OEM Radio problem
Discussion in 'Gen 2 Prius Audio and Electronics' started by Tynyyn, Sep 24, 2018.
  1. Tynyyn
    Tynyyn Member
    109
    30
    Bella Vista Arkansas
    I have an '04 Prius with an OEM head unit. I'm very happy with the vehicle, yet am disappointed in the radio reception. I've read some previous threads about OEM radios yet I guess I didn't seem to get an answer to my problem while looking through those threads.
    Here goes: My wife's Nissan Armada gets great radio reception on various AM and FM stations. When I tune my Prius' radio to those same stations I cannot get any AM stations and the FM stations are very weak. My question is, should I look at the wire going into the head unit and the antenna or something else? Could the problem be as simple as a wire not being plugged in properly into the head unit? How should I check the in line resistor on that wire?
    Suggestions would be helpful. If there is a thread which would explain my situation I'd would appreciate a link to it. Thanks.
    Terry
  2. BarronrdPri
    BarronrdPri New Member
    Port Hueneme CA
    I had poor connection due to a aftermarket antenna swap. And in a other instance I had forgotten to plug back antenna connection so just maybe it might loose back there.
  3. BarronrdPri
    Port Hueneme CA
    I have a 2005 Prius
  4. audiodave
    audiodave Active Member
    800
    272
    US
  5. 69shovlhed
    69shovlhed Surly tree hugger
    2,170
    752
    Delaware
    could be faulty roof antenna or simply corrosion on the mast threads. I'd unscrew the mast, clean the threads and tighten it with a 10mm wrench and see if that helps any.
  6. KK6PD
    KK6PD _ . _ . / _ _ . _
    4,003
    946
    118
    Los Angeles Foothills
    so you all know that there is an antenna pre-amp that is in line with the FM antenna right?????? The unit is located in the passenger roof above the headliner, close to the pillar between the front/rear doors! If it's lost power, or dead, your reception will go to hell really quick....
    If this were my car, the way I might test the theory is 1- I would make sure that antenna connector is securely pushed into the ant socket if that produces no significant results, check # 2 - would be to take a cheap antenna you might find at auto zone, etc, and plug it into the radio and see if FM improves. Make sure the antenna has the proper sized Motorola connector, tere are several sizes, or get an adapter. You are not going to install that antenna, but if it helps, it narrows down the field to the root of the problem. If indeed the pre-amp is bad, You can have Toyota fix the problem, costly, or buy the pre-amp and install it yourself. I myself am comfortable doing that, some are not! Also an ohm check from the input to he pre-amp unit to the socket of the antenna might be in order to see if the coax is open... while it's a simple fix, there are steps you need to check out to resolve the problem it takes some time, equipment/tools, and replacement parts!
    good luck, let us know how you get the problem solved!
  7. Tynyyn
    Tynyyn Member
    109
    30
    Thanks to everybody for your replies. I shall delve into the problem. Although I haven't yet done anything, I'm thinking the problem lies with the pre-amp. Exasperating to be a techno dolt, though.
