Oil Catch Can, Eliminate that knock!
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by danlatu, May 22, 2017.
  1. mjoo
    mjoo Senior Member
    1,163
    1,334
    Michigan
    That's a filter minder. It records the vacuum behind the air filter. Dirty air filters remove more dirt than clean ones. When the vacuum reaches a certain point I'll change it. Better for the engine and saves money.
    Pixel XL ?
  2. danlatu
    danlatu Senior Member
    533
    1,367
    maryland
    Can you imagine the what the knock would be like if you did not have the catch can. How many miles on your motor MJOO? How many miles did it take to fill up? May need to buy a bigger catch can? I did post in the first page to check it more often in cold weather. If it is full, it will not work. That is why I mounted mine in a place that was easy to get to. I just cleaned mine yesterday and found this today. 22 miles driven round trip with a cold start going to work and a cold start back home with zero knock. 21degrees in the morning drive and 28 degree for the ride home. Fuel, oil and water are present.
    mjoo likes this.
  3. danlatu
    533
    1,367
    maryland
    They are also found on
    Fix
    Or
    Repair
    Daily
    vehicles
    mjoo, Prodigyplace and Raytheeagle like this.
  4. Prodigyplace
    12,713
    11,848
    Central Virginia
    I thought it was
    Fix
    Or
    Rebuild
    Daily
    :LOL: :D
    mjoo, danlatu and Raytheeagle like this.
  5. RMB
    RMB Senior Member
    406
    642
    Oakland, CA
    Or
    Found
    On
    Road
    Dead
    :D
    mjoo and Raytheeagle like this.
  6. Raytheeagle
    Raytheeagle Senior Member
    11,269
    15,528
    Bay Area, California
    2019 Prius Prime
    Any updates on how much you have been catching in your can:whistle:?
  7. RMB
    RMB Senior Member
    406
    642
    Oakland, CA
    Anyways, for now I am still leaving my catch can on the top side of engine, not planning to hide it under the intake or anywhere yet, because I am cleaning it every couple weeks, and found maybe about half an ounce of that fuel/oil/water mixture every time i open it up.
    The Bay Area has cooled down a lot :)pbut still makes many jealous), my daily drive is cold start stop&go for 1.6 miles of stop signs/traffic lights, and a freeway entrance metering light. Then after a mile or 2 at freeway speed I am in about 4-6 miles of congestion on Hwy880. Traffic clear for 2 - 3 miles and I am taking the downtown exit for a fully warmed up local drive. Well, all of 4 blocks. 10 miles of driving takes 25-30 mins. I doubt the ICE is fully warmed up until the last couple miles of my commute. I think summer months maybe whole lot better with what I see in the catch can.
    scona and Raytheeagle like this.
  8. mjoo
    mjoo Senior Member
    1,163
    1,334
    Michigan
    I'm from "Beer City". If you're not into cross-country skiing around here in the winter you look forward to shovelling snow and getting drunk.
    Pixel XL ?
    RMB likes this.
  9. RMB
    RMB Senior Member
    406
    642
    Oakland, CA
    Need some of that beer to save up carbohydrates for shoveling snow next morning. Or skiing. :D
    Let us know how yours go too.
    We have some morning fogs that may add moisture to the collection? Or I think the water in the can is due to not warming up fully in my commute?:(
    Raytheeagle and mjoo like this.
  10. Raytheeagle
    11,269
    15,528
    2019 Prius Prime
    No issues providing more data;).
    Will post the results when I take a gander(y).
    RMB and Mendel Leisk like this.
  11. Mendel Leisk
    42,347
    Yeah, I don't really want to crawl under the car, and pull the panel off, for a false alarm. :whistle:
    RMB and Raytheeagle like this.
  12. Raytheeagle
    11,269
    15,528
    2019 Prius Prime
    I may try to take the air intake off and reach around it to remove mine ;).
    Already tried the flexible-ness of the setup and the Can comes out of the holding can well:).
    So it’s a matter of can I get enough of a hold to rotate the can out of the housing :whistle:.
    I know one way to find out(y).
  13. RMB
    RMB Senior Member
    406
    642
    Oakland, CA
    :whistle:You can take the air intake off to reach down from the top, in the warmth of your heated garage.:whistle:
  14. mjoo
    mjoo Senior Member
    1,163
    1,334
    Michigan
    I have 79k miles on the motor. Not sure about the miles between OCC fills. Maybe 100-150 miles? I do lots of short trips.
    The OCC is the Danlatu-approved one.
    Pixel XL ?
  15. qettyz
    qettyz Active Member
    181
    208
    Finland
    This thread has given me a reason to think about installing OCC also and realizing how good thing it may be! I drive a lot of 5-10km trips on daily basis. I always shut off car after it first shuts itself.
    I hope my block heater(what actually heats oil, not cooland on newer cars) helps reducing water on oil and maybe from mist also.
    Im so planning to keep my car for many many years, so OCC seems to be a must have thing.
    RMB, scona and Raytheeagle like this.
  16. Raytheeagle
    11,269
    15,528
    2019 Prius Prime
    Take the plunge :).
    If nothing else it is a wide spot in the line that you can inspect rather than having to pull the plastic hose and throttle body for an inspection ;).
    I mounted ours on the front cross member so it didn’t impede with the PCV functionality. I work in the Chemical industry and have run across backflow prevention that has liquid collecting on the downstream side before. It inhibits the functionality ;).
    Good luck and keep us posted(y).
  17. danlatu
    533
    1,367
    maryland
    More short trips is what is filling it up faster. Makes sense. Are these short trips involving drive 4-6miles shut down engine, engine gets cold and start it back up again. Guessing 5-6 stops in a day. I know it is really cold in michigan. This kind of stop and go is bad for any combustion engine. On a cold start, most cars run rich and this destroys catalytic convertors with more repeated cold starts. You my friend would greatly benefit an all electric setup.
  18. SFO
    SFO Senior Member
    5,302
    4,251
    Northern California
    Found this image and thought of you guys.
    Robert Holt, RMB and Raytheeagle like this.
  19. Raytheeagle
    11,269
    15,528
    2019 Prius Prime
    Just tried this morning and can’t get 2 hands through the small opening:(.
    But worth a shot(y).
  20. Raytheeagle
    11,269
    15,528
    2019 Prius Prime
    Nice choice of container ;).
    Hope someone after them didn’t confuse the contents:eek:.
