Oil Catch Can, Eliminate that knock!
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by danlatu, May 22, 2017.
  1. 04priusnow
    04priusnow Active Member
    345
    201
    I kept having odd fumes after the catch can install.. tracked it down to the hoses i used. Found this info on a different site ...SAE 30R7 tubing has a high permeation and is not recommended on vehicles newer than 1985. Gates states that the 30R7 is 37 times higher than 30R9. Gates claims 30R9 meets the California CARB standard and is below 15 grams per meter squared per day, putting the 30R7 around 550 g/m2/day. I have ordered some gates Barricade fuel line that is one of the lowest permeation hoses available at 1 g/m2/day, so I'm hopeful that this will permanently resolve this issue.
    Nexus 6 ?
  2. Mendel Leisk
    42,354
    Strange. I've got 30R7 hose, didn't notice anything. My setup is below intake manifold though, not near cabin air intake. The hose was supplied with my OCC, made in USA FWIW.
  3. 04priusnow
    345
    201
    Mine are also made in USA.. i have it routed to space behind driver side headlight.. i believe its good year brand
    Nexus 6 ?
  4. amos
    amos Active Member
    376
    285
    los angeles
    Can you post a link to that hose you boyght? Thanks
  5. 04priusnow
    345
    201
    #325 04priusnow, Nov 10, 2017
  6. Abu Rais
    Abu Rais Member
    58
    42
    Houston, Texas
    Finally installed the OCC successfully.
    1. Front and rear shocks
    2. Cleaned Hybrid battery fan
    3. Cleaned intake manifold and new gasket
    4. Cleaned EGV cooler
    5. MAF sensor
    6. New PCV valve
    7. OCC installed
    8. Engine and inverter coolant
    Unfortunately once I turned the car check engine light is on. Here is code on the attachment. P261C short in coolant pump B.
    Anyone familiar with this?
    mjoo likes this.
  7. Abu Rais
    Abu Rais Member
    58
    42
    Houston, Texas
    Car is running fine after all the work but this new check engine light issue need to fix asap.
    How can I tell if the car is overheating?
  8. Mendel Leisk
    42,354
    Give it a few more startups. I had check engine light: 5 or 6 start ups and it went off, didn't return. Hopefully something similar in your case, maybe a momentary poor connection.
    OTOH, could be coolant change related, as I guess you're suspecting.
    Congrats on all your work btw. (y)
    Abu Rais likes this.
  9. mjoo
    mjoo Senior Member
    1,163
    1,334
    Michigan
    Might be some coolant or grease in the water pump connector that's shorting the leads? Try spraying both connectors with electronic contact cleaner
    Pixel XL ?
  10. Abu Rais
    Abu Rais Member
    58
    42
    Houston, Texas
    Can you please share a picture or diagram of those connector connections.
    Thanks again everyone for your patience when I asked so many questions about OCC routing. With all of your help it was a clean install and I followed Mendel install location.
    amos likes this.
  11. Mendel Leisk
    42,354
    Assuming you used MAF cleaner, it'll work for those connections too.
  12. Abu Rais
    Abu Rais Member
    58
    42
    Houston, Texas
    Yes I used MAF cleaner. But I want to which connectors location wise you guys are saying.
  13. SFO
    SFO Senior Member
    5,302
    4,252
    Northern California
    Abu Rais, m.wynn and Raytheeagle like this.
  14. Abu Rais
    Abu Rais Member
    58
    42
    Houston, Texas
    Drove 100 miles or more today. Still check engine light on.
    But I really wanna thank to the guys who came up with OCC idea.
    Prius drives awesome without any noise compare without OCC.
    danlatu, mjoo, RMB and 1 other person like this.
  15. 04priusnow
    345
    201
    Yeah.. with cold weather the occ lets me move my car and not worry about a complete warmup...no more cold knock
    Nexus 6 ?
    danlatu and RMB like this.
  16. Mendel Leisk
    42,354
    That's very expensive hose. And 30R7 is fuel rated. (even 30R6, pretty much the same?)
    Are you sure your first hose was the source of leak? I would test your original setup by seeing if it'll hold vacuum, say with a mighty vac if you have it, or maybe you can jury-rig something with a air pump. I'm suspecting an OCC seal leak.
    #336 Mendel Leisk, Nov 12, 2017
    Raytheeagle and Prodigyplace like this.
  17. Raytheeagle
    Raytheeagle Senior Member
    11,269
    15,528
    Bay Area, California
    2019 Prius Prime
    That is pricey :(.
    You could always pressure it up if you had an compressor. If it has a leak, soapy water will point you to the location ;).
    amos and Mendel Leisk like this.
  18. Mendel Leisk
    42,354
    Raytheeagle likes this.
  19. mjoo
    mjoo Senior Member
    1,163
    1,334
    Michigan
    All connections on the engine coolant pump. Google "Prius engine coolant pump"
    It's underneath the first big intake tube (resonator). The resonator is next to the top of the radiator.
    Pixel XL ?
  20. 04priusnow
    345
    201
    Yeah .. no leaks bought from advanced auto.. .. rock auto has the R9 for 3.99 for 2 ft... Thats where i bought it from. The entire length of hose has an oil/gas odor to it.. when it was hot outside thats all you smelled with outside air venting in. Now its colder out so the smell has subsided some.. i found some other forums for Ford Ecoboost OCC having similar issues with the kit they bought
    Nexus 6 ?
