oil cartridge falling apart?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by GasSaver1, Jan 5, 2014.
  1. El Dobro
    El Dobro A Member
    7,106
    3,282
    I would imagine the Wix filter is sealed the same way.
  2. Mike500
    Mike500 Senior Member
    2,593
    767
    The so called "glue" on the end is more like a thermo plastic elastomer.
  3. gliderman
    gliderman Active Member
    751
    225
    TPE or not, its sealing the end.
    El Dobro likes this.
  4. Mr.Electric
    Mr.Electric Member
    287
    106
    San Francisco
    I talked to a high level mechanic yesterday about my habit of using the wrong oil in my prius. He said too thick oil would make the vvti system chatter and wear my timing chain and oil pump more quickly. I dumped the oil and refilled with 0-20w. He said that if 5-20w and other oils were ok to use the writing on the oil cap would say "any oil" not " 0-20w" .
  5. El Dobro
    El Dobro A Member
    7,106
    3,282
    More and more vehicles are going over to 0W-20. Many of the new GM are.
  6. Mendel Leisk
    42,386
    I do not know. I've used 0W20 consistently, but doesn't the oil spec vary around the world. Australia for instance, I think their Owners Manual recommends a wider range of oil weights.
    I suspect the main reason for 0W20 is to improve mpg, get them a better rating.
