Oil Catch Can, Eliminate that knock!
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by danlatu, May 22, 2017.
  1. NutzAboutBolts
    NutzAboutBolts Senior Member
    1,756
    1,789
    Bay Area
    still trying to find time lol...
  2. mjoo
    mjoo Senior Member
    1,163
    1,334
    Michigan
    Yeah, I think I'll wait until the power train warranty expires at 60k miles. I'm afraid Toyota will find out about the OCC and then put it in a database. Until then, the PCV valve and intake manifold can be removed and cleaned.
    Oops I thought this was the Gen4 forum.
    Pixel XL ?
    amos and Prodigyplace like this.
  3. Mendel Leisk
    42,364
    Interesting point, about warranty issues. Strange that it should have a bad rap though.
  4. RMB
    RMB Senior Member
    406
    642
    Oakland, CA
    :pWe all probably understand that an oil catch can is being done for good intentions, but still, it is tempering with factory emission equipment, thus can void warranty and fail emission test.
  5. Mendel Leisk
    42,364
    The funny thing is: a non-vented oil catch can does not increase emissions, and promotes engine longevity.
    Montgomery, scona, mjoo and 2 others like this.
  6. RMB
    RMB Senior Member
    406
    642
    Oakland, CA
    I have not install mine yet, but with the Ruien set there maybe couple more items you need before you can tackle this job. I am more of a visual kind of person, so here are some photos with ugly drawing, hopefully this can help while not having a video. IMG_5792.JPG IMG_5878.JPG 126004_IMG_0063.jpg
    AcidSun, danlatu, amos and 4 others like this.
  7. danlatu
    danlatu Senior Member
    533
    1,367
    maryland
    It would not fail emission's through a sniffer test maybe on a visual. That will vary from state to state. These people have no idea what they are doing anyway. There are like the guys @ jiffy lube. Burning oil is not good for emissions or the environment, the catch can traps the majority of the oil before it hits the combustion chamber. I like your drawing RMB :):):)
    I am happy to report that we have 2 prius' with catch cans! I have passed all of my emissions tests.
    2010 prius has 113k miles and no engine knock (ball jar)
    2011 prius has 302k miles and no engine knock
    7k miles
    2.5k miles
    milkman44, Abu Rais, amos and 5 others like this.
  8. Abu Rais
    Abu Rais Member
    58
    42
    Houston, Texas
    Thanks RMB for the drawing.
    I am going to order the OCC. I want to order same as Danlatu but without the vent option. I hope that one works same as the one with filter options on the top.
    Need to look for a mount option and hopefully extra 5 feet of hose will do the job.
    Need to visit ACE hardware for the connector.
  9. Mendel Leisk
    42,364
    I put mine on the lower cross beam, just below the intake manifold and pcv valve. It's really not accessible from above, more intended to be checked during oil changes, with the engine underpanel removed:
    Oil Catch Can, Eliminate that knock! | Page 9 | PriusChat
    Also, I went for an OCC with drain tap, this one's more expensive, but very nicely made:
    (It only comes with about 3' of hose, which is enough for my install location, but probably not if you install to be accessible from the top. Just look below in the link, there's suggestions; you basically want 3/8" I.D. rubber fuel hose. Also, I found the bolts supplied for connection to the circular bracket were jamming, just purchased some 1/4" NC bolts from hardware store, plus 3/8" brass barb splice, plus clamps.)
    danlatu and Abu Rais like this.
  10. soldierguy
    soldierguy Active Member
    108
    245
    Maryland
    I'd love to check, but I just don't see it happening soon. I have some vacation time coming up that I'm actually going to use as a vacation (meaningI'm going to one corner of the world and I'll go back to work exhausted), then a trip for work to another corner of the world right on the heels of that. I'll try to dig up some time and take a look.
    In the meantime, it's Saturday morning and my motorcycles are calling to me. I must answer the call!
  11. Abu Rais
    Abu Rais Member
    58
    42
    Houston, Texas
    PRO 1 Fuel Line Hose 3/8 Inch Inside Diameter X 5 Feet Length NRB/PVCC SAE30R6
    Is this hose from Amazon will work?
  12. Mendel Leisk
    42,364
    Yeah, I think so. Mine, supplied with the can, says SAE-30R7, but I think 6 is fine too, I've seen mention of both. Keep in mind, this hose is designed for gasoline, and in this application it's just air and vapour.
  13. Montgomery
    Montgomery Senior Member
    2,254
    2,244
    Orange County, CA
    Looks like I am an early canidate for the catch can. At around 28.8K, I experienced a rough start twice within the last month. I haven't bothered to look at the throttle body yet. I want to make sure I have hours ahead of me and time off of work just in case.
    danlatu and Raytheeagle like this.
  14. Mendel Leisk
    42,364
    Keep in mind too: 5' length will for sure work for a location nearby to the original hose. But if you're thinking to put the OCC up top, possible locations there are all pretty tight, and 5' might be ok, or not quite. If you could, for example get 10' for $15, I'd be inclined to do that, just so you're ready for anything, and in case you screw up, change your mind, whatever.
  15. StarCaller
    StarCaller Senior Member
    1,284
    733
    Cedar Crest, NM, USA
    on the location I put mine, 10' were ok, but there was pretty much nothing left to wiggle/
    6 feet for each direction would've been perfect/
  16. Mendel Leisk
    42,364
    Heck, that's an OCH (Oil Catch Hose), lol.
  17. Abu Rais
    Abu Rais Member
    58
    42
    Houston, Texas
    Unfortunately I can't find any 10 feet long from Amazon. I saw 25 feet long.
    Can you please share the link for 10 feet?
    Thanks.
  18. StarCaller
    1,284
    733
    go to homeDepot/
    Raytheeagle and Montgomery like this.
  19. Abu Rais
    Abu Rais Member
    58
    42
    Houston, Texas
    Okay. That will work.
  20. Abu Rais
    Abu Rais Member
    58
    42
    Houston, Texas
    In my Maintenance scenario I am going to clean the EGV cooler and replace the coolant from the inverter and engine.
    So should I drain both of them and then clean the EGV cooler. Once all of the cleaning done then refill the inverter and coolant reservoir.
    I am trying to understand the sequence of doing it.
    Last Saturday car have Check Hybrid System and then went away by itself. Last night engine was vibrating while driving 50 miles. Then I hit hard on gas and it went away.
    This morning no sign of that knock from last night.
    Really nervous about the car. Hopefully it's not the end of my Prius.
