Oil Catch Can, Eliminate that knock!
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by danlatu, May 22, 2017.
  1. danlatu
    danlatu Senior Member
    533
    1,367
    maryland
    I will modify our ball jar and install a brass filter (I have 4 left) for the 2010 and install a new 3/8 hose too. Not sure about how much flow is restricted but you can breath through the brass filter. I do not have a cel, so far so good. I know there are two different mishimoto filters that use them. Prius runs smooth.
    Screen Shot 2018-01-26 at 3.51.21 PM.png Screen Shot 2018-01-26 at 3.52.22 PM.png
    SFO, mjoo and Mendel Leisk like this.
  2. danlatu
    533
    1,367
    maryland
    I have seen the dual can setup. Like I have said in my first post. I do not know what catch can is the best. Everyone has wild claims. I want the proof. I have adopted what I have seen to experiment with. Only time/miles will tell.
    Screen Shot 2018-01-26 at 3.55.56 PM.png Screen Shot 2018-01-26 at 3.56.05 PM.png Screen Shot 2018-01-26 at 3.56.26 PM.png
    scona and Mendel Leisk like this.
  3. Mendel Leisk
    42,340
    Looks purdy.
    scona likes this.
  4. danlatu
    533
    1,367
    maryland
    The clear body on this morose is really purdy.
  5. Mendel Leisk
    42,340
    Yeah I watched that, an eye opener.
  6. tvpierce
    tvpierce Senior Member
    951
    883
    Maine
    2013 Prius v wagon
    Great video... thanks for posting?
    Did you catch those puffs of vapor when the throttle closes at :47 & :52?
  7. danlatu
    533
    1,367
    maryland
    What ever happened to that misfire problem you had last year? Was it a bad coil/spark plug?
  8. Lightning Racer
    Lightning Racer Active Member
    239
    321
    Anchorage, Alaska
    Misfire followed spark plug when switched around, so it was a bad spark plug with less than 20K miles on it. I can't say what the reason was. I tried some of the multimeter tests for resistance and conductivity, and the bad plug had poor conductivity, but so did the others. Maybe they were fouled by stuff coming through the PCV.
    danlatu and Raytheeagle like this.
  9. LasVegasaurusRex
    LasVegasaurusRex Active Member
    234
    110
    Las Vegas, NV
    awesome!! any update, hoses still clear?
    nice
    how is this working for ya? :)
    added to parts list :)
  10. danlatu
    533
    1,367
    maryland
    Drove the prius 440 miles from Jan 26 till today. Hoses are still clear! Catch can is working better than ever. You can see there are tiny little spots (size of ball point pen) of moisture/condensation in the clear hose. Air temps were ranging from 19~36 degrees fahrenheit.
    Bay Stater, m.wynn, tvpierce and 7 others like this.
  11. LasVegasaurusRex
    234
    110
    Las Vegas, NV
    Amazing.
    Ordering everything now, including a few taps in case I break one lol :)
  12. danlatu
    533
    1,367
    maryland
    You just need one tap. Buy the 3/8 brass filter so you will not need the 3/8 to 1/4 reducer. Use clean motor oil throughout the tap/cutting process. Turn the tap 1/2 turn in, back out. Clean threads and turn 1 full turn in, back out and clean threads. Repeat this until you have 1/2 inch of threads or so. Do not force the tap, doing this correctly will not break the tap, the aluminum is soft.
  13. danlatu
    533
    1,367
    maryland
    3/8 #18 npt tap.
    LasVegasaurusRex likes this.
  14. jas8908
    jas8908 Member
    42
    38
    dallas
    Thanks for the update danlatu. How long do you think the filters will last? Also how will you be able to tell that its too retrictive?
    Thanks
  15. danlatu
    533
    1,367
    maryland
    The mishimoto guys say it is washable. Not sure how many miles it will be effective/good for, but will monitor it every week when I empty the occ. The clear hose will also be an indicator of how well it works. As far as restriction goes, I think as long as it is not plugged, works for me, too much flow may have been the problem in the first place. The pcv system just releases hot gas pressure from the crankcase so oil seals don't leak, the other is so combustible (oil/fuel) FUMES can be burned off without releasing them into the atmosphere. I prefer this to be a Fumes only and keep the WET mucus out to keep a clean combustion process. This should further help keep egr system, valves, pistons, intake/exhaust ports, spark plugs and injectors clean for better mpg and power. The oil in theory should stay cleaner. Burning oil creates nasty carbon buildup.
    #655 danlatu, Feb 6, 2018
  16. jas8908
    jas8908 Member
    42
    38
    dallas
    Thanks for the info. The fact that the filter can be cleaned makes it easy to switch out a clean filter for a dirty one.
  17. LasVegasaurusRex
    234
    110
    Las Vegas, NV
    you sir are a lifesaver!
    scona and danlatu like this.
  18. LasVegasaurusRex
    234
    110
    Las Vegas, NV
    Going to install on the Camry as soon as all the parts & tools come in. I'm sure you've already answered this but I want to double check: Ideal location for the can, ignoring hiding it from the CA smog test people, is up high correct? And it goes before the valve in this diagram?
  19. Prodigyplace
    12,712
    11,848
    Central Virginia
    I thought it went after the valve, but I could be mistaken.
  20. Mendel Leisk
    42,340
    Not sure about that pic, the oil catch can goes between the pcv valve and the intake manifold, in series along that hose, up to you how. I don't believe it matters if it's higher or lower; mine I did lower, it was just convenient, shorter hose runs and there was more room.
