Official (OEM) Toyota Prius 2016 (Gen 4) oil-change instructions
Discussion in 'Gen 4 Prius Care, Maintenance and Troubleshooting' started by Gokhan, Mar 4, 2016.
  1. Mendel Leisk
    41,516
    Good luck pre-loading a horizontal mounted filter.
    Doug McC likes this.
  2. Doug McC
    Doug McC Senior Member
    1,079
    418
    Midwest
    2022 Prius
    I SUPPOSE you COULD use that as an argument in a misguided attempt to support not changing the filter. :whistle:
  3. Michael Wood
    Michael Wood Active Member
    181
    118
    Boston, MA
    2020 Prius Prime
    Stick around.....at some point "Prius culture" will get you to stop throwing those $5 bills away and filling the landfills with clean oil filters.
  4. Michael Wood
    181
    118
    Boston, MA
    2020 Prius Prime
    "QUOTE....I've never filled new oil filters with oil even though some recommend it...the thing fills up super-fast when the engine starts so I don't see how that could be harmful to anything."
    When you have a spin-on filter that mounts vertically, it's practical to prefill the filter. You'll avoid that full second of valve chatter on start-up. The metal to metal contact is audible if you don't prefill - and high milers don't like to hear that. On a vertically mounted filter you're going to make a mess, but you could do a partial prefill and see how that works.
    #204 Michael Wood, Nov 3, 2023
    ColoradoBoo likes this.
  5. Doug McC
    1,079
    418
    Midwest
    2022 Prius
    I recycle my old filters and peer pressure quit influencing my behavior a long time ago. Facts generally have more of an influence, not opinions. ;)
  6. Michael Wood
    181
    118
    Boston, MA
    2020 Prius Prime
    I agree with you 100% on "facts". Here are some facts to mull while recycling those filters -
  7. Doug McC
    1,079
    418
    Midwest
    2022 Prius
    Sorry, but I missed the facts in your attempt to influence my behavior by peer pressure and ridicule. :sneaky:
    #207 Doug McC, Nov 5, 2023
  8. puspa
    puspa Junior Member
    London
    If Phillips head screws secure the panel, the rust belt can indeed pose a challenge. The corrosion risk with those screws is real. Consider exploring anti-rust measures or replacements with more corrosion-resistant alternatives to ensure long-term durability
  9. puspa
    puspa Junior Member
    London
  10. Doug McC
    1,079
    418
    Midwest
    2022 Prius
    On my ‘22 Prius the screws are plastic, the bolts are metal, but the bolts screw into plastic. I strongly suspect that it will be a significant historical event if the salt causes the plastic to corrode.
