Oil cap becomes oily
Discussion in 'Gen 3 Prius Technical Discussion' started by Blurredforlife, Aug 10, 2021.
  1. Blurredforlife
    Blurredforlife Junior Member
    75
    Chicago
    I've noticed after driving on long trips that my oil cap has a oily film on it. Its just the cap
    ...nothing else has oil on it. I wipe it dry but after a few weeks it comes back. Ive Google and searched but to no avail. Anyone have any suggestions or has had the same problem?
  2. ASRDogman
    ASRDogman Senior Member
    8,055
    4,083
    Replace the cap. About $10 from Toyota.
    The seal is bad and you cannot get just the seal.
  3. jzchen
    jzchen Newbie!
    3,316
    1,022
    Arcadia, CA
    Inside the cap or outside the cap? I used Blue Devil Pour and Go and the oil cap on the car started leaking. It leaked out the seal. The Blue Devil warped the seal. I replaced the oil and cap and no more leaking out….
    Blurredforlife likes this.
  4. PriusCamper
    PriusCamper Senior Member
    13,440
    5,426
    Pacific Northwest, USA
    Please clarify if you're talking about outside of cap or inside of cap? And if outside of cap any visible damage to the seal?
  5. Colorado Boo
    Colorado Boo Active Member
    307
    202
    Monument, Colorado USA
    2021 Prius
    LE AWD-e
    A 9-year old car? Yep, there's a rubber seal inside of the oil filler cap you can replace for about $6. (I just did in my Tundra) For Prius, should be part # 90080-43025. When you replace it, the new one will have one smooth side and one side with a thin, raised edge...this is the outside edge, that seals it to the car.
    Blurredforlife and burrito like this.
  6. ASRDogman
    8,055
    4,083
    I tried 3 different Toyota dealerships, and even online. No one had that seal.
    They all said you can only get the cap with the seal. But since the cap was only $10, I think it was worth it.
  7. Mendel Leisk
    42,315
    Excessive back pressure? How many miles? Check the PCV valve?
    jzchen likes this.
  8. Blurredforlife
    75
    Chicago
    Outside the cap
  9. Blurredforlife
    75
    Chicago
    Had a new one installed last fall
  10. Blurredforlife
    75
    Chicago
    Thanks for the info
  11. Blurredforlife
    75
    Chicago
    I looked at the cap...didn't see any warping or damage
  12. jzchen
    jzchen Newbie!
    3,316
    1,022
    Arcadia, CA
    You're not using a stop leak nor high mileage oil are you? Should be warrantable within a year? (Take it in and get a free replacement)...
    Our Porsche cap is okay with Lucas version but absolutely not Blue Devil...
    moto g(7) power ?
  13. Blurredforlife
    75
    Chicago
    I do use high mileage oil
  14. Blurredforlife
    75
    Chicago
    I didn't see anything which has me stumped
  15. jzchen
    jzchen Newbie!
    3,316
    1,022
    Arcadia, CA
    Please specify which oil you are using? If I'm not mistaken Toyota recommends ILSAC rated oils and for some reason some high mileage oils aren't ILSAC rated. Change the oil to a different high mileage, and the cap, then observe.
    moto g(7) power ?
