Officially joining the club
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by markabele, May 21, 2013.
  1. markabele
    5,084
    1,782
    Nebraska
    Some questions:
    Are partial charges ok? I have some really unpredictable days sometimes. Can I charge up about half way and leave it that way for a day or more?
  2. drinnovation
    drinnovation EREV for EVER!
    2,027
    586
    65
    CO
    Yes, not a problem to do partial charges. In fact if you are going to leave it sit at high temperature it can be even better. Ideally you want it to finish charging just before you use it.
    Of course you then risk not having a full charge when you need it.
  3. markabele
    5,084
    1,782
    Nebraska
    So leaving it at 50-60 percent is ok for 24-48 hours?
  4. CharlesH
    2,798
    1,166
    Roseville, CA
    The old Nickel-Cadmium rechargeable batteries had a problem with partial charges, leading to a "memory effect" and the advice to charge them completely. The Lithium-Ion batteries used in the PiP (and the Nickel-Metal-Hydrid batteries used in the standard Prius, for that matter), do not have this problem.
    JMD likes this.
  5. drinnovation
    2,027
    586
    65
    CO
    Leaving it at 50-60 percent for months is probably okay. 40-50% is the ideal long-term storage charge level for Li-Ion.
  6. markabele
    5,084
    1,782
    Nebraska
    So if I put an end time for the timer with a half charge already in the battery does the timer then start charging about an hour and a half before the end time?
  7. drinnovation
    2,027
    586
    65
    CO
    Approximately. I recommend you aim for 30min or even a hour before you leave in case something comes up and you have to leave early. Most important thing is not to charge when its really hot, so even if it finishes at 5am in Nebraska it should be fine till you leave in the AM.
  8. Tideland Prius
    16,683
    As in air temperature or as in when the car is really hot (i.e. after a long drive)?
  9. Tideland Prius
    16,683
    That's what I've noticed too when I test drove the PHV. P&G probably still works but maybe it needs to be modified? I didn't have time to try it out since I wanted more time in the RAV4 EV :)
  10. drinnovation
    2,027
    586
    65
    CO
    Its all about the battery temperature. Air temp can get the battery hot, but so can heavy battery use. In generally best to charge when the air and the battery are both cool, since the prius does not have a liquid TMS as some others do. If one sets it to charge by early morning it will allow both air and th car/battery to cool. But all of this is a secondary concern for the Plug in Prius as the battery is small enough and if charging on L1 is slow enough that its probably not much of an issue. Temp induced loss was an issue for leafs, but they were L2 and QuickCharge users often going to 100% (prius protects it not letting people go to 100%). And even for those leafs it was an issue in AZ, with almost no measured impact in cooler places like seattle or even northern Cali. Canada.. you're probably cool.
    Chazz8 and Tideland Prius like this.
  11. Tideland Prius
    16,683
    Thanks!
    lol. It can hit 30+°C in many places in Canada (38°C in south-central British Columbia where the cacti can be found). Some are dry heat (Prairies or south-central BC), others are humid (southeastern prairies and southern Ontario). Heat can be an issue. (and also why I love my Solar Panel Ventilation System)
  12. drinnovation
    2,027
    586
    65
    CO
    30C is near ideal temps for LiIon -- more range fromt he battery with little risk to battery.
    Don't think a few days of even mid to upper 30's C sort are a big problem, though best not to leave it with a full charge in the sun when in the upper 30s Its weeks mid to upper 40s's that really toasted the leafs in AZ -- air temps there are regularly 46-47 and a car on hot backtop can hit 50+ inside.
    Tideland Prius likes this.
  13. markabele
    5,084
    1,782
    Nebraska
    After preliminary tests it looks like the stop timer simply starts it 3 hours before then end time regardless of how much charge is left.
  14. bisco
    52,889
    pip manual says to discharge to zero ev for long term storage. for short term. i leave it around 50%, that's when the level 2 evse is worth it, only 45 min. to top up.
  15. markabele
    5,084
    1,782
    Nebraska
    Finally had my first chance to do some old school (as in not that many months ago with the last Gen3 I had) pulse and gliding since it was my first time out of EV and not at highway speeds. Like riding a bike, although I was just a tad rusty.
    Why is the warmup cycle so dang long compared to the Gen3?
  16. 3PriusMike
    3,101
    2,421
    Silicon Valley
    Yes, it says to zero EV, which means about 20-25% actual.
    Mike
  17. bisco
    52,889
    right. but the only thing you can tell without a scan gauge is zero.
