OEM number part unicity
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Anton Moukharski, Jan 22, 2026.
Tags:
  1. Anton Moukharski
    Anton Moukharski Junior Member
    Paris, France
    Hi!
    My mechanic is OK for me to buy the part myself, however I'm a little at a loss when it comes to which part exactly is compatible.
    I'm looking for the steering rack (I'm translating so bear with me, the axle+movement transformer that steers the wheels.. just an example however).
    I identify the OEM number thanks to websites that specialize in that : https://partsouq.com/en/search/all?q=4551047020&qty=1 (2nd result)
    I get 2 OEM numbers. OK, I guess either are good.
    But then, when I look at my dealer sites (ebay, and French stuff like Oscaro.fr and many others), I find slightly different parts for the same OEM number. In my case, there are electrically assisted or purely mechanical steering racks, AND some have a synchro bar, some don't. I noticed my car has one and I read somewhere (can't recall) that it's eletrically assisted (are some cars really still mechanically assisted for turning??).
    Any idea on how to procede?
    (Hopefully I'm not doubling a post, the Search doesn't work right now)
    COPY OF OEM number part unicity | PriusChat
    (since it's a general question but maybe there are specific answers for Gen2 and/or the part I'm talking about itself.
  2. rjparker
    rjparker Tu Humilde Sirviente
    11,152
    6,989
    Texas Hill Country
    Most conventional cars are still hydraulic steering but your gen2 Prius is electric.
    I believe the only replacement that includes the electric assist will be Toyota. To get a reduced oem price you would have to order it online from a Toyota dealer.
    Any Toyota dealer will use your vin to supply the exact part which in some cases could vary over a production run, sometimes in the middle of the year.
    Often the variance is an upgrade from the original which means casual googling can provide more than one part number. Again a Toyota dealer can tell when a part supercedes original or intermediate parts.
    A shop gets a discount from local dealers so parts which require shipping to get a better price sometimes are not a great deal.
    With that said it often pays to check with an online Toyota dealer.
    Anton Moukharski likes this.
  3. Tombukt2
    Tombukt2 Senior Member
    13,879
    2,521
    Durham NC
    The part that generally wears out is the manual rack assembly .tie rod ends etc . literal slip in the rack and slide assembly . The electric assist is above your knees sitting in car
  4. Anton Moukharski
    Paris, France
    Yeah no so I do know for sure my OEM part number, but the online dealers offer too many options for that 1 number. And Toyota is too expensive (around 700+ euros - more than my mechanic wants to charge if he gets the piece himself), unless maybe there are refurbished Toyota deals... but then even though I should I don't feel super confortable about a refurbished steering gear.
  5. ChapmanF
    19,065
    It looks as if @Tideland Prius deleted the other thread and the responses that were on it instead of merging the threads, so I'll try to re-create my post from there here:
    In my experience, there can be different part numbers that go with different trim/option levels for the car (for example, there may have been a trim level that came with larger wheels and different steering angles). I would be very cautious about assuming two part numbers are interchangeable because they both are listed.
    I would want to confirm with a search by the Toyota dealer, or on a web site from Toyota itself, checked with the VIN of the car.
    When you are looking on generic internet marketplaces like eBay and those others, the accuracy of whatever you see depends completely, usually, on whoever enters those listings. Often they have minimal knowledge of what they are selling, and they might have a part in hand that was salvaged, and list it under some number that they see physically marked on the part. That is risky because Toyota parts often have numbers physically marked on them that are not their part numbers. Or the person may have copy/pasted and edited a listing for something else. And so on.
    I am not aware of any Prius generation ever coming with anything except electric-assisted steering. Any listings to the contrary would have to involve some mistake. It's not always easy to be sure what the mistake was. (Is it the right part, described incorrectly? or with the wrong picture? Or really the wrong part?)
    I confess I don't know what a 'synchro bar' is, in the context of a steering rack.
    With great care. I would want to start with a definitely-known-good part number confirmed with Toyota, and then be very careful sifting through generic marketplace listings for the part.
    Here in North America, Toyota sometimes has inventory of parts they have remanufactured themselves. Last I knew, you could check for those by tacking -84 on to the end of the part number and searching for that. I would be fairly confident of a remanufactured part coming from Toyota.
  6. Tombukt2
    13,879
    2,521
    Durham NC
    Taken pictures of this years ago not posted they're are two different brands of assist motors two different labels and all of it both will plug and bolt up in either place I have them both on ground in carport can supply pictures . This isn't your gear just assist . You're gear is a standard manual rack no fitting no hoses nada. The gear reman. Is like 170 US dollars similar to Corolla manual rack . We install reman racks pretty regular in many models of vehicles . may not be a new available.
  7. ChapmanF
    19,065
    Part number given by the OP shows up for me as the rack, not the assist motor. Shows up as fitting 2004–2006.
    OP didn't seem to mention what other part number originally came up; maybe that one shows 2007–2009?
    Thanks Tombukt2 for the reminder that the electric assist parts are separate from the rack in gen 2 and later. They were built into the gen 1 rack, but that made the gen 1 rack a weird expensive part nobody liked.
  8. Tombukt2
    13,879
    2,521
    Durham NC
    One assist is Asin or Asian and the other I think begins with a c both have same plugs or outlets on them one was from a loaded 05 the other Asian unit from the 07.
  9. pasadena_commut
    pasadena_commut Senior Member
    3,076
    956
    Southern California
  10. Tombukt2
    13,879
    2,521
    Durham NC
    Well both of mine are USA Southern cars one 5 04 the other 7 08
