Oil Catch Can, Eliminate that knock!
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by danlatu, May 22, 2017.
  1. StarCaller
    StarCaller Senior Member
    1,284
    733
    Cedar Crest, NM, USA
    homedepot hoses work perfect/
    amos likes this.
  2. Mendel Leisk
    42,349
    I cut the original hose, and spliced in new hose with whats called a "barb splice". They don't call them barb for nothing: they're almost a permanent connection, it's very hard to coax a hose back off them, if you change your mind about anything. What I did was knock the edges off the "barb" with a flat file, and also put a sparing amount of silicon dielectric compound on it.
    The hose I splice in was supplied with the OCC, I believe it's fuel line. The only thing: Moroso kind-of cheaped out, only supplied about 3'. 6' would be nice, for more flexibility, if you want to mount for access from above. The label on it says:
    SAE-30R7 - KX078698508818 - MADE IN U.S.A. (and a numerical date)
    @danlatu says it doesn't really matter if the OCC is higher or lower than the original plumbing, but still, I've got a hunch if the detour is downward about 8", then down through a labyrinth, around the underside of a baffle, up through another labyrinth, then up another 8" of hose before it's back on the on regular path, gravity maybe helps.
    Addendum: added red portion of hose label, missed it earlier.
    #182 Mendel Leisk, Oct 2, 2017
  3. Mendel Leisk
    42,349
    Did you use the original for the end at the intake manifold, where it flares out to bigger diameter? Is it 3/4", I believe so, but think I neglected to do a careful measurement. I like the concept of using the original hoses, at the original ends, for a few reasons:
    They have the correct inside diameters, both ends, no problem there. They have elbows. The have nice clips, easy to pull back, easy to then pull the hoses off. I wouldn't mind having similar spigots at the OCC and at the splices. Much easier to work with than those #%*! hose barbs.
  4. RMB
    RMB Senior Member
    406
    642
    Oakland, CA
    I am getting ready to get this done, but need to find the free time first, then arrange to borrow my father in law's shared garage for a day.
    Same OCC as Danlatu's recommendation, $52 from Amazon.
    NutzAboutBolts, Mendel Leisk and mjoo like this.
  5. Raytheeagle
    Raytheeagle Senior Member
    11,269
    15,528
    Bay Area, California
    2019 Prius Prime
    Or if you want to wait until the next meetup (tentatively November 11th), you'll have a garage and plenty of willing helpers(y).
    amos, SFO, RMB and 1 other person like this.
  6. RMB
    RMB Senior Member
    406
    642
    Oakland, CA
    I will try to be at next meetup, needing works on my car or not. Reason I wanna get this OCC done ahead of time is my #2 baby is due in about 3 weeks, I will be super busy afterwards. And knowing a meetup is coming soon, I will have something to fall back on if I cant get this done soon. :D Of course, to attend the meetup, I will have to get a permit from wifey first.
    SFO and Raytheeagle like this.
  7. Raytheeagle
    11,269
    15,528
    2019 Prius Prime
    3 weeks, eh:)?
    If it were 5 weeks you could pull a @mmmodem and attend the day before the birth;).
    We were all surprised Mrs. Mmmodem let him come:whistle:.
    But get permission and not ask for forgiveness in this case;). Let us know if we can help(y).
    RMB, SFO and mmmodem like this.
  8. SFO
    SFO Senior Member
    5,302
    4,251
    Northern California
    Would tell you to just bring the baby, though it might be even harder to get that permit :cautious:
    Guessing 80% of past meetup attendees currently have (or have had) babies within the last 18 years, but I could be off by 10%.
    Of course @mmmodem is the man with all hands on deck at this point, and most likely has all the gadgets and gizmos to get the party started :sleep:
    RMB and Raytheeagle like this.
  9. RightOnTime
    RightOnTime Senior Member
    791
    1,660
    183
    Kidnapped in OC, CA
    Very good thread!
    Raytheeagle likes this.
  10. RightOnTime
    791
    1,660
    183
    Kidnapped in OC, CA
    Here is my contribution to this thread! Been looking at this method for over 1year and find it interesting.
    Feedback or Input?
    amos and m3pare like this.
  11. Mendel Leisk
    42,349
    Not sure. What about the hose between PCV valve and intake manifold, any mod there?
    RightOnTime likes this.
  12. SFO
    SFO Senior Member
    5,302
    4,251
    Northern California
    Find it confusing.
    Why is there a white "one-way" arrow from the T-Rex device pointing into the intake and then another red arrow pointing into the crank case?
    And why isn't the PCV shown as a one-way?
    RightOnTime and mjoo like this.
  13. mjoo
    mjoo Senior Member
    1,163
    1,334
    Michigan
    @RightOnTime:
    If the red arrows are correct in your check valve diagram, this would force more air through the PCV valve. It would create more oil loss by forcing more oil mist through the PCV. We're trying to keep our intakes clean by removing oil mist.
    Besides this is an "Oil Catch Can" thread. I don't see an OCC in this diagram.
  14. RightOnTime
    791
    1,660
    183
    Kidnapped in OC, CA
    Just throwing it out there.
    This unit is specific for the Gen 3 & Gen 4 Prius which is researched and designed in Japan.
    Yes, this may be an 'Oil Catch Can' thread - just 'thinking outside the Box' and was wondering if this was a better version.
    I have seen this piece on several cars in Japan and thought that we in the States might be a couple of steps back of keeping our intakes clean by removing oil mist.
    Just remember that in Japan they have a bunch of time and resources in R&D to produce many parts for the Prius that is not found in the States.
    Will keep everyone updated if i find more info.
    Btw - this thread is awesome!!
    iPhone ?
    Juntuner and SFO like this.
  15. Mendel Leisk
    42,349
    So you're doing nothing to the lower circuit, between PCV valve and intake manifold? The consensus is that lower line is where the majority, if not all of the oil is coming from.
    mjoo, StarCaller and RightOnTime like this.
  16. StarCaller
    1,284
    733
    this^
  17. mjoo
    mjoo Senior Member
    1,163
    1,334
    Michigan
    What you posted is snake-oil. Please post that in your own thread.
    #197 mjoo, Oct 4, 2017
  18. StarCaller
    1,284
    733
    kinda steep neway....
  19. RightOnTime
    791
    1,660
    183
    Kidnapped in OC, CA
    Price is a bit steep
    iPhone ?
  20. RightOnTime
    791
    1,660
    183
    Kidnapped in OC, CA
    Prius Chat is all about sharing thoughts and ideas. Thought I throw something out there.
    To each his own my Friend
    iPhone ?
    Juntuner, Burna J, danlatu and 3 others like this.
