OEM spare tire install
Discussion in 'Gen 5 Prius Care, Maintenance and Troubleshooting' started by Hammersmith, May 31, 2023.
  1. Zeromus
    Zeromus Active Member
    553
    309
    Ottawa Canada
    2024 Prius Prime
    SE
    Now its just a matter of finding it, or an importer who wants to order what amounts to a tiny item.
    I wonder if there's an alternative DIY option I could consider using at some point, in the event I can't get this thing. It seems like such a slam dunk low cost accessory to offer I'm surprised we don't have it in North America. I have been planning to get a generator for a long time now, ever since a really terrible storm happened here. But if the car can replace that need, I will gladly take it. It's probably significantly more fuel efficient and quieter when doing the same job too for short stints. I obviously don't think it should run 24 hours or anything doing the job.
  2. Winston Smith
    Winston Smith Active Member
    473
    339
    OH
    2024 Prius
    LE AWD-e
    Thanks for laying out the full solution in detail. When I bought a Corolla pre-covid, they all came with the boot space "enhancement", i.e. no spare. I made inclusion of the full kit part of the deal.
    An alternative for some people might be just carrying a tire only. If you have a problem on the road, is the most frustrating part going to be not having a jack and wrench? Or is it going to be getting towed into a town that doesn't have your tire size?
    For as often as anyone sits behind me, I could see sitting a tire in the rear passenger footwell.
  3. Mendel Leisk
    42,343
    IIRC 4th gens that came without a spare at least had the scissor jack and lug nut wrench. Toyota is applying "continuous improvement" credo, to their cutbacks.
  4. Winston Smith
    473
    339
    OH
    2024 Prius
    LE AWD-e
    It's gratifying that they put this much effort into looking out for us.
    I haven't changed a wheel roadside in many years. I don't know that I would try it with the stubby wrench that comes with kits. It may weigh a lot, but a long breaker bar and socket could probably find a nook somewhere amongst all that styrofoam.
  5. Mendel Leisk
    42,343
    As long as they're torqued to the spec'd 76 ft/lb's, should be no problems with the factory supplied style of wrench.
    There's other, long-gone goodies. Owner's Manual recommends to chock the wheel diagonally opposite the flat. There is a compact, steel pair of wheel chocks from Toyota, for this purpose, AFAIK it at least used to be supplied, for Japanese Domestic Market.
    TOYOTA SOARER EMERGENCY WHEEL CHOCK STAND AND POUCH 91-00 – Import Nation Australia
    #165 Mendel Leisk, Mar 15, 2024
  6. Hammersmith
    Hammersmith Senior Member
    2,484
    2,543
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    My personal solution is a cheap Ryobi impact wrench. I also have a cheap Ryobi tire inflator that uses the same battery(which I have about six of because I have a bunch of Ryobi tools). And I've got the adapter so I can use the impact wrench to raise and lower the scissor jack. I don't plan to use it until my ToyotaCare runs out, but it's nice to be prepared if I'm in the middle of nowhere.
    There are two dedicated spots for sockets in all the different foams(I think). One is for a standard socket, and the second is for a security socket if you've got wheel locks. There's also a dedicated spot to store up to three folding triangle reflectors. If you really wanted to, you could use that slot for a medium length breaker bar and a pipe to extend it(something more comfortable to use than the factory wrench).
    Georgina Rudkus likes this.
  7. Winston Smith
    473
    339
    OH
    2024 Prius
    LE AWD-e
    The problem I foresee is the application of my old man muscles and soft hands reliably getting 80 ft/lbs thought what looks to be a one foot wrench after I've already jacked up a car gotten five nuts loose and removed the old wheel..
  8. Mendel Leisk
    42,343
    Maybe throw stow a pipe extension then. Too: try it, in advance. Check out the scissor jack operation too, Toyota supplied one is a mixed-bag, Honda's are better.
    Alway good to break loose the lug nuts before raising the wheel; then it's not precariously dancing on the scissor jack. Just slightly loosen them; leaving them snug.
    GcinFl likes this.
  9. b0nd0710
    b0nd0710 New Member
    2024 Prius
    Spare Tire, foams and boards all stay intact with no noise or shifting after plenty of driving. Success to all my LE peeps. Happy spare tire modding :)
    Jerry G likes this.
  10. Greenhill39
    Greenhill39 New Member
    2024 Prius
    4 way lug wrench.jpg I am including a 4-way lug wench to my spare tire install. Foam inserts fit our Limited great. The aftermarket donut spare i got from Discount Tire appears to be a whisker wider than expected. The deck rubs the tire but doesn't wobble. I'm not sure where I'll store the lug wrench, but I have always carried one. I end up with a roadside tire change about once a year. Twice last year in my Ford Flex. The Prius is my Wife's.
    GcinFl and Jerry G like this.
  11. Hammersmith
    2,484
    2,543
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    There are supposed to be little dense foam blocks glued to the underside of the deck board to keep it stabilized. That's the difference between the standard high deck board and the spare tire deck board. I keep meaning to document the size and placement of the blocks, but the warm weather doesn't stick around long enough. I promise I'll get to it soon.
  12. LesPaulTomFL
    LesPaulTomFL Junior Member
    So, I am going to end my participation in this thread saying that I spoke today loud and clear with my money and I purchased a new car that came with a spare tire - and I did not have to pay $1800 above the car cost and I did not have to move mountains to get a factory warranty (Factory product NOT JM&A Product) (Not the same) for 100K miles.........any way it does not have a Toyota logo - Sorry Toyota - you are dead to me as the great Shark Tank Leader Kevin O Leary would say.......you are dead to me. Nice job cutting cost - how did that work out for you?
    Mendel Leisk and Tande like this.
  13. LesPaulTomFL
    You guys are awesome and good luck with your new Prius and the 2.0L - I wish you all the best! Wish I could have went that way.....Thanks for all the help as well.
    Tande and GcinFl like this.
  14. Jeff606
    Jeff606 Junior Member
    31
    SF Bay area
  15. SparcEE
    SparcEE New Member
    2024 Prius
    XLE AWD-e
    The AWD connector cover flange nut has been replaced by: 90178-A0132
    Toyota 90179-06274 Clip
    1996-2023 Toyota 90179-06274
    • Part Description Bumper Cover Nut
    • Part Name Code 33821G
    • Replaced by 90178-A0132
    • Manufacturer Toyota
    This thread has been super helpful as I just ordered all of the parts.
    Also, just happened to get a JD Power survey so i took the time to in the last question about 1 thing you love or hate about the Prius to explain the how a real spare tire is needed by many given they distance from a repair facility or even cellular access. If they at least had a reasonablly priced dealer installed kit to help those how don't have the capability to do it themselves or find the great resources here put togther the list of parts and videos to make it even easier.
    SparcEE
    GcinFl and Mendel Leisk like this.
  16. Mendel Leisk
    42,343
    The only problem (for Toyota) with doing that:
    If they designed the car so it was relatively easy to add the spare plus all the associated items (scissor jack and lug nut wrench), and virtually all buyers were shelling out for dealerships to install this kit, it would make it patently obvious, what a cash grab it is.
    KInda like air travel tickets included a charge for having a seat.
  17. jmcquaid
    jmcquaid New Member
    North Carolina
    2024 Prius
    I ordered the styrofoam pieces cited in some posts here and elsewhere. However, those pieces that go around the spare tire do NOT fit the 2024 (I have an LE) The "spare tire" compartment is not as deep as the 2023 so those pieces stand up about 4 or 5 inches higher than the floor is without the tire. The only solution is plywood or shave the 2023 styrofoam.... alas.
  18. Hammersmith
    2,484
    2,543
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    Did you read most of the thread or only the first post? The problem is not 2023 vs. 2024, it's that you have an LE with the lower floor. There's lots of discussion in this thread about the differences, including the experience of an LE owner and pics from his install.
    This forum doesn't allow the editing of posts after a day or so, so you have to actually read all of threads like these to see if there's updated info later on.
  19. villageidiot2
    villageidiot2 Junior Member
    35
    24
    2024 Prius
    This works fine on my 2024 Limited and it sits flush. The LE has the lower floor, regardless if it’s 2023 or 2024.
  20. JimLudden
    JimLudden Member
    Taos, NM
    2024 Prius Prime
    We got stuck in Chaco Canyon, 40 miles of gravel road from pavement, then farther to a tire store, with a mini-spare that had deflated to 30 psi (from recommended 65) because it is hidden under the Sienna. No room to change the flat before we had to drive to a wide spot for a change.
    So I'm just hoping I never get a flat in the gen 5 Prime.
