Oh CRAP.....wrong gas
Discussion in 'Gen 4 Prius Care, Maintenance and Troubleshooting' started by ssdesigner, Aug 4, 2016.
  1. alanclarkeau
    alanclarkeau Senior Member
    7,045
    7,593
    near Brisbane, Australia
    Agreed - the worst were a while back, in a couple of country towns, where there was one isolated diesel pump away from the petrol (gas) pumps, away from the sun shelter designed for trucks. The pavement had the remnants of spilled diesel on the ground, the nozzles were greasy.
    Nowdays, with more cars using diesel, and pumps interspersed with the petrol pumps it is much better - but now I've left diesel probably for good, and gone back to petrol. Blame the DPFs (Diesel Particulate Filters) which have been $$problematic$$, I'll stick with petrol.
  2. wjtracy
    wjtracy Senior Member
    11,374
    3,609
    Northern VA (NoVA)
    Dang it, I meant to see if the diesel nozzle fits in today...was down to one pip flashing so I got in a hurry
    alanclarkeau likes this.
  3. Tideland Prius
    16,680
    You do know I'm not from the States, right?
    Ahh I see.
    #43 Tideland Prius, Aug 7, 2016
  4. FroggyTaco
    FroggyTaco Member
    211
    59
    Paso Robles, Ca
    That's good to know & very interesting considering the price premium Chevron & the like charge for their "premium" gas in California. I have seen surcharges as much as .90/gal but more typically around .30/gallon.
  5. thunderstruck
    thunderstruck Active Member
    154
    151
    Port Charlotte, FL
    2022 Prius
    50 cent spread up here on the various grades of gas. By my house this morning it was 2.65, 3.15 and 3.65.
  6. Mendel Leisk
    42,347
    We have typical higher prices for premium gas (which aren't of interest to me), but station-to-station price for regular gas is pretty uniform.
  7. fuzzy1
    10,707
    In this context, 'premium' meant the price differential between competing branded and no-brand stations selling the same fuel grade, not the upcharge for higher octane blends.
  8. Mendel Leisk
    42,347
    That doesn't seem to happen up here. Brand name and independent stations price the same.
    Guess it's not really "up" lol, just over a bit.
  9. fuzzy1
    10,707
    From my map perspective, you are 'up', but your capital of Victoria is less 'up' and more 'over'.
    U.S. border security officers claim special police powers, not held by other police, within 100 miles of the border. That covers my neighborhood which is more than 100 highway miles from the Peace Arch crossing, but barely over 60 air miles from Victoria Harbor. I might live closer to your Parliament than you do.
  10. FroggyTaco
    FroggyTaco Member
    211
    59
    Paso Robles, Ca
    Correct.
  11. Rebound
    Rebound Senior Member
    3,996
    2,645
    Portland, OR
    It doesn't work that way.
    Premium brands, such as Chevron Techron and others, add detergents to their gasoline formulations which definitely help keep your engine cleaned and better-running. But these additives are the same no matter the octane rating.
    The octane rating defines how much resistance the gas has to ignition. In larger, higher-compression engines, you need higher octane to prevent the fuel from detonating (pinging) from the pressure of piston compression. Gas stations have two gasoline formulations, with low and high octane. When you pump the medium grade, it mixes the medium and low.
    It won't hurt your Prius to use a higher octane fuel, but it may slightly reduce your mileage because it may be that some fuel doesn't fully burn. In my limited tests, high octane fuel slightly reduced my mileage. But more tests would be needed to be conclusive about that.
  12. MrMischief
    MrMischief Active Member
    426
    443
    Denver CO
    Is this really true? I've always thought that it is but Shell really advertises their 91 octane (premium here) at the pumps as being better cleaning, but it only says against the competition. However from Shell's website it sounds like their premium has more detergents than their regular. Maybe I'm reading their pumps wrong but I'm sure it shows regular (85 octane), mid-grade (89 octane), then Shell V-Power NiTRO+ for their highest octane (91 octane).
    Shell V-Power NiTRO+ Premium Gasoline FAQs | Shell United States
  13. Rebound
    3,996
    2,645
    Portland, OR
    Oh, I didn't know that they put more detergents in their high oct gas, but if you're at a Shell or other station when they fill the tanks, you'll see they only supply two grades, which are mixed to deliver the intermediate grade.
    I have no idea at all if the additional detergents matter.
  14. bbald123
    bbald123 Thermodynamics Law Enforcement
    386
    275
    Harrisburg, PA
  15. fuzzy1
    10,707
    Previous discussions have suggested that this varies by location. Some places have separate tankage, others mix.
  16. fuzzy1
    10,707
  17. fuzzy1
    10,707
  18. wjtracy
    11,374
    3,609
    Northern VA (NoVA)
    It does sound like Shell is saying more detergents in their Premium (7x minimum). That's a bit of a surprise because for the last decade or so, U.S. oil companies have not been pushing Premium.
    None of my cars need Premium, so I wonder why Shell says 40% of new cars now need Premium? But this potentially represents a "new" marketing strategy, maybe with the 54 MPG CAFE rules we are getting turbo charged cars etc that requires higher octane.
    RCO likes this.
  19. MrMischief
    426
    443
    Denver CO
  20. bhtooefr
    bhtooefr Senior Member
    1,396
    1,489
    Newark, OH, USA
    Do note that fuel economy and performance can take a huge hit in a vehicle where premium is "only" recommended, if you run regular - and that will hold true even in cases where you're driving gently, for automatics, as they'll want to go to higher load, at lower RPM - where the higher octane may well help.
    RCO and wjtracy like this.
  21. wjtracy
    11,374
    3,609
    Northern VA (NoVA)
    Right I agree...as people buy cars that get better MPG, we want to see the 50 MPG or whatever up there in our eyes. We want to get as good MPG as we can get, which EPA and Cons Reports have yet to catch up with that max MPG idea.
