Oh dear! Triangle of Death! No oil! Help!
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by WilDavis, Feb 19, 2020.
  1. Priuslover09
    Priuslover09 Member
    365
    48
    Dc
    If it then Toyota will have to replace the engine.
  2. WilDavis
    WilDavis Senior Member
    2,493
    2,155
    49
    Well, here's an aside from the main thread (which happened last week):
    All seems to be well (…so far!o_O), but I remember that when I got the car to the stealer, the SKS seemed to be flakey, but I was able to get access etc. using the hidden key (in the FOB). On reflection it was pretty cold outside, and I usually have the FOB dangling from a carabiner on my belt, and I had a fleeting thought that perhaps the FOB-battery was getting old, and would you believe in the past couple of days (v. chilly) the SKS started getting flakey once more, so I checked the battery in the FOB (…after I finally remembered how to dismantle it! :rolleyes:) sure enough it was down to 2.92V, so a new battery made it as almost as good as new (I also gave it a good clean!) Looking back through my records I see that I last changed it back in April 2018, so I was surprised that the battery only lasted just under 2 years, but I think it must have been the low temperature! (…just FYI, and don't forget to keep anything which dangles cosy and warm! (…it will work much better - you know it makes sense! ;))
    #62 WilDavis, Feb 28, 2020
    jerrymildred likes this.
