Oh how the mighty Bisco has fallen...
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by bisco, Jul 22, 2019.
  1. bisco
    52,855
    yeah, i think they're either lying or clueless
    Yea Right and Raytheeagle like this.
  2. KennyGS
    KennyGS Senior Member
    1,243
    1,046
    Keystone State
    ...or both. :whistle:
    TGrracie, Raytheeagle and bisco like this.
  3. Salamander_King
    Salamander_King Senior Member
    11,024
    8,978
    New England
    52,855
    it is overkill, if none of your car batteries crank the engine
    Salamander_King likes this.
  5. bisco
    52,855
    there's a guy on youtube, 'mercedessource' who uses a second battery to 'trick' a dead agm that won't take a charge.
    he jumps the agm with another car battery, and puts the charger on the second battery.
    Meg&Bear likes this.
  6. fotomoto
    fotomoto Senior Member
    5,639
    3,815
    So. Texas
    When the battery backup costs more than the battery? Yeah, that's a sign. ;) :D
  7. Salamander_King
    11,024
    8,978
    New England
    OK, that one is overkill for PRIME and other hybrids. I thought larger capacity may come handy if I need it as an emergency power bank to charge other things like laptop or phones, but I do have a smaller battery power bank for that purpose. How about this one. 1/10 of Amps, but substantially cheaper. Would it be big enough for PRIME and other hybrids?
    Tri-State Battery Warehouse : NOCO GB20 BOOST Sport 12V Lithium Jump Starter [GB-20] - $79.95
    bisco and jerrymildred like this.
  8. farmecologist
    farmecologist Senior Member
    1,960
    1,801
    Southern MN
    Interesting...sounds like a similar process to 'jumping' dead tool batteries ( ahem...like the infamous Ryobi One+ batteries ). In fact, I just 'jumped' four of my One+ batteries a couple weeks ago. However, I used my 12V battery charger to do it vs. another battery.
    Meg&Bear and bisco like this.
  9. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,804
    2017 Prius c
    True but having some extra capacity isn't necessarily a bad thing.
    That should handle most any vehicle.....except maybe a big 24V diesel.
    It should handle a situation where the battery is REALLY weak.
    It should still work if you have neglected to recharge the pack for a LONG time.
  10. jerrymildred
    jerrymildred Senior Member
    11,517
    14,167
    Tampa, FL
    That's the one I have but have so far never used. (y)
  11. Georgina Rudkus
    Georgina Rudkus Senior Member
    3,575
    2,603
    Taylors, SC
    That's the point of having it. Like a spare tire, life preserver or fire extinguisher, I prefer that they are NEVER used and gladly throw them out when their service life has expired.
    Prius from Dad and jerrymildred like this.
  12. jerrymildred
    11,517
    14,167
    Tampa, FL
    It's insurance. ;)
    TGrracie and Georgina Rudkus like this.
  13. VFerdman
    VFerdman Senior Member
    1,200
    1,218
    Western Massachusetts
    @bisco, if you have Pep Boys close by, give them a call. They sell a Bosch battery for under $200 and it has a date code and they install for "free". I had good luck with that on my 12V Prius battery adventure.
    Meg&Bear, N.J.PRIUS, TGrracie and 2 others like this.
  14. Rmay635703
    Rmay635703 Senior Member
    2,702
    1,729
    Somewhere in Wisconsin
    2013 Chevy Volt
    The key with an agm is to find out its weak before it fails or you dry out and blow separators ruining the battery.
    Normally a weak AGM is just dried out, turn it on it’s side an hour then upside down a half hour then trickle charge using a dumb charger for a few hours to see if the voltage starts stabilizing.
    I drilled holes an added a few teaspoons of acid to 2 failing AGMs restoring them.
    If the batteries free it’s worth a few experiments but it’s really just for fun.
    My Honda Insight I just use a $19.99 lawn mower battery and replace every 2 or 3 years.
    Meg&Bear, N.J.PRIUS and bisco like this.
  15. bisco
    52,855
    looks good to me
  16. bisco
    52,855
    looks like they have one in dedham, $200. or $150. if i order online, thanks! (y)
    VFerdman and Mendel Leisk like this.
  17. bisco
    52,855
    i usually just recycle them, what method do you use?
  18. sam spade 2
    7,035
    2,804
    2017 Prius c
    I don't think you can support that statement.
    Since a "real" AGM is fully sealed, how do you figure the "water" is going to get OUT ??
    Hint: it won't unless subjected to EXTREME conditions which will upset the chemistry too.
    Trying to "rejuvinate" a completely dead and/or dry battery is a fools errand.
    It just isn't worth the trouble.......and some of the "procedures" can be dangerous too.
    Meg&Bear and Georgina Rudkus like this.
  19. VFerdman
    1,200
    1,218
    Yes, and they'll install it without loosing your radio presets :) (they have a thing)
  20. Diemaster
    Diemaster Active Member
    301
    264
    so. cal
    Bisco, Im surprised you dont know this but AAA has a battery service. the one in my truck died (from a bad alternator, but thats another story) they came out and swapped it out. all i had to pay was the battery it's self, about $130 with tax. (the truck battery is physically larger than the Prius one so maybe the Prius one will be cheaper?
