Official (OEM) Toyota Prius 2016 (Gen 4) oil-change instructions
Discussion in 'Gen 4 Prius Care, Maintenance and Troubleshooting' started by Gokhan, Mar 4, 2016.
  1. Mendel Leisk
    41,400
    Do a dry run?
    Valiant V likes this.
  2. jb in NE
    jb in NE Senior Member
    2,233
    1,599
    Nebraska
    2018 Prius Prime
    Why is this too high? All those engineers at Toyota got this and the drain plug spec wrong?
  3. thomassster
    thomassster Member
    239
    83
    Colorado, US
    2019 Prius
    XLE AWD-e
    it seems like for my AWD 2019 version, it recommends 0W-16. They also state with this grade that it can go for 10,000 miles. I get 2 years of maintenance so I'll look to see if the dealership puts in 0W-16 at my next oil change. I'm not sure if there are any engine differences from mine to previous years.
  4. Mendel Leisk
    41,400
    I believe there was some contradiction, some places it says 20, others 16. I emailed Toyo Canada and they said stick with 20.
  5. thomassster
    thomassster Member
    239
    83
    Colorado, US
    2019 Prius
    XLE AWD-e
    yeah, a lot of confusion. and the maintenance manual recommends that you can use 0W-20, but the next maintenance job, use 0W-16. I see no worry using 0W-20, and since the wife's car uses 0W-20, it makes things easier for me. Luckily our local mart (Walmart) sells 0W-16, so I'll try to use it as much as I can. I am getting 55 MPG on my first tank of gas for AWD, so if 0W-16 is suppose increase efficiency, it is showing.
  6. Mendel Leisk
    41,400
    I wouldn't look too hard for 0W16; aren't all these thinner oil increments primarily to gain Toyota mpg "brownie points"? And at what cost?
  7. thomassster
    thomassster Member
    239
    83
    Colorado, US
    2019 Prius
    XLE AWD-e
    I would agree I shouldn't look too hard. But if the manual says to use a certain grade level viscosity and it's easily available within similar cost to 0W-20, then I would use 0W-16 whenever I can. Being in the owner's manual requires some type of qualification (I hope). or could this be a situation which CAFE pressures are pushing companies to recommend certain things with limited testing :unsure:
  8. Prodigyplace
    12,547
    11,772
    Central Virginia
    It was rumored that the Gen 4 had 0W-16 from the factory but recommended 0W-20 because it was more widely available.
  9. jb in NE
    2,233
    1,599
    Nebraska
    2018 Prius Prime
    The specific wording from the maintenance manual is:
    "Your vehicle is certified with Genuine Toyota 0W-16 motor oil. For VEHICLES CERTIFIED FOR 0W-16 motor oil, the oil change interval is 10,000 miles or 12 months IF 0W-16 MOTOR OIL IS BEING USED. If 0W-16 is not available, 0W-20 oil may be used. However, it must be replaced at a 5,000-miles or six-month INTERVAL with 0W-16 motor oil."
    You are on a shorter oil change cycle with 0W-20.
    The owner manual says:
    "SAE 0W-16 is the best choice for good fuel economy and good starting in cold weather. If SAE 0W-16 is not available, SAE 0W-20 oil may be used. However, it must be replaced with SAE 0W-16 at the next oil change."
    It is the maintenance manual that specifies the oil change frequency, and when 0W-20 is in the sump, it is 5,000 miles.
  10. Mendel Leisk
    41,400
    "Certified" means the mpg testing?
  11. jb in NE
    2,233
    1,599
    Nebraska
    2018 Prius Prime
    Hard to know without seeing the test protocol and results. However they certify it, these are the terms under which they warranty the car. Do the maintenance per the maintenance schedule, etc.
    Perhaps they did change some clearances in the engine, oil pressures, etc. Perhaps somebody will know if there were any physical changes made to that model year engine.
  12. Mendel Leisk
    41,400
    @thomassster what does it say on the oil filler cap? Picture would be cool.
  13. krmcg
    2,592
    2,392
    Whittier, CA
    0W-20 on mine...
    Prodigyplace likes this.
  14. Mendel Leisk
    41,400
  15. krmcg
    2,592
    2,392
    Whittier, CA
    2016 Toyota Prius 4
  16. Elektroingenieur
    2,515
    3,283
    Three Touring
    No, it’s the EPA emissions certification. For 2019 model year Prius cars with AWD, for example, see page 3 of the Certification Summary Information Report (PDF), where the “Oil Viscosity/Classification” is stated.
    That may be; use of “low-viscosity 0W-16 engine oil” is among the measures for friction reduction mentioned in the SAE technical paper from 2016 about the fourth-generation engine, and in Japan, 0W-16 has been among the specified oil grades since the first fourth-generation cars in 2015.
    Mendel Leisk and Prodigyplace like this.
  17. Prodigyplace
    12,547
    11,772
    Central Virginia
    This is the first I have heard of a 5K oil change interval for 0W-20. What changed from earlier Gen 4 ?
    From the 2017 manual:
    Maintenance log:
    #97 Prodigyplace, Jun 13, 2019
    Valiant V and Mendel Leisk like this.
  18. thomassster
    thomassster Member
    239
    83
    Colorado, US
    2019 Prius
    XLE AWD-e
    I'll take a picture when I get back to my car in couple hours of my oil cap. But it was mentioned in a different thread within the 2018 maintenance manual had that same verbiage of 0w-16, but on other pages of the same manual suggesting conflicting wording, 0w-20 to be used every 10,000 miles as well as the recommended oil for that car. It's very difficult to believe any of Toyota's wording in any of their manuals.
  19. jb in NE
    2,233
    1,599
    Nebraska
    2018 Prius Prime
    How so? I have found the wording to be very clear. Is it that the wording is not clear, or you don't believe what the wording is telling you?
    Valiant V and Prodigyplace like this.
  20. thomassster
    thomassster Member
    239
    83
    Colorado, US
    2019 Prius
    XLE AWD-e
    The only issue I have that makes my head scratch is the 2018 owner's manual conflicts with maintenance manual. and you can see it's clear that they took the same wording and modified couple words/numbers for the 2019 version.
    2018 owner's manual:
    2018 maintenance manual:
    2019 owner's manual
    2019 maintenance manual:
