OEM PIP Aftermarket Radio Fascia (55405-47080) Equivalent for 2012
Discussion in 'Gen 3 Prius Audio and Electronics' started by EV_Joyrida, Oct 9, 2017.
  1. EV_Joyrida
    EV_Joyrida Junior Member
    Tampa, FL
    I'm looking for some help tracking down a part.
    Part number 55405-47080 is the 2010-11 Prius Plug-in (PIP) OEM fascia for aftermarket radios that everyone is using in their Gen III Prius to keep that clean OEM look when installing an aftermarket radio. I'm looking for the part number for this part for the 2012 PIP. Because the trim in the 2012 PIP is much lighter in color than that of the 2010-11 Prius packages. I've attached pictures for reference.
    I was told by a dealer that I need part numbers: 58474-47140 or 47150 depending on the stereo system. However, I can't find any information on those part numbers. So I'm still at a loss.
    For clarity, I'm looking for the equivalent part of 55405-47080 for a 2012 Plug-in. So that all my trim will be color matched.
    2010 Prius II with 2010-11 Prius Plug-in fascia (55405-47080)
    - dark gray trim
    2012 Prius Plug-in in need of equivalent fascia for PN: 55405-47080
    - light silver'ish trim
