Oil battle revisited GF4/GF5
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Jay J, Nov 24, 2012.
  1. Jay J
    Jay J Active Member
    469
    253
    Torrance, CA
    So I know the only readily available full synthetic off the shelves is the 0W30 Castrol (German Car Formula).
    There's also Redline and Amsoil.
    What about using LAT based oils?(that stuff is in there forever) even if you change the oil on next R&R you can see it draining out.
    Any advantages to using real synthetic fluid?- Has anyone sent their oil to blackstone?
    Since the OEM Toyota 0W20 isn't full synthetic as far as I know??-
  2. Former Member 68813
    3,524
    983
    US
    Seriously, have you tried to search?
    What is LAT?
  3. Jay J
    Jay J Active Member
    469
    253
    Torrance, CA
  4. RRxing
    RRxing Senior Member
    2,563
    1,842
    NEPA
    Toyota 0W-20 is a full synthetic oil, whether made by Nippon (originally) or Mobil (currently.)
  5. Former Member 68813
    3,524
    983
    US
    "LAT based oil" sounds like LAT is a type of base oil. Apparently it isn't and you misspoke.
  6. Jay J
    Jay J Active Member
    469
    253
    Torrance, CA
    Is Toyota 0W-20 SN made in heaven? - Bob Is The Oil Guy
    They're saying Subaru is the closest to GF5, and those that are into rotaries or high power high strung engines know that LAT oils stick to metal like no other, even after a R&R with another fluid you can still tell LAT exists/or has existed in that engine.
