Oil Catch Can, Eliminate that knock!
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by danlatu, May 22, 2017.
  1. Abu Rais
    Abu Rais Member
    58
    42
    Houston, Texas
    I really want to install OCC but I after reading 12 pages I'm still not sure how to put it together and don't know how The line will connect from the PCV valve to the OCC.
    definitely I would like to install that while I am in there to clean the egv cooler.
    Can someone post a link or tell me exactly what I have the parts needed to put this together so I can go ahead and order the parts.
    Most of the work I do after watching the videos so this one without the videos making me nervous.
    Thanks in advance for everyones contribution.
  2. Mendel Leisk
    42,351
    Something like this?
  3. Prodigyplace
    12,715
    11,848
    Central Virginia
  4. Mendel Leisk
    42,351
    You could theoretically eliminate the original hose, but there's a wrinkle: it's 3/8" ID at the PCV valve, and maybe 3/4" ID at the intake manifold, it flares out at the latter. I might still do that, if I could find some sort of adapter. But anyway, just cutting the original hose at the middle, you have two nice elbows.
    SFO and mjoo like this.
  5. Abu Rais
    Abu Rais Member
    58
    42
    Houston, Texas
    Thanks for the diagram. So it means I can still keep the original lines. Need to cut them in the middle and insert them into the new OCC.
    Do I need any adapter to insert them at the OCC.
    Do you think the original line will work if I cut it in the middle?
    Which OCC need to order. I already saw many of them on the entire thread and I think 1st post OCC is reasonably priced compare to the rest.
    Also if I use the original lines can I access the OCC easily? How often do I need to clean it?
    What are the mounting options with the use of stock lines?
    Sorry to ask so many questions. I am trying to do it right because I really need my Prius.
  6. Abu Rais
    Abu Rais Member
    58
    42
    Houston, Texas
    Is this is the origin of lines that was in the car and you cut them in half?
  7. Mendel Leisk
    42,351
    Look at my last picture. I've retained the original hose (cut in half) and added extension to each, with 3/8" brass hose barb and airplane clamps. The extension is a 3/8" ID rubber hose fuel line that was supplied with the OCC I bought. It's really up to you though: you can use just replacement 3/8" hose EXCEPT the spigot at the intake manifold is bigger, I think 3/4" ID. It's up to you to address this. For now I opted to go per the picture, keep the original hose at the two original connection points.
  8. Abu Rais
    Abu Rais Member
    58
    42
    Houston, Texas
    Where and what size the brass connector in between the black line?
    Where did you purchase the OCC, brass connector and clamps?
  9. mjoo
    mjoo Senior Member
    1,163
    1,334
    Michigan
    3/8"
    Pixel XL ?
  10. Prodigyplace
    12,715
    11,848
    Central Virginia
  11. Mendel Leisk
    42,351
    Thanks all, I'm running out of steam...
    Raytheeagle and kc410 like this.
  12. StarCaller
    StarCaller Senior Member
    1,284
    733
    Cedar Crest, NM, USA
    VERY nicely said...../ ;-)
    BION
    Prodigyplace and RMB like this.
  13. Raytheeagle
    Raytheeagle Senior Member
    11,269
    15,528
    Bay Area, California
    2019 Prius Prime
    Sounds like someone needs a steam catch can:p.
    Prodigyplace, RMB, amos and 1 other person like this.
  14. RMB
    RMB Senior Member
    406
    642
    Oakland, CA
    I think Abu Rais really needs a video tutorial on installing oil catch can, as he stated. ;)
  15. Prodigyplace
    12,715
    11,848
    Central Virginia
    Paging @NutzAboutBolts Video request. Perhaps @Raytheeagle can assist. :D
    SFO and Raytheeagle like this.
  16. Abu Rais
    Abu Rais Member
    58
    42
    Houston, Texas
  17. Abu Rais
    Abu Rais Member
    58
    42
    Houston, Texas
    Check this out: Ruien Polish Baffled Universal Aluminum Oil Catch Can Reservoir Tan...
    Same product as the original 1st post without filter
  18. Prodigyplace
    12,715
    11,848
    Central Virginia
    Isn't the filter what catches the oil? I guess you could use steel wool.
  19. Raytheeagle
    11,269
    15,528
    2019 Prius Prime
    I’m a believer in the KISS principles, so keep it simple;).
    An oil catch can is another “wide spot in the line” or knock out pot to prevent liquid carryover.
    In this thread there is the gambit between the less than $5 and the @Mendel Leisk gold plated model:whistle:.
    I’m a backwoods engineer at heart, so using what I have and not spending a large sum would be my approach if I were to put one on our Prius. Mounting points have been discussed as well as plumbing runs.
    If it were me, I would mount the catch can below the PCV valve to prevent oil collection on the downstream side of the valve. If oil collects there, it is now resistance to the PCV valve functioning properly or getting gummed up faster. So where @Mendel Leisk mounted it made sense to me;).
    Hope that helps(y).
    #259 Raytheeagle, Oct 25, 2017
    SFO, Montgomery, Keithstef and 3 others like this.
  20. Prodigyplace
    12,715
    11,848
    Central Virginia
    I know @Mendel Leisk asked about Gen 4 and I have not had a chance to check on mine with 12K miles. Perhaps @soldierguy could check his 2016 with 80K miles on it.
    Mendel Leisk, mjoo and Raytheeagle like this.
