Oh... OOHHHH... OH Shoot...
Discussion in 'Fred's House of Pancakes' started by amm0bob, May 8, 2010.
  1. Rokeby
    Rokeby Member
    3,033
    710
    75
    Ballamer, Merlin
    Merda!
  2. amm0bob
    amm0bob Permanently Junior...
    7,730
    2,547
  3. amm0bob
    7,730
    2,547
  4. amm0bob
    7,730
    2,547
  5. amm0bob
    7,730
    2,547
  6. amm0bob
    7,730
    2,547
  7. amm0bob
    7,730
    2,547
  8. Rokeby
    Rokeby Member
    3,033
    710
    75
    Ballamer, Merlin
    Has a goal been scored?
    Soccer; The Rules of the Game
    Rule 16 - The Goal Kick
    A goal kick is a method of restarting play.
    A goal kick is awarded when the whole of the ball passes over
    the goal line, either on the ground or in the air, having last
    touched a player of the attacking team, and a goal is not scored
    in accordance with Law 10.
    A goal may be scored directly from a goal kick, but only against
    the opposing team.
    How is play restarted?
    If the ball had curved back and crossed over the end line, but
    not into the goal, how is play restarted?
  9. Trebuchet
    Trebuchet Senior Member
    3,772
    936
    43
    2 people like this.
  10. Politburo
    Politburo Active Member
    971
    208
    It's a goal, I think. There doesn't seem to be a definitive answer, though.. some people think the ball is in play once it crosses out of the penalty area, some think that it needs to be touched to restart play. The 'procedure' section on the FIFA website says it's when it goes out of the penalty box. I can't tell if that's formally part of the rule or informal guidance.
    Further confusing things is the use of "attacking" and "opposing", as the team each term refers to flips halfway through the rule (or doesn't.. it's not clear!).
  11. Trebuchet
    3,772
    936
    43
  12. sdtundra
    sdtundra Senior Member
    1,314
    194
    Sacramento, CA
  13. Rokeby
    Rokeby Member
    3,033
    710
    75
    Ballamer, Merlin
    I think no goal was scored. After reading the Rules of the Game, here's my take:
    As to whether a goal was scored, the key seems to be in this sentence:
    the opposing team.
    "Directly" means not having been touched a second time by a player.
    Also, the ball is in play after it passes directly out of the penalty area.
    That raises the matter of was the ball ever properly in play.
    For the sake of simplicity, let's say the ball did not pass out of the penalty
    area as it was turned by the wind. The ball was not in play. A goal was not
    scored and the goal kick would be retaken.
    Now let's look at the ball having passed out of the penalty area and in play.
    By all appearances, despite his trying to stop the ball, the goalkeeper did not
    touch the ball. So, the ball entered the goal directly. But as noted above, an
    own-goal cannot be scored directly on a goal kick.
    Had the goalkeeper touched the ball, the ball would have entered the goal
    indirectly and a goal would have been scored.
    Because the ball was last touched by the goalkeeper and then crossed the goal
    line and a goal was not scored, play would be restarted with a corner kick.
    Had the ball seen in the video crossed the goal line outside of the goal, again
    because it was last touched by the goalkeeper, play would be restarted with a
    corner kick.
  14. Politburo
    971
    208
    The rule doesn't say that an own goal can't be scored on a goal kick, as it doesn't use that term. It's not clear what team is being referred to by "opposing team" in the rule there. Earlier in the rule, "attacking team" is used to mean the team that kicked the ball out. So one could believe that "opposing team" means the team now taking the goal kick. Or one could argue that the context flips because possession changes, and now the goal kicking team is "attacking". I lean towards the former because it is more consistent. It also makes more sense from a gameplay perspective. Because when you really think about it, why shouldn't you be able to own goal on a goal kick? If you're that dumb to kick it 30' in the air with gusting winds, you should suffer the consequences.
    Note that if the GK had touched the ball, it would have been an infraction because you can't be the first person to touch the ball after putting it in play (same goes for throw-ins.. you can't throw-in to yourself). The result would be an indirect free kick.
  15. amm0bob
    7,730
    2,547
  16. amm0bob
    7,730
    2,547
  17. amm0bob
    7,730
    2,547
  18. amm0bob
    7,730
    2,547
  19. amm0bob
    7,730
    2,547
  20. SPEEDEAMON
    SPEEDEAMON Professional Car Nut
    1,556
    606
    Los Angeles
