Oil Burning :(
Discussion in 'Gen 3 Prius Main Forum' started by fustion, Dec 15, 2017.
  1. orenji
    orenji Senior Member
    5,887
    3,488
    1.8 motor and 4,000 RPM is thrashing these motors.
  2. taxidriver50005
    taxidriver50005 Active Member
    204
    170
    GB
    Excel
    4,000rpm is not high rpm for a petrol engine
  3. FnRedPrius
    FnRedPrius Active Member
    100
    121
    Pilot, NC
    How many RPM for 116 MPH? That's what hers will run. :sneaky:
    taxidriver50005 likes this.
  4. orenji
    5,887
    3,488
    Really?! It is for a small 1.8 motor.
  5. taxidriver50005
    204
    170
    GB
    Excel
    OK then show me another 1.8 that only revs to about 4,000 RPM lawnmowers are exempt.
  6. taxidriver50005
    204
    170
    GB
    Excel
    From what I can see you guys in the states seam to be reporting more oil burning problems than most, from what I can see you also are only now switching to low sulphur fuel unlike us in Europe who have been using it for decades..... Could this be causing the sticking ring problems.?
  7. Doug E.
    Doug E. Junior Member
    East Troy
    USE Conventional motor oil. Not Synthetic. Or at least use Semi Synthetic. my 2010 after switching to Conventional old fashion oil does not burn as much. Almost no oil burn. I use 5w-20 from amazon.
  8. Tim Jones
    Tim Jones Senior Member
    1,762
    569
    SE Texas
    2011 Nissan LEAF
    My 2013 v has 240,000 i run Rotella T6 10w 40 and it doesn't use a drop between 4 to 5000 mile changes.
