Official JDM Aqua/Prius c Press Information
Discussion in 'Prius c Main Forum' started by ydooby, Dec 26, 2011.
  1. ydooby
    ydooby Junior Member
    29
    32
    CA, USA
    Converted the official PDF brochure to images for your convenience of viewing and quoting.:)
    New information includes drag coefficient of 0.28 Cd, and pics of the trunk and a person sitting in the rear seat.
    11 people like this.
  2. 2sk21
    2sk21 Member
    138
    22
    Teaneck, NJ
    Dashboard looks quite similar to the dashboard on my Prius v. However, it seems as if there is a "gear shift" lever in the console between the front seats. Am I seeing things right? What would be the purpose of this - I see the standard PRNDL shift knob on dashboard.
  3. AquaJan
    AquaJan Junior Member
    47
    17
    US
    "The Aqua uses the same 1.5-liter Toyota Hybrid System II engine found in some of the most recent Prius cars, which has returned a touch over 35 km/l or 82mpg in Japanese tests. This will be revised to between 50mpg and 60mpg for the US launch though."
    Why does it lose 30mpg between Japan and here??????
  4. giora
    giora Senior Member
    1,966
    730
    Herzliya, Israel. Car: Euro version GLI
    2013 Prius Plug-in
    Could be 'Imperial miles' versus 'US miles'? LOL
    Now seriously, these are completely different tests, plus the fact that EPA is manipulating the results by some kind of correction factor.
    Generally, EPA sticker is more realistic to the average driver although hypermilers will easily defeat it.
    Welcome to Prius Chat.
  5. Teacake
    Teacake OohShiny
    152
    43
    Louisville, KY
    Thank you for these amazing pictures! While I know people will quickly start pointing out very informational and advanced technical points using this information...I just want to add, "YAY more colors! :cheer2:"
  6. Flying White Dutchman
    4,376
    313
    i see that there is one model doing w little better in mpg also 1080 and 1050kilograms
    so maybe the 3 door version?
  7. alfon
    alfon Senior Member
    1,370
    270
    seaside, oregon
    Can this be converted into English.....
    al
  8. ryogajyc
    ryogajyc Active Member
    985
    165
    Reseda, CA
    Could you post the original PDF? Then...
    the answer is yes. Use Google Translate: Google Translate.However, I don't know how to save the translated PDF, so if anyone figures that out, please let us know.
  9. cwerdna
    cwerdna Senior Member
    12,545
    2,125
    SF Bay Area, CA
    Yep. The tests are totally different.
    http://priuschat.com/forums/prius-h...s-c-leaked-photos-brochure-3.html#post1403842 shows the Aqua specs vs. the regular Gen 3 Prius on the Japanese tests.
  10. ydooby
    29
    32
    CA, USA
    3 people like this.
  11. Tideland Prius
    16,668
    It looks like the difference between the base "L" trim level (with 14" tyres) vs. the uplevel "S" and 'G" trim levels with 15" wheels.
  12. ryogajyc
    985
    165
    Reseda, CA
    Unfortunately, Google Translate doesn't work b/c the PDF is all graphics instead of Japanese text.
  13. deliciousirony
    deliciousirony New Member
    1.5L :( I thought this was going to have the 1.8L from the current Prius
    and ugh, why the huge shifter?
    That back end looks ... impacted, too.
  14. B. Roberts
    B. Roberts Hypah Milah! Ayuh.
    691
    212
    used to be "Glacial" Maine and now FL
    Maybe compacted? Why would we need a 1.8L on a smaller and lighter car?
    Has anyone done a power to weight ratio comparo between a Gen III and the c?
    Don't know why they would go retro on the shifter.
  15. Tideland Prius
    16,668
    It's cheaper to go with the 1.5 litre 1NZ-FXE engine because it's an older engine (so they'll continue to reap the benefits of the R&D cost) and it's been updated with the latest technology such as the electric water pump (so beltless engine like the 1.8) and there's the exhaust heat recovery system too.
    I don't think there's a new NR family engine with 1.5 litre displacement. There's 1.0 and 1.33 (same one in the iQ and Yaris in Europe) and I don't think either would work well on US roads.
