OEM rear shocks or KYB?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by famoustale, Sep 28, 2019.
  1. famoustale
    famoustale Junior Member
    31
    U.S.
    Hey guys. I'm replacing the rear shocks and was surprised to see that the OEMs are actually cheaper than KYB at $40 a piece.
    Is there any reason to go with KYB?
  2. JC91006
    16,925
    8,637
    Buy the oem, same thing as kyb
    famoustale and Raytheeagle like this.
  3. famoustale
    31
    U.S.
  4. Raytheeagle
    Raytheeagle Senior Member
    11,267
    15,526
    Bay Area, California
    2019 Prius Prime
    I replaced the shocks on our old 2010 at 180ish k miles and went KYB:).
    They’re OEM and they work well;).
    Good luck and keep us posted (y).
    famoustale likes this.
  5. The Critic
    The Critic Resident Critic
    3,193
    2,333
    CA
    KYB and Genuine Toyota are definitely not the same. They are tuned differently and the Genuine Toyota units last significantly longer. I have seen this multiple times. Also, not all Genuine Toyota shocks and struts are made by KYB - some are made by Tokico.
  6. douglasjre
    douglasjre Senior Member
    2,238
    747
    Null, NL
    Who makes the turd gen shocks? Who has best price?
    nicoj36 likes this.
  7. iskoos
    iskoos Active Member
    415
    254
    Orlando, FL
    I am in the market to buy a pair of rear shock absorbers. I was thinking between TRQ and KYB.
    Now that I see the OEM is around the same price, I will get me OEM shocks...
    I checked and it seems the part number is 48530-80533
  8. famoustale
    31
    U.S.
  9. NewHybridOwner
    NewHybridOwner Active Member
    607
    283
    W. Michigan
    From the page you linked:
    "Product Details
    • Positions: Left, Right
    • Other Names: Support, Shock Bushing, Shock Support, Shock Absorber Support, Support Rear Suspensi
    • Description:
      Prius. IM. TC.
    • Notes: Included With Shock Absorber. "
    (Emphasis added)
    #10 NewHybridOwner, Nov 12, 2019
    Khezekiah and famoustale like this.
  10. famoustale
    31
    U.S.
    Thanks for pointing that out! I may shoot them an email to confirm, seems weird that this $50 item is included with the $36 item (shocks)
    EDIT:
    McGeorge's (very quick) response:
    Part number 48530-80533 does not appear to come with any bushings. It would just be the shock with the top nut. The description is handled by a third party, so it is unfortunately inaccurate. We apologize for the error.
    EDIT2:
    What I ended up doing is getting the OEM shocks from McGeorge and then getting two KYB SM5840 mounting kits for ~$60 from RockAuto. Hopefully this works out OK
    #11 famoustale, Nov 12, 2019
  11. douglasjre
    2,238
    747
    Null, NL
    Which ones are stiffer
  12. SB6
    SB6 Member
    324
    71
    How did this end up working out?
  13. ShihFa
    ShihFa Junior Member
    53
    Milpitas, CA
    Right now, this part is listed for $10.95. It has gone down?
  14. blaisep
    blaisep Junior Member
    48
    22
    Santa Cruz California
    I got here while looking for comparisons between Toyota and kyb.
    I have used both on separate Gen 2 Prius and I noticed that the kyb degraded more quickly.
    I would say, lacking any test equipment, that at 80,000 miles, the kyb were noticeably less effective in preventing nose dive.
    Now I'm at 257,900 miles on the car (about 90,000 on the kyb) and I think I will replace with Toyota shocks because it's such a hassle for me to replace shocks (all the things I have to get out of the way.)
