Oil Catch Can, Eliminate that knock!
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by danlatu, May 22, 2017.
  1. Raytheeagle
    Raytheeagle Senior Member
    11,269
    15,528
    Bay Area, California
    2019 Prius Prime
    Looked at mine today (I do every Saturday) and the clear hose is stained:(.
    But after ~2k miles, less than 1/16” of level on the dipstick :).
    I would go to Lowes and pick up the $4 pack. It’ll last you a good bit;).
    But increase the residence time to keep it in the can and prevent it from going further(y).
    leeb18c likes this.
  2. danlatu
    danlatu Senior Member
    533
    1,367
    maryland
    I have been looking at a lot of different oil catch cans and saw that the mishimoto is using a brass filter like the one's you see on air compressors. These are used for removing water and oil so they don't blow through your paint sprayer or tools. I am wondering if i could drill and tap 1/4 npt into the ruien occ and use these filters I found on amazon.
  3. scona
    scona Active Member
    225
    207
    Courtenay, BC, Canada
    2013 Prius v wagon
    You better consider getting a patent the way your OCC is developing!!!
    Really nice work!!!
    danlatu and Prodigyplace like this.
  4. kc410
    kc410 Active Member
    263
    255
    2010 Prius IV
    I picked this one up at Harbor Freight - item 68230
    Packaging says it has a 40 micron brass filter element.
    Filter element itself is 23mm OD, 33mm long
    The drain at the bottom of the clear bowl was designed for air pressure use. I had to remove the parts & plug the fitting with JB Weld. I haven't tried it yet. I want to try it after a much improved OCC, in series with the OCC output. I'm afraid if used alone this unit would fill up quite fast.
    SFO, leeb18c, danlatu and 2 others like this.
  5. Kuang
    Kuang Member
    37
    38
    US
    This is follow up, after 1000 miles, I am Uber driver ( about 300 miles/day, 9000miles/month), so I check OCC every morning and see it's clean now. I also found a mug which is fit to my OCC. The MPG goes up from 45 to 51. I am watching the engine oil consumption.
    danlatu, leeb18c, Bay Stater and 2 others like this.
  6. leeb18c
    leeb18c Active Member
    272
    202
    SF Bay Area
    I still have one of those from 10 years ago that I bought for my Integra as secondary OCC filter but never end up using it. :)
    I thought about putting it in Prius after OCC but not sure if I want another piece of filter.
    Dang, my mesh filter is 100 Mesh(150 Micron). I should find finer one. :)
      File size:
      44.4 KB
    #626 leeb18c, Jan 22, 2018
    danlatu and Raytheeagle like this.
  7. leeb18c
    272
    202
    SF Bay Area
    I'll stop by Lowe's when I have a chance. I do, actually my wife, has a pack of 0000 fine steel wool under the kitchen sink :) but I think it's too thin/fine and thick to use it in the can. Maybe it might be ok.
  8. Raytheeagle
    11,269
    15,528
    2019 Prius Prime
    If you try blowing through it and you are successful, you’ll be fine;).
    Let us know how it turns out(y).
    leeb18c likes this.
  9. Mendel Leisk
    42,352
    FWIW, the top of the Moroso has about an inch of dense packed steel mesh. I'm not sure if stuff is getting through the can. It is catching a fair bit though. I've seen a video where it was set up in series with a competitor OCC, and when the other was downstream it did catch some more.
    leeb18c and kc410 like this.
  10. danlatu
    533
    1,367
    maryland
    Uhhh. I drove the prius 130 miles today with 75 mph speeds. I went to check my occ today after work and noticed it was bone dry at the bottom maybe a couple of drops of oil lingering at the top around the baffle. I did an oil change on sat using 5w20 and added about 200ml of liqui moly. I am not sure if it is the new oil change or the moly. Has any one used this stuff before. I saw a giant sticker advertising this snake oil a couple of weeks ago and googled it when I was working by this small euro mechanic shop. The weather was 35ish this morning with 55 degree on the drive home. I did buy a 1/4 npt tap and some of those brass filters today and will install it when it arrives. I did not relocate the pcv just yet. Still reading to see if anyone else has done anything like this on the web.
    mjoo likes this.
  11. mjoo
    mjoo Senior Member
    1,163
    1,334
    Michigan
    Relocating the valve to after the OCC should help keep it clean. The drawback is that it probably would block the draining of the intake manifold on shut-off for those that have the OCC mounted below.
    Pixel XL ?
  12. danlatu
    533
    1,367
    maryland
    I used a 3/8 tap. Then used a 3/8 to 1/4 npt reducer and installed the 1/4 brass filter and swapped the hoses to the occ. I wanted the filter to protect the intake manifold and I will see how it separates the oil/water/fuel. I put some black rtv where the dipstick came out. It is a little cockeyed, tapped it by hand and eye balled it. I had a 1/4 of a teaspoon worth of fuel/water in the catch from 450 miles driven this week and emptied it and will monitor the progress. This is my ghetto mishimoto occ.
    leeb18c, qettyz, mjoo and 2 others like this.
  13. tvpierce
    tvpierce Senior Member
    951
    883
    Maine
    2013 Prius v wagon
    Nicely done.
    Keep us posted!
    Perhaps I missed this earlier in the thread. The column that's stuffed with stainless steel scrubber... did you add that or did it come that way?
    danlatu likes this.
  14. danlatu
    533
    1,367
    maryland
    I added it. The cone of shame is 3d printed and the stainless pads are just funny business to defuse the mucus coming from the pcv. The brass filter side, feeds the intake plenum/manifold. I kinda of copied the mishimoto one above. I asked questions on amazon regarding if the brass was washable and asked it it filtered all the oil out. I have received email replies from the manufacturer (mishimoto sells these through amazon direct) and customers on how great it was and it is washable. We will see.
    LasVegasaurusRex and tvpierce like this.
  15. tvpierce
    951
    883
    Maine
    2013 Prius v wagon
    Well done.
    So the 3D printed part is simply a compression fit to the OD of the screw-on input area?
  16. LasVegasaurusRex
    LasVegasaurusRex Active Member
    234
    110
    Las Vegas, NV
    @danlatu is this the can you're using?
    danlatu likes this.
  17. danlatu
    533
    1,367
    maryland
    yes.
    yes.
    LasVegasaurusRex likes this.
  18. danlatu
    533
    1,367
    maryland
    It was 35 degrees outside avg all day with 4 start stops in 120 miles driven. When I got home from work, I removed the stained hose and replaced it with new clear/clean 3/8 hose. This is the hose that comes out of the catch can and into the intake plenum. I found a very very small amount of oil under the throttle body in the intake plenum. This is there prior to installing the brass 40 micron filter yesterday in pic above. I cleaned it out with a shop rag while opening the butterfly. It looked like maybe a teaspoon's worth. The catch can had what smelled like fuel and water inside (khaki colored juices) with a hint of oil. I noticed the brass filter had moisture on it inside the can. The hose going to the intake plenum was dry. So far so good. I will monitor the hose to see if it changes in color due to oil passing through the new brass filter I installed. If successful, I would love to see if the brass 40 micron filter keep this hose clear as I put miles on it. This is so exciting.
    Kuang, qettyz, kc410 and 3 others like this.
  19. danlatu
    533
    1,367
    maryland
    174.8 miles driven today, hose is clear and dry.:) I hit speeds with 75mph in the morning and hit mad traffic on the way home. I made 6 stops today.
    leeb18c, mjoo and xliderider like this.
  20. Mendel Leisk
    42,352
    Is that outlet filter going to impact flow too much though? Not sure.
    I've seen one at least one application of the moroso can (they have custom brackets for various vehicles, same can) where they gang-install a pair: whatever gets by the first is caught by the second. Getting pricey though. Maybe you could do similar though, with cheaper cans. Maybe a large primary can, and a smaller secondary one.
    That's a very good make-shift setup btw, a good labyrinth on the inlet side, all the way down, looks very effective.
    scona and danlatu like this.
