Oh CRAP.....wrong gas
Discussion in 'Gen 4 Prius Care, Maintenance and Troubleshooting' started by ssdesigner, Aug 4, 2016.
  1. Coast Cruiser
    Coast Cruiser Senior Member
    2,267
    2,571
    Pacific Coast Highway
    That's the first time in 45 yrs of driving, that I started to pick up the wrong nozzle.
    I've seen diesel nozzles that were not green, and not blue. Just dirty black like the regular gas nozzles. But you guys are correct, supposedly a diesel nozzle will not fit into a newer (?) non-diesel gas tank. But you still hear stories of people doing it somehow.
  2. Coast Cruiser
    2,267
    2,571
    Twice a year, I would pour a $5 bottle of Chevron "Techron" fuel system cleaner into my Camry's tank. Have no idea if it made any difference, or if it was actually needed. Top Tier gas seems to be good enough these days.
  3. Mendel Leisk
    42,241
    Gotta hunch those fuel treatments don't do much, if anything. I do use Chevron, virtually exclusively, just a hunch they have good quality control, and they're the only stations in town that still provide free air. That said, the last few times I've aired up the tires, at more than one station too, the pumps seemed barely capable, not sure what's going on there.
    Coast Cruiser likes this.
  4. bhtooefr
    bhtooefr Senior Member
    1,396
    1,489
    Newark, OH, USA
    Diesel nozzles are typically 24 mm (except for high-flow (truck) nozzles at 30 mm), versus unleaded gasoline nozzles at 21 mm. And, leaded gasoline nozzles were typically 25 mm, IIRC - within the tolerance range for diesel nozzles.
    However, it's worth noting that 21 mm diesel nozzles, while they used to be around here and there, are far less common now, due to a lot of diesel cars having mechanisms to prevent a 21 mm nozzle from being used to fuel the vehicle - only a ~24 mm nozzle can open the filler neck.
    Also, BP locations will typically use black for diesel, as that's the European (at minimum UK) standard, I believe.
    CR94, Coast Cruiser and Mendel Leisk like this.
  5. The Electric Me
    The Electric Me Go Speed Go!
    9,083
    5,801
    Undisclosed Location
    Oh..my god! It's a tragedy! Siphon it all out now, like it's snakes venom.
    You're absolutely fine.
    If it makes you feel better, some people occasionally run fuel injection/system cleaners that temporarily change the octane of the gas in the tank.
    Even though I hesitate to recommend it, because I feel it's probably unnecessary, about twice a year I run a tank of Premium just for kicks, and I use a Techron fuel treatment.
    I recommend simply using "regular" but 2 gallons of mid-grade...even a whole tank of premium, IMO is not a problem.
  6. alanclarkeau
    alanclarkeau Senior Member
    7,045
    7,593
    near Brisbane, Australia
    FOUND IT - the handbook says (Page headed "OPENING THE FUEL TANK CAP"):
    "To help prevent incorrect fuelling, your vehicle has a fuel tank opening that only accommodates the special nozzle on unleaded fuel pumps".
    Which presumably includes premium and E10.
    krmcg and Coast Cruiser like this.
  7. Tideland Prius
    16,665
    Yeah the local dealer keeps on bringing it up *fuel injector cleaning" and "hot engine oil treatment".
  8. alanclarkeau
    7,045
    7,593
    Maybe on a REALLY old car. My Dad's 1992 Camry, 250,000km, (fuel injected) was running a bit rough, recently his mechanic suggested some fuel injector cleaner - 2 bottles later, it was definitely running better.
    Tideland Prius likes this.
  9. Gen 2 Tom
    Gen 2 Tom Active Member
    333
    286
    Lincoln Park NJ
    Yes, I knew there was a nozzle size difference. I couldn't remember what wouldn't fit into what. So the diesel pump won't fit into a gas car. Today with diesel at the same pump as the gas you have to be careful.
  10. orenji
    orenji Senior Member
    5,887
    3,488
    ssdesigner likes this.
  11. kithmo
    kithmo Couch Potato
    2,404
    2,776
    47
    South Yorkshire, UK
    UK pumps have 4 nozzles. Of the 4 on each pump, Shell has two green nozzles, one for Fuelsave (normal UL) and one for Nitro (Super UL) and two black nozzles, one for normal Diesel and one for Nitro diesel. The two different fuel Nitro nozzles could be very easily confused if you're not paying attention.
    alanclarkeau likes this.
  12. Tideland Prius
    16,665
    Or when you guys come over here! Diesel fuel is the green pump handle! (all nozzles are unpainted steel)
  13. Autoist
    Autoist Member
    119
    81
    Seattle Metro
    Not always. Don't be lazy, always pay attention and pick the right nozzle pump.
  14. bhtooefr
    1,396
    1,489
    Newark, OH, USA
    There's no standard for colors. Read, then grab.
    Except at BP, where diesel's always black, regular gas is always green. (Premium is sometimes gold, with midgrade being silver, IIRC, unless they share a nozzle with regular.) Then you can look at the color and grab. Unless it's a station that isn't conforming to the standards, then you still get the wrong nozzle, so still read.
  15. thunderstruck
    thunderstruck Active Member
    154
    151
    Port Charlotte, FL
    2022 Prius
    Exactly. Look twice, squeeze once. Some places thankfully have dedicated pumps for diesel, although a number of years ago I did see a woman in a Geo Tracker about to put diesel in her car. I stopped her before she grabbed the pump handle.
  16. bhtooefr
    1,396
    1,489
    Newark, OH, USA
    To be fair, as a former diesel owner, stations that have diesel at every pump are amazing.
    Often, stations have diesel on only one pair of gasoline pumps, or in between two pairs of gasoline pumps on one side of the station. And, invariably, at an empty station, someone with a gasoline vehicle will go for the first pump they see, and that'll be one that blocks a diesel pump. Only takes two of those to block both of the diesel pumps, then you have to wait for one of them to finish.
    It's the diesel version of getting ICEd, except not as awful as actually getting ICEd (because you only have to wait 5-15 minutes, not hours, and you've probably got enough fuel to get somewhere else).
    Basically, it's just good fuel station etiquette, before stopping at a pump, to see if you're blocking a diesel pump.
  17. FroggyTaco
    FroggyTaco Member
    211
    59
    Paso Robles, Ca
    That "free" air is mighty expensive when you factor the surcharge per gallon(litre) your paying at the pump. You must certainly could have afforded a nice compressor by now & would be able to adjust
  18. Mendel Leisk
    42,241
    Prices are very steady here, no premium at Chevron. I do use a bicycle pump on a occasion, especially if it's just one problematic tire.
  19. fuzzy1
    10,687
    Not in his neck of the woods. While visiting his Province, I've noticed a very glaring lack of price competition. Every station in town usually has exactly the same price, regardless of brand or no-brand. Except for the Costco in Kamloops, which did post a price 5 cents/liter lower than everyone else.
  20. fuzzy1
    10,687
    I believe this varies by location. Around here, the market is large enough to justify separate tanks for each blend.
