OEM Part Numbers for Spare Tire set?
Discussion in 'Gen 5 Prius Accessories and Modifications' started by RobotBastard, Sep 20, 2024.
  1. RobotBastard
    RobotBastard Junior Member
    30
    Connecticut
    2024 Prius
    I've got the Limited, and I don't enjoy the thought of needing to do a sensor change just because I used the fix-a-flat gunk.
    I have no use for a bunch of goofy under-deck compartments in the trunk, so I'd like to pull that out and replace it with a proper spare tire.
    Has anyone put together a parts list for the spare tire set? It would be useful if I could just take that to the dealer.
  2. RandyPete
    RandyPete Active Member
    409
    171
    Santa Margarita, CA, USA
    2024 Prius Prime
    XSE
    I have read quie a feww posts about PP spare tries so I decided to do a search for spare tires. Did no find many, but dod find this one:
    The Box Jack Set may not have the proper scissor Jack for a 2024 Prius, but there are posts about that also. I just can't find them for you. You might have to use the search tool in this forum.
  3. Hammersmith
    Hammersmith Senior Member
    2,497
    2,559
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    I mean, there is a 17 page thread about the subject in the Maintenance subforum.
    Gorgonzola likes this.
  4. RandyPete
    409
    171
    2024 Prius Prime
    XSE
    OK, so I searched that out and found your thread on the subject. That's the one I was looking for :
  5. RobotBastard
    30
    Connecticut
    2024 Prius
  6. RandyPete
    409
    171
    2024 Prius Prime
    XSE
    Did you read thru the entire thread, not just the post I itemized above ?
