
    Isn't it the coating that wears away? Isn't the metal OK, and aren't aftermarket head gaskets often all metal (no coating)?
  12. rjparker
    10,159
    6,316
    Texas Hill Country
    I believe it is thermal cycling of the block and head that allows slightly acidic coolant to slowly attack the black sealant impressed on the metal head gasket
    A later revision of the gen3 Toyota hg expanded the black sealant layer. However gen4 redesigned the entire coolant passage geometry and added a cylinder insulator to improve temperature consistency of the cylinder itself.
    Gen4 Insulator and Coolant Passages
    #32 rjparker, Aug 18, 2023
    Brabus82 and Bill Norton like this.
  13. ASRDogman
    ASRDogman Senior Member
    7,599
    3,916
    Just remember, the head gaskets for the 4th Generation engines are failing also....
  14. rjparker
    10,159
    6,316
    Texas Hill Country
    Overheat your engine and it will blow a head gasket. People often drive with their temperature icon on. Gen3 does not require an overheat event.
  15. Bill Norton
    2,157
    735
    MONW, Ks.
    By this reasoning any engine that is used in a Hybrid platform is going to have HG failures more often then the same engine in a Gasser.
  16. Bill Norton
    2,157
    735
    MONW, Ks.
    Thanks for posting this pic of the thing that is placed in the block of a Gen4.
    Other than that are the block and head the same?
    Maybe 'another' improved head gasket design?
    You call it a 'cylinder insulator'. I don't see how that description works.
    Maybe it's a 'flow mixer', or such, to 'stir' all the flowing coolant to make contact with the block more even.
    There could be eddys or backwater areas where the block runs hotter than average...
    Such as between #1 and 2 where the failures commonly occur?
    Which is also where the EGR passages get the most clogged, creating uneven flow of EGR gasses to the cylinders.
    Hence: the two leading theories of why the dang head gaskets fail routinely...
    Either way, did the thing help with head gasket life in the Gen4's?
    How exactly does one 'Overheat your engine'?
    I assume the water pump has to start failing... And the dumb driver presses on regardless....:whistle:
    Do you recommend replacing the water pump proactively at 'X' miles?
  17. rjparker
    10,159
    6,316
    Texas Hill Country
    No the engine in gen4 is totally redesigned. All parts, even the water pump, cylinders, head, egr, aux cooling lines.
    Gen4 has no inherent engine problems. A leaking exhaust coolant recirc system has taken out gen4s due to overheating drivers ignored for 5 minutes.
    Overheating means something fails and the driver assumes he can make it three more miles and or does not realize what the lights mean or thinks the temp light that flashed and went away is nothing.
    Gen3 really has no chronic overheating problems and egrs do not cause failed head gaskets. Toyota has updated pistons, rings, intake, egr valve, head gasket and ecu software to improve gen3 engine reliability. To get it in your car means a pro rebuilt engine with all of those things or a 2017-2022 gen3 JDM engine.
  18. rjparker
    10,159
    6,316
    Texas Hill Country
    The cylinder "insulator" is foam to even out cylinder wall temps in gen4s.
    Sometimes our paradigms have to be shifted.
  19. Bill Norton
    2,157
    735
    MONW, Ks.
    Some here would definitely question this statement.
    I don't know.
    I'm on my 3rd Gen3 and still trying to figure out the best route to avoiding the dreaded HG failure....
    I sold one while it was in the beginning stages of the failure... shame on me...:cry:
    So, RJ, what about replacing your Gen3 water pump before it fails? Do you have an opinion on that?
    I'm currently at +10k mi with the EGR valve disconnected.
    I can't detect a change of mpg. And, I know the engine is NOT getting uneven EGR flow.
  20. Patrick Perry
    Patrick Perry Junior Member
    Salt Lake City
    I just bought my second and third 2010 Prius:
    #1 Purchased @160k now @170k; everything working fine.
    #1 Solution:
    Time to do an EGR system clean out and possibly install a new electric water pump.
    #2: Purchased for $1,000 @260k, hole in crankcase.
    #2 Solution:
    Carefully Inspect, Purchase and Install a low mileage Japanese engine from 2017 or later that doesn’t have major history of head gasket failures.
    #3: Babied by grandparents, toured the USA @ 55 mph; given to children @300k.
    Purchased @360k, idling very rough.
    #3 Solution:
    I believe I will find that the OEM head gasket has failed.
    When I rebuild #3, an American Made Fel-Pro replacement head gasket set will be used or the best quality I can find.
    Patrick Perry
    Salt Lake City
