OEM vs aftermarket catalytic converter
Discussion in 'Gen 2 Prius Technical Discussion' started by Ananda13, Oct 21, 2021.
  1. Ananda13
    Ananda13 Junior Member
    San Diego
    newbie here.
    My catalytic converter was stolen from my 09 prius and my insurance paid for a replacement from a local exhaust shop. I haven't picked up the car yet but I was reading online the importance of getting an OEM part vs. aftermarket so I called the shop to get more info on the part they installed.
    He said he installed a "direct fit" part, not a "universal" and they even if I had the work done at the dealership it would be the same part and the only way to get true OEM would be to go back in time and get it from the assembly line.
    So my question is, how important is it to get "OEM" and how is it different than "direct fit" or whatever he likely installed? Should I push my insurance to pay for a more expensive replacement?
    Thanks in advance for you help!
  2. SFO
    SFO Senior Member
    5,302
    4,250
    Northern California
  3. PriusCamper
    PriusCamper Senior Member
    13,067
    5,306
    Pacific Northwest, USA
    In California the visual inspection of the smog test requires the inspector to confirm it is an OEM or the most expensive non-OEM replacement cat ($700-$2K). If you lived in a different state you could put on a cat that costs less than $200. Some people have gotten away with this more affordable replacement cat in California if the inspector doesn't follow the rules / is lazy, but that's relatively rare.
  4. Another
    Another Senior Member
    1,819
    517
    Naples, Florida
    The repair guy is an idiot.
  5. TMR-JWAP
    TMR-JWAP Senior Member
    6,404
    6,093
    Columbia, SC
    The only way you'll know for sure is to look at the receipt and get the manufacturer and part number of the system they installed. Perhaps they installed the new aftermarket CAR approved model. I would find it hard to believe a repair shop, performing an insurance repair, would install a 'not legal for sale in California' model. And if they installed the 'legal' replacement, which was approved, then it should be perfectly fine.
    An OEM replacement component is "Original Equipment Manufacturer". In this case, that would be Toyota. Toyota still manufactures and sells this catalytic converter assembly and it is exactly identical to the ones used on the assembly line when the car was built, unless there have been improvements made. It does not mean the actual 'original' piece installed during assembly. So, in this case, the repair guy is significantly uneducated.
    Most automotive repair parts are available from several different manufacturers. OEM would be Toyota (or whichever manufacturer built the car) and would be most likely to be a perfect fit and have the longest life. An "Aftermarket" manufacturer would be everyone/anyone else who reverse engineered the part and built their own version, usually these are less expensive, and potentially lower quality with a shorter lifespan. Some aftermarket companies do a great job and are equal to or better than OEM.
    #5 TMR-JWAP, Oct 22, 2021
  6. alftoy
    alftoy Senior Member
    1,132
    518
    Saskatchewan, Canada
    Direct fit are available as low as $180 vs $2000 for OEM
  7. fuzzy1
    10,603
    But California legal????
  8. dolj
    dolj Senior Member
    8,559
    4,349
    Wellington, New Zealand
    No, but the aftermarket that is legal is in the same ballpark as OEM.
  9. Another
    1,819
    517
    Naples, Florida
