OEM TrueStart Battery vs ACDelco B24R replacement
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by GKinslow, Jan 12, 2021.
  1. GKinslow
    GKinslow Junior Member
    50
    23
    San Antonio
    2007 Prius Touring w/Smartkey. Bad OEM battery just beyond 24-mo free replacement. Dealer has a new one (TrueStart by Interstate) but ACDelco has an allegedly exact replacement (ACDB24R) available from Amazon for $173 with the same 24-mo free replacement 84-mo prorated warranty. I know the new ACDelco will cost more initially, but this OEM Interstate battery should have lasted far longer than 2 years. Replacing it myself. Recommendations?
    More than two years on, and I'm still learning how to use all of the features, like pulling up the display to check the 12V battery voltage and determine its status. Reads 14V when the hybrid battery is recharging it and 11.4V when turned off.
    My daughter drives it and hands it to me when something breaks. YouTube is a gift.
    #1 GKinslow, Jan 12, 2021
  2. GKinslow
    50
    23
    San Antonio
    Never mind. Stupid question. I think it would be easier to deal with a prorated OEM battery and core return at the dealer than another battery through Amazon. I believe both are manufactured by Johnson Controls.
    bisco and SFO like this.
  3. rjparker
    rjparker Tu Humilde Sirviente
    11,117
    6,975
    Texas Hill Country
    If an agm battery failed that soon, I would suspect excessive parasitic load which would continue with a new battery. Have the off state load properly measured with an inline ammeter. Should be around 20 ma or less. Often a car that is driven daily will still start with an excessive current drain but the battery life will suffer.
    GKinslow likes this.
  4. mr_guy_mann
    mr_guy_mann Senior Member
    4,118
    2,015
    NJ-USA
    I would suggest getting a decent digital multimeter and testing voltage at the underhood fuseblock- jump start point. That will give you a better reading as the MFD isn't very accurate. With the car off for awhile you should have 12.6 to 12.8V for a fully charged AGM.
  5. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,804
    2017 Prius c
    That alone is NOT a good way to determine the "status" of the battery, mostly because it isn't really giving you the voltage of the battery itself.
    What else makes you think it has failed ??
    P.S. I never recommend getting batteries by "mail order" because of all the potential problems.
  6. bisco
    52,863
    good move on the oem, imo.
  7. GKinslow
    50
    23
    San Antonio
    Replaced the OEM. I was mistaken, it was nearly 3 years old. One cell tested bad at the dealership. Paid $128 out the door for the new replacement. The Prius is happy again. Going on 14 years old with 77K on the clock.
  8. GKinslow
    50
    23
    San Antonio
    After jumping it, then driving it for 20 minutes, I turned the power off, and when trying to turn it back on again, it was dead, even only moments later.
  9. bisco
    52,863
    hang on, an oem for 128? installed?
    SFO likes this.
  10. SFO
    SFO Senior Member
    5,302
    4,252
    Northern California
    How many hours per week is the vehicle being driven?
  11. GKinslow
    50
    23
    San Antonio
    I should have made it more clear. I couldn't drive the Prius to the dealer because it was dead as a doornail. I could've jumped it but had no assurance that it wouldn't hiccup on the way. I removed the old battery myself and took it to the dealer for replacement. After verifying it was defective they replaced it and the prorated price was $128 including taxes. I installed it myself. Saved $$$ but it took the entire morning from start to finish with no screws left over or holes needing screws.:)
    #11 GKinslow, Jan 13, 2021
  12. GKinslow
    50
    23
    San Antonio
    Bought it in January 2018 with accurate 62K on the odometer. It has 77K now. So, appx 5,000 miles per year.
  13. SFO
    SFO Senior Member
    5,302
    4,252
    Northern California
    The current usage of 100 miles, or 2 hours per week may not be enough to maintain the 12v with the SKS enabled.
  14. GKinslow
    50
    23
    San Antonio
    That's a possibility.
  15. sorka
    sorka Active Member
    1,034
    199
    Merced, CA
    2019 Prius
    That same ACDelco I bought on Amazon in 2019 for my 2009 Prius just pulled 324 CCA in 35F (left the car out all night in the freezing just so I could properly test the battery).
    I was on the fence about replacing it since I've just installed a dashcam with parking mode that will still on for a preset number of hours after it loses the ACC voltage signal.
    Looks like the only reasonable non OEM replacement is the Everstart:
    EverStart Platinum AGM BOXED Automotive Battery, Group Size S46B24R 12 Volt, 410 CCA - Walmart.com
    Which is just another rebranded Interstate, same as the TrueStart which has identical specs to this one.
    Was going to do the mod the tray and replace the terminals to use a group 25 AGM battery with 50 ah or 55 ah capacity but the cost on those have gone from being way less than the S46B24R batteries to being way more.
  16. Mendel Leisk
    42,354
    Can you turn off the the dashcam's stay-on function? Or you've got to have it?
    My 2 cents: anything that intentionally stays on after shut down is asking for trouble.
    Merkey likes this.
  17. sorka
    sorka Active Member
    1,034
    199
    Merced, CA
    2019 Prius
    That's the whole point. I replaced a dashcam that didn't have this because I need this feature. It does have a safety cutoff on the power supply to physically cut the power entirely at a preset voltage which is selectable.
