OEM spare tire install
Discussion in 'Gen 5 Prius Care, Maintenance and Troubleshooting' started by Hammersmith, May 31, 2023.
  1. Blackat
    Blackat Active Member
    486
    355
    Colorado
    2023 Prius
    Limited AWD-e
    I ordered from the part numbers Hammer provided and they were spot on.
    Go with his numbers.
    Gorgonzola, daisy555 and Templeton like this.
  2. daisy555
    daisy555 Senior Member
    1,729
    716
    CT
    Thanks. That’s what I plan on doing. I just needed assurance that Toyota hadn’t suddenly changed something. I appreciate the feedback.
    #382 daisy555, Dec 19, 2024
    Tanegashima likes this.
  3. Templeton
    Templeton Active Member
    371
    129
    usa
    2024 Prius Prime
    SE
    Your posts about all of this have been very helpful, so thanks again. So, I just received my toyota spare 16" "disk" rim (part no. 42611-21280). I gotta say, it is not the lightest thing in the world, but I digress.
    I have a prime SE with the stock 17" wheels. Anyone know if, due to the prime's higher curb weight, if the disc brake calipers and/or rotors on the front wheels of the prime are any bigger than the prius hybrid's? If yes, has anyone test fitted the 16" steel disk rim on a prime (of any trim) to be sure it clears the front calipers (or front rotors) ?
    And, regarding the spare tire for this set up (T145 / 90D16), what do the "T" and the "D" signify in the the tire size? I found Kumho and Yokohama spare tires in this size for pretty cheap; if the price is similar, any advantage/disadvantage of one brand over the other?
    #383 Templeton, Dec 19, 2024
  4. Gorgonzola
    Gorgonzola Member
    42
    28
    New Hampshire, USA
    2024 Prius
    LE AWD-e
    I can’t confirm your question regarding fitment on the SE, but with regard to the tire coding, “T” indicates a temporary spare, while I believe “D” before the 16 denotes wheel diameter (in this case, 16”). And you also may see 106M in the tire description - “106” is the tire load index (equates to approx 2,000 lbs), and “M” is the tire’s speed rating (81 mph, although most manufacturers will recommend that you not exceed 50 mph when using a compact spare).
    As for Yokohama vs. Kumho, I venture to guess they are roughly equivalent. It’s not like these are performance tires; just intended for short distances in emergencies. I ended up getting a Yokohama for myself simply because I figured a Japanese tire is more appropriate in a Japanese car :D
    zare34 and Templeton like this.
  5. Hammersmith
    Hammersmith Senior Member
    2,457
    2,520
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    Same. lol
    D stands for diagonal ply(aka bias ply). The other option is R for radial.
    Radial is technically better, but it's typically an insignificant difference in a tire that's only going to be used maybe a hundred or so miles over the course of its life.
    Gorgonzola likes this.
  6. Templeton
    371
    129
    usa
    2024 Prius Prime
    SE
    Thanks for the input. But, l am curious, have you tested the fitment of the 16" toyota steel spare rim on the front of your own hybrid prius? No clearance issues with your front rotor or caliper? What trim do you have?
    No problems with using the original lug nuts (designed for aluminum rims) on the steel spare wheel? They work fine with the thinner steel rim?
    Also, where can l find the official torque numbers for tightening the lug nuts after a tire rotation?
    Thanks.
    #386 Templeton, Dec 20, 2024
  7. Mendel Leisk
    42,272
    The lug nuts work fine with either the alloy rims or the spare; torque spec is 76 ft/lb. Info is in your Owners Manual (excerpt attached).
  8. Templeton
    371
    129
    usa
    2024 Prius Prime
    SE
    Thanks for that. But, unfortunately, it is not in my prime owners manual. That section is just directions on how to use the fix-a-flat kit! (since the prime comes with no spare, no jack, and no tools--except tow hook)
  9. Mendel Leisk
    42,272
    Ah. Yeah you can download pdf manuals from Toyota Tech Info site (just Google). They’re easier to search too, then the paper tome.
    Assuming the lug nuts are sim to previous gens, they have a captured washer to clamp the alloy rims, and a small but sufficient taper at the end, for the temp spare.
    just think about it too: it’d be a major gaffe for Toyota, if the their lug nuts an temp spare rims were incompatible. ;)
    zare34 likes this.
  10. Gorgonzola
    Gorgonzola Member
    42
    28
    New Hampshire, USA
    2024 Prius
    LE AWD-e
    @Hammersmith, thank you for that correction of my post. I had forgotten that detail and made an assumption — and I know better. Apologies for the misinformation!
  11. Templeton
    371
    129
    usa
    2024 Prius Prime
    SE
    Good idea, I downloaded some of those pdfs.
    Any idea what the lug nut size is for the gen5 prius? 21mm?
  12. Mendel Leisk
    42,272
    That's likely. Previous gen's are 21 mm, and 21 mm is what our son's Mazda CX5 is as well, and that's a heavier weight class I think.
    Assuming you're socket shopping. If you've got a caliper (measuring tool) you could check. Or even some sort of drawing compass, then lay it on a ruler.
    Templeton likes this.
  13. Templeton
    371
    129
    usa
    2024 Prius Prime
    SE
    Yes, I could do that as I do indeed have calipers. But the car is outside in some damn cold temps. And I have to first remove the aero cover (which is plastic) to access the lug nuts. But I will certainly do that when the temp increases such that the plastic is a bit less brittle. And it should get warmer this coming week. But thanks for the input.
  14. Hammersmith
    2,457
    2,520
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    It's 21mm.
    Mendel Leisk and Templeton like this.
  15. Cactus
    Cactus Junior Member
    32
    Mountville PA
    Any updates on this? I just bought a 24 XLE AWD and would like to get a spare as well.
  16. xliderider
    xliderider Senior Member
    8,140
    3,278
    Honolulu, HI
    I admit I didn't read through this long thread.
    Has anyone purchased the spare wheel/tire kit from modernspare.com?
    2023-'25 Toyota Prius Prime Spare, Light Alloy, Long-Range | Modern Spare
    Sounds very appealing, strong/lightweight alloy rim, M rated tire. Came across the product looking for options for a spare for our 2025 Toyota Crown Signia with no spare. They have an application for the Crown/Crown Signia, I thought you all would be interested as well.
    Edit: OK, did a search and saw that, indeed, modernspare.com has been mentioned in previous posts.
    https://r.tapatalk.com/shareLink/topic?url=https://priuschat.com/threads/anyone-tried-this-spare-kit-from-modern-spare.248064/&share_tid=248064&share_fid=1171&share_type=t&link_source=app
    SM-G781V ?
    #396 xliderider, Dec 28, 2024
  17. Templeton
    371
    129
    usa
    2024 Prius Prime
    SE
    Crazy thing, is that for the gen5 prius at least, the steel toyota spare is lighter than those modernspares.
  18. Hammersmith
    2,457
    2,520
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    Your problem with the Crown Signia is that the version with the factory spare has a different deck board that raises the the deck and accommodates the height of the spare.
    If you wanted to have a completely factory conversion, you would need the following parts:
    58410-30050-C1 - BOARD ASSY, DECK, SPARE TIRE-TEMPORARY(T165/80R17)
    58411-30030-C1 - BOARD, DECK, NO.1, SPARE TIRE-TEMPORARY(T165/80R17)
    58412-30020-C1 - BOARD, DECK, NO.2, SPARE TIRE-TEMPORARY(T165/80R17)
    64777-30120 - CUSHION, SPARE WHEEL, SPARE TIRE-TEMPORARY(T165/80R17)
    51931-33270 - CARRIER, SPARE WHEEL, NO.1, SPARE TIRE-TEMPORARY(T165/80R17)
    4261B-30010 - WHEEL, DISC (FOR SPARE), 17X4T,SPARE TIRE-TEMPORARY(T165/80R17)
    T165/80R17 - (ex. Yokohama Y870C or Continental SContact)
    But the prices for all the parts are pretty insane even with discounts and sales.
    MSRP - around $1700
    31% off - around $1200
    31% off + 20% off sale - around $990
    31% off + Black Friday 25% off - around $935
    xliderider likes this.
  19. xliderider
    8,140
    3,278
    Honolulu, HI
    Yeah, those prices ARE insane!
    Thanks for confirming that a T165/80R17 spare will also work. It's closer to the OEM 225/55/R19 in circumference. I was worried that there would be interference with the brake calipers or EPB with the 17 inch donut rim. Though the 165 is wider than the 145 tire.
    I realized the Crown Signia also has 14mm wheel studs, not 12mm. So that might make finding a spare more difficult, since most passenger care have 12mm studs.
    SM-G781V ?
  20. Mendel Leisk
    42,272
    If the crown insignia has the spare in certain markets, or if it was a last minute delete, the owners manual may have the spare tire specs. You can download the manuals in pdf format; one source is Toyota Tech Info, under the "manuals" tab.
    Appreciate I'm a broken record, but my 2 cents, if you want a spare, buy a car that comes with one.There is no way I'd drop that kind of money, and then start cobbling.
