Oil Analysis, Redline D6 ATF 30k miles
Discussion in 'Gen 3 Prius Technical Discussion' started by TheChip, Oct 22, 2018.
  1. edthefox5
    edthefox5 Senior Member
    10,096
    4,840
    Clearwater, Florida
    I was replying to Grid that engine oil with ZDDP damages the converter. Redline oil touts a ZDDP package that really helps with the valve train noise on my G2.
    But this thread is ridiculous.
    m.wynn and Raytheeagle like this.
  2. Raytheeagle
    Raytheeagle Senior Member
    11,269
    15,530
    Bay Area, California
    2019 Prius Prime
    See what happens when you delve outside of the Gen2 threads:p.
    m.wynn and edthefox5 like this.
  3. Mendel Leisk
    42,383
    I doubt there's any 3rd gen without EGR clogging. More likely just different degrees of owner complacency, and it is something that is a lot easier to deal with earlier than later.
    m.wynn, mjoo and Raytheeagle like this.
  4. TheChip
    TheChip Senior Member
    388
    1,211
    Misissippi
    I agree. There are a lot of people in here upset that someone is doing something out of the ordinary.
    I'm just stunned that we're being argued with that there is any quality difference between motor oils. And somehow the argument is "Well none of my cars had the engine blow up so they're all the same!" Simply stunning.
    I guess we need to get in touch with stock car and formula one drivers, because they've been paying too much! Might want to get some WS in those transmissions too!
    The only way I can understand the argument is if you're trying to say there's not a huge difference between top tier synthetic oils changed at the proper interval while being driven the same. That I can understand. But when you put strain on the car, hit high temperatures or are harsh in any way to the car motor oil does make a difference. I really can't believe we're arguing this, in a thread I posted to show how my redline D6 oil looked.
    The topic at hand is "wow look how great those wear numbers are, and the guy beats up on his car constantly!"
    Instead it's turned into whatever you want to call the above.
    #64 TheChip, Nov 4, 2018
    mjoo, Bill Norton, Threej and 2 others like this.
  5. edthefox5
    10,096
    4,840
    Clearwater, Florida
    Its exhausting.
    mjoo, TheChip and Raytheeagle like this.
  6. TheChip
    388
    1,211
    Misissippi
    In case anyone skips to this page and doesn't want to read the majority of the posts, I've summarized them here.
  7. Bill Norton
    Bill Norton Senior Member
    2,247
    754
    MONW, Ks.
    2019 Prius
    L Eco
    OFF Topic:
    What are the symptoms?
    How bad before you need the cure?
    What's the best thread on this subject?
    Thanks, I'm new to this subject....
    Mendel Leisk and Raytheeagle like this.
  8. Raytheeagle
    11,269
    15,530
    2019 Prius Prime
    Typical symptoms I have experienced are a reduction in mpg when on a defined route. I have seen as much as 4 mpg reduction when traveling to and from work (38 miles one way) that I have been doing for almost 5 years now. You’ll also see the ice requiring more use on hill climbs (I have one significant one on my work route and when I have to constantly put the pedal to force it into the PWR range I knew something was up).
    I’ve done the egr circuit cleanse twice to our 2010 and have done the job 6 times overall. The cooler at 120 k miles was caked and I consume a quart of oil every 5 k miles. At 173 k miles, the cooler was just as bad, so I’ve determined for our situation that every 50 k miles seems about right for the egr circuit cleanse.
    Hope that helps.
    Robert Holt, Grit, m.wynn and 2 others like this.
  9. Mendel Leisk
    42,383
    There's several threads but this one is the most trodden I think:
    EGR & Intake Manifold Clean Results | PriusChat
    As to symptoms: it's probably best to get ahead of them, pretty much all 3rd gen EGR's clog. A relatively easy check is to remove the connector pipe between EGR valve and intake manifold, see what it's inside looks like. If it's moderately carbonned up, then the EGR cooler is likely due for cleaning.
    I cleaned ours very early, and I get the sense it's progressively harder to clean, in particular the cooler, the more clogged it is. Maybe for sure clean it by 100K miles?
    The car will display warning lights and code P0401, but this is usually when the EGR system is REALLY clogged.
    @NutzAboutBolts has done video's on the pipe check and a full EGR clean, pinned in the 3rd gen maintenance forum.
    Grit, NutzAboutBolts and Raytheeagle like this.
  10. Bill Norton
    2,247
    754
    MONW, Ks.
    2019 Prius
    L Eco
    Just looked at the video. Lot's of work but no parts required! Maybe a cup of collant.
    Only,, I don't see any info about 'Symptoms'.
    I'm at 182k miles with this '11 Gen3 I just bought and it runs great and seems to be getting very good fuel and oil mileage.
    How bad is it to wait for the light and code?
    (I didn't get into the thread you linked, but thanks for the help !)
  11. Mendel Leisk
    42,383
    Yeah have a read through the thread. When I did ours, at the outset I drained 2 liters of coolant, at the radiator drain spigot, into a clean container. That dropped the level of coolant to be below the EGR system, so no need to clamp hoses, and zero spills. You just need to be careful: lift the cooler out without tipping, there's a wee bit of coolant trapped in the back corner. You can pour it in with the rest that you've drained.
    When you're done, all the hoses reconnected, pour coolant back into the reservoir. Maybe burp the main hoses a bit has you go. You can also leave the coolant vent screw open (2010, 2011 model years), or leave the topmost hose loose (2012 on), until coolant reaches that level. The reservoir level will likely end up slightly high, but will settle with a day or two driving.
    Clamping the hoses is a bit absurd anyway: you clamp the hoses that run into the cooler, disconnect them, and the all the coolant in the cooler promptly drains out.
    I'd highly recommend to do the intake manifold cleaning too. It tends to act as unofficial Oil Catch Can for the PCV circuit, and also is the final leg of the EGR gas circuit.
    And while the intake manifold is off is an easy time for OCC install...
    Oil Catch Can, Eliminate that knock! | PriusChat
    Take the aforementioned EGR pipe off (there's a @NutzAboutBolts video on just that removal), see how it looks. That's an easy exercise, about an hour. The main symptom? you have a gen 3 with 182K miles, lol.
    #71 Mendel Leisk, Nov 5, 2018
    m.wynn likes this.
  12. Grit
    Grit Senior Member
    6,577
    4,231
    Wilkes Land
    Thats how we do it here.
  13. Bill Norton
    2,247
    754
    MONW, Ks.
    2019 Prius
    L Eco
    Thanks again for all these helpful pointers!
    I understand the usefulness of an Oil Catch Can. I had a 2 VW TDI's before getting my first Gen3.
    So I understand intake manifold/EGR valve cleaning... Yuk with the TDI's.:confused: You never saw clogging like those get.
    How about a self-supported FIRE cleaning of an intake manifold?!! Just the first 2 minutes shows how it's done!
    But, again,,, What are the symptoms? What do you experience before you eventually get the light and code?
    (I drive a BEV. 58k miles so far. I should open the hood someday and add washer fluid. But I don't like working on cars even that much anymore....;))
    I am capable of doing all this work on the fabulous Gen3 I just bought. But I'm not going to do it without cause.
    It had a great service record. But, maybe the previous owner had this work done by an independent shop and it's not on Toyota's service history. Know what I mean? I don't want to get into it and find it didn't need the work.
  14. Raytheeagle
    11,269
    15,530
    2019 Prius Prime
    How many miles on your Prius?
    Are all of these records from a dealer?
    Did you meet the previous owner?
    Were they the DIY type?
    If above 100k miles and only dealer service records, it’s safe to assume that the egr circuit has not been addressed. The previous owner probably also believed in the “closed hood” philosophy for maintenance. Cause the dealer maintains it, they would let me know when something is wrong:rolleyes:.
    As @Mendel Leisk said, you can pull the egr pipe and see a glimpse of the situation.
    Good luck (y).
    Mendel Leisk and m.wynn like this.
  15. m.wynn
    m.wynn Senior Member
    684
    1,230
    Queensbury, NY
    Sometimes repeated cold start knock, real cold start knock where it seems like the engine is trying to jump out of the engine bay.
    Sometimes
    a slight shudder during light, gas engine involved acceleration, from mid-teens mph thru mid-20s or so. Feels like the road has a high-frequency washboard pattern to it.
    Sometimes
    reduced mpg as Ray reports.
    Sometimes
    P0401, but I personally feel this one is overplayed and only happens in some cases. Complete blockage within the intake manifold and complete blockage of the cooler can and do occur without the valve and it's sensor ever knowing there is an issue. No cel, no code. This may even be the case in the majority, in my opinion. Also, the popular Priuschat test of "checking the EGR pipe for blockage" is a marginal test, again in my opinion. The pipe, and the EGR valve rarely (if ever?) show complete blockage. It's the intake manifold and/or the cooler which block completely. You may march to your blown head gasket with no symptoms whatsoever. It will be popular opinion around here that at 180k+ miles, you're well on your way, and somewhat lucky you're not already there.
    Okey doke.
    That's a definite maybe. Only a handful of Priuschatters have an awareness of this being an issue. Well, maybe dealer techs (they likely aren't talking too much about it, in my opinion) and higher level, honest Toy indy's, such as Carspec:
    EGR circuit concerns from a Toy indy shop | PriusChat
  16. Bill Norton
    2,247
    754
    MONW, Ks.
    2019 Prius
    L Eco
    So you're saying a blown head gasket will be the result of not having the normal amount of exhaust gases mixed in with the intake flow?
    How would that be explained?
    Some say the head gasket is just the weak link on really high mile Gen3's.
    I once heard the 'cold start knocking' on my previous '10 Gen3. I chalked that up to driving slowly around town on a rainy day and never getting the engine thoroughly warmed up. At the time I read about an updated intake manifold design to prevent that. And I didn't know about EGR clogging as an issue. That Gen3 had less miles than this one.
    (That car gave me a taste of limited EV driving. Sold it and for a Volt, which gave me a taste of Real EV driving.
    Sold it for a Chevy BEV,, the 82 mile one. This '11 Gen3 is for the GF and to have a good road trip car.)
  17. mjoo
    mjoo Senior Member
    1,163
    1,334
    Michigan
    The allam power cycle is an extreme example. It's a new type of engine used by power companies that uses fuel, pure oxygen (3%), and 97% EGR. Because of the immense use of EGR this engine achieves 59% thermodynamic efficiency, generates no NOX, and eliminates catalytic converters . If we were to run an engine on pure oxygen without any EGR the engine would explode into puddles of liquid metal.
    In comparison, the Gen 3 Prius engine was designed to run on 21% EGR and has a thermodynamic efficiency of 38%.
    #77 mjoo, Nov 6, 2018
    Mendel Leisk, m.wynn and Raytheeagle like this.
  18. Simtronic
    Simtronic Active Member
    290
    116
    Surrey, UK
    2017 Prius PHV
    Business Ed. Plus
    I run Pentosin ATS-1 LV does that mean I will have even better fuel economy? My old Prius (now my sons car) has 300K on it and never had WS put in
    m.wynn likes this.
  19. m.wynn
    684
    1,230
    Queensbury, NY
    Yes sir.
    Way high cylinder temps from lack of, or zero flow of exhaust gas to combustion.
    Yes, they do, and they may be correct. But they may be incorrect. So personally, I feel looking after the EGR circuit makes the most sense. If they're right, I've wasted my time tending to it and will be doing a head gasket job regardless. But if they're wrong;)... I don't imagine Toyota will ever be telling us why the turd gen Prius blows head gaskets, but who knows?..
    Your story is indeed one of the likely ways to induce an isolated cold start knock. An extreme overnight temperature swing with a big change in barometric pressure is another. Firing a cold gas engine up and shutting it immediately down (cold soak) is another. The updated IM may or may not help the isolated cold start knock issue. My opinion from reports I've read here is that it's inconclusive at best, with a lean toward it really doesn't help at all. Isolated cold start knock is a turd gen fact of life and a non-issue, imo.
    Raytheeagle likes this.
  20. Mendel Leisk
    42,383
    You know we all seem to be getting along just fine right now. Maybe we need Fred's House of Alternate Transaxle Fluids? :whistle:
    Raytheeagle and m.wynn like this.
