OEM spare tire install
Discussion in 'Gen 5 Prius Care, Maintenance and Troubleshooting' started by Hammersmith, May 31, 2023.
  1. Paul Gregory
    Paul Gregory Senior Member
    2,340
    614
    Alberta
    2024 Prius Prime
    XSE
    There was no room for a spare, I was given to believe.
  2. Mendel Leisk
    42,366
    That’s true, with the bigger plug-in battery.
  3. Jwangcap
    Jwangcap New Member
    Seattle, WA, USA
    2024 Prius
    LE AWD-e
    Chiming in that the install with just the main black foam and the AWD wire protector worked perfectly with my LE AWD; I cut the existing foam to size, and filled the gap with some pads and other misc. items.
    Also giving a shout-out to the Modern Spare tire; just had to use it today when we got a flat 80 miles from our hotel, and the spare handled that range like a champ!
    Humble Bear likes this.
  4. I Throw 99
    I Throw 99 Junior Member
    28
    2023 Prius
    XLE AWD-e
    When I called for a flat, they just towed me to my house. They initially wanted to tow me to Toyota, but that was about an hour away, and my house was only 10 minutes away.
    Georgina Rudkus likes this.
  5. samsprius1
    samsprius1 Active Member
    720
    182
    2023 Prius
    Limited AWD-e
    You get a spare? I do some travel I'll pickup a donut then call they can change! No tire your not going anywhere!!!!!!
  6. LesPaulTomFL
    LesPaulTomFL Junior Member
    I just wanted to follow up and show that Toyota made a HUGE Mistake not having a spare tire in many of their cars! And followed that up by trying to rob me of $1800 with no love whatsoever for the parts to DIY. Peace Out Toyota - you and me are DONE! I am a Subaru Family now - they sell affordable, reliable cars that come with spare tires! :cool: It was said in this chat many times "Speak with your wallet" and "Don't buy a car without a spare" and I did exactly that! Got 10 times the value my local Toyota dealer had to offer and none of the grief (such as dealing with them in Finance Dept.). Turns out my other car would "Give up the ghost" just 1 week later and I was not in the market for 1 car, but 2 and I just said F@*% IT and got a 3rd since it was such a good deal! (Certified Pre-owned with only 5K miles) :D This was the result of it, Good luck to all the Prius Owners here, hope you get more miles from yours than I got from mine. I am good and will enjoy all 3 cars that came with spare tires and a jack. I didn't have to do anything. Lovin' it! upload_2024-5-17_10-7-24.png
    RandyPete likes this.
  7. Mendel Leisk
    42,366
    Amen. You're only aiding-an'-abetting the corner-cutting car companies, buying a car without a spare.
  8. samsprius1
    720
    182
    2023 Prius
    Limited AWD-e
    put it in a bag behind the passenger seat between front and rear for road trip
    its not going anywhere!! I just ordered wheel and tire! I'm not getting stuck in podunk for a week waiting for tire to come in!!! Good luck!!
    reservoirblue likes this.
  9. reservoirblue
    reservoirblue Member
    96
    76
    Woodacre, CA
    2024 Prius Prime
    SE
    That is exactly what I'm doing. Bought an old donut of sinilar size and same bolt pattern on Ebay for $100 and put it in an old RV wheel cover. Done.
    samsprius1 and GcinFl like this.
  10. I Throw 99
    28
    2023 Prius
    XLE AWD-e
    I bought a spare.
    samsprius1 likes this.
  11. Serenity Now
    Serenity Now New Member
    United States
    2024 Prius Prime
    May I inquire: What model and size tire and rim did you get?
  12. Serenity Now
    United States
    2024 Prius Prime
  13. Mendel Leisk
    42,366
    Attached is an excerpt from 2023 Prius Owner's Manual I've cobbled, has some info, including spare tire size. Screen grabs:
    (same spare for both)
  14. Serenity Now
    United States
    2024 Prius Prime
    Thank you so much!!
    Edit: Found some on Amazon; just need to find a rim for it...
    #274 Serenity Now, May 24, 2024
  15. Mendel Leisk
    42,366
    Toyota's official parts website "might" have the official spare tire rim, but it's been a gong show for maybe the last year. Maybe by design.
    You'll notice in the Owner's Manual excerpt I posted it says "if equipped" regarding spare tire. From that you can glean there is a stock spare tire rim. Come to think of it, @Hammersmith might have the 5th gen spare rim part number at his fingertips.
    Serenity Now likes this.
  16. radsaq
    radsaq Junior Member
    28
    Virginia, USA
    2024 Prius
    It's the first item in the list in the first post on this thread.
    Serenity Now and Mendel Leisk like this.
  17. samsprius1
    720
    182
    2023 Prius
    Limited AWD-e
    $120 dollars at your local Toyota dealer called mine had to order out of Chicago! had it next day
  18. Agronomy
    Agronomy New Member
    2024 Prius
    XLE AWD-e
    Ok I finally got my spare put in, ordered the parts per this thread for my awd model except for the wire protector and foam parts, (cut the foam it came with instead) attached is a picture of it done. Jackstand only fit in the recess to the left behind the wheel arch but the tire iron and such fit in the foam insert hidden underneath. I was able to fit everything I had underneath already like fire extinguisher, extra clothes, water bottles, and first aid kit in the remaining foam area still
    Only thing I noticed was a little flex in the deck board right near the middle of the tire (area not really supported by foam) so I threw a roll a duct tape in the center for support and it was perfect. Total cost was around $420 which is not so great but worth the peace of mind. Let me know if you have any questions or want more pictures
  19. tat2boy
    tat2boy Junior Member
    23
    TX
    2024 Prius
    Looks great! Dumb question: what did you use to cut the foam without making a huge mess?
  20. Agronomy
    Agronomy New Member
    2024 Prius
    XLE AWD-e
    I used a hand saw and a half serrated knife, it was easy enough to cut through the foam and adjust what needed to be cut. But, yes. Huge mess afterwards. Took about 5 minutes of vaccuming the shop floor to get it cleaned up. Luckily the foam didnt really statically stick to anything except the table.
    For not making such a mess, honestly a big sharp knife might be able to get through it without chewing it up like a saw
    Humble Bear, samsprius1 and tat2boy like this.
