Oil Burning
Discussion in 'Gen 3 Prius Fuel Economy' started by Ted in Olympia, Dec 11, 2010.
  1. Former Member 68813
    3,524
    983
    US
  2. DaveinOlyWA
    15,140
    611
    South Puget Sound, WA
    2013 Nissan LEAF
    I have an old Corolla that uses oil. Have not paid that much attention to how fast it uses oil so I say roughly a quart every 1000-1500 miles or so but the option to run to the dealer for things like this since it could mean an expensive repair that does not qualify under the warranty.
    by design, most cars "should" burn oil but most new ones burn it so slowly that its not that easy to tell. In my Priuses, none burn oil fast enough to warrant adding any between changes.
    and yea, a quart every 600 miles is very extreme in my opinion and I would start looking for signs of leakage. burning it at that rate is likely to produce a pretty hefty cloud at start up every time the car has sat for any length of time
  3. Former Member 68813
    3,524
    983
    US
    Yes, for oil seals failure.
    No, for oil ring failure.
  4. Mendel Leisk
    42,361
    Toyota's oil burning disclaimer in the Owner's Manual is pretty sad. That said, we're not consuming any, as far as I can see, around 4 years and 48000 km's.
    That's something new for me: for decades with Hondas, it was pretty much the norm to be down close to 1/2 quart every 6000~8000 km's.
  5. Sherry Laible-White
    Sherry Laible-White New Member
    1505 Kelsey St. Washington Il
    1796 miles driven & needed a quart at mileage 137998. So not over this!
  6. Mendel Leisk
    42,361
    There is a Technical Service Bulletin, two actually. The first is an oil consumption test. And if you "pass" the first, the second, basically an instruction to remove the engine, partially disassemble it, and replace the pistons and piston rings, with revised parts. I'll attach those two documents.
    The threshold for consumption in the first TSB is 1 quart per 1100~1300 miles.
    Of interest: 2014 model year has the revised pistons, and 2015 has both the revised pistons and rings:
    Text version:
    piston ring
    2010 13101-37120 13011-37110
    2011 13101-37120 13011-37110
    2012 13101-37120 13011-37110
    2013 13101-37120 13011-37110
    2014 13101-37240 13011-37110
    2015 13101-37240 13011-37260
