Oil Catch Can, Eliminate that knock!
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by danlatu, May 22, 2017.
  1. Tbkilb01
    Tbkilb01 Active Member
    218
    187
    Louisiana
    EngineLink with IOS
  2. Tbkilb01
    218
    187
    Louisiana
    IMG_0561.jpg IMG_0562.jpg IMG_0556.jpg IMG_0563.jpg I plugged MAF back in
    Cleared codes
    Let system turn on engine and do its thing. (It shuts off when engine reaches 104F)
    The MAF reading around 8gm/sec running and 0.18gm/sec in ready mode.
    Powered off and checked for pending codes... none!
    Raytheeagle likes this.
  3. Tbkilb01
    218
    187
    Louisiana
    There's that big metal gasket that connects the cooler to EGR pipe coming up from Exhaust manifold. Kinda like and exhaust gasket..it's really thin.It usually drops off before I can grab it. It lands on steering behind engine, straight down, hard to hear with the leaves blowing in air...
  4. JMJCATH
    JMJCATH Member
    91
    52
    Here
    I get READY mode, no problem. It's just that it's running very rough like revs up then down and sounds like it clunks. No check engine light comes.
    I did put the original intake manifold back in and have no change. Next is the pipe and dreaded cooler. :mad:
    Are talking about #8? If so, yes it is on.
    #904 JMJCATH, Apr 15, 2018
  5. Tbkilb01
    218
    187
    Louisiana
    IMG_0575.JPG IMG_0581.JPG Yes that back one. Sounds like not your first rodeo. So guess you saw it. Here's the EVAP purge valve. Mounted on side of intake. Gots connector and two hoses. One comes from back gas tank, connects to the metal tubing, the other connects to intake, front side, next to MAP.
    Did you check harness to fuel injectors? It was in my way a bit. Might have prob there.
    Did you reconnect TPS
    #905 Tbkilb01, Apr 15, 2018
  6. JMJCATH
    JMJCATH Member
    91
    52
    Here
    Yeah, unfortunately, not my first rodeo!
    EVAP purge valve all good.
    Didn't do much as far as checking the fuel injector harness. Nothing seems out of the ordinary.
    Yes, TPS is connected.
    Thank you for all your help. :)
    mjoo and Raytheeagle like this.
  7. Tbkilb01
    218
    187
    Louisiana
    IMG_0584.jpg Here's a shot of MAP ...should read same as atmospheric pressure in ready mode, engine not running, less when idling... IMG_0585.jpg
    May just need to blow out gunk loosened up sucked in during cleaning..have you attempted to drive?
    Did you attempt to clean intake ports on head? The injectors are there too, on top of ports, maybe plugged up one?
  8. JMJCATH
    JMJCATH Member
    91
    52
    Here
    Too afraid to try to drive for fear of it stalling.
    How would I clean the intake ports and unclog the injectors?
  9. Tbkilb01
    218
    187
    Louisiana
    If you never got in there, don't need another variable.putting in gear and pressing gas in driveway? Did you try putting into maintenance mode? Just runs engine at 1000rpm ish for testing...
  10. JMJCATH
    JMJCATH Member
    91
    52
    Here
    Success!!!
    I just went out and put it in maintenance mode. It sounded rough but not as bad as before. About 30 seconds in, the car revved to about 2800rpm for about 2 seconds then went back down. Heard a couple of putters and then it leveled out and sounds fine now!
    My take is the used intake manifold has a crack in it like you said. I will probably remove the original intake manifold and clean it and reinstall it since I can now do this in my sleep!
    Thank you to all who helped me troubleshoot this. :D I really didn't want to remove the cooler!
  11. Tbkilb01
    218
    187
    Louisiana
    That's sounds like a fix...yea ought to take a few minutes off your best time!LOL
    Let it warm up, run a bit, check for codes, may call it a day! May be nothing wrong with intake? I blow nozzle all the parts after cleaning. May have been left over loose build up sucked past valves into cylinders.
    Great job! Not a tough job just tight and low quarters!
    Bay Stater likes this.
  12. JDZILL
    JDZILL Junior Member
    28
    apple valley, ca
    Just finished my OCC install after EGR cooler cleaning on nieces 2010 hears some pics:
  13. Raytheeagle
    Raytheeagle Senior Member
    11,269
    15,528
    Bay Area, California
    2019 Prius Prime
    The one consideration would be the braided hose holding up as the one I installed on our 2010 collapsed:(.
    I switched to 3/8” gas hose and has been working well ;).
    Good mod though (y).
    Bay Stater and Mendel Leisk like this.
  14. Mendel Leisk
    42,343
    I'm not a big fan of replacing parts to sidestep the cleaning process. It's not that hard to clean these items, and it's just throwing a wild card into the mix, acquiring and sub'ing an EBay component, used and from who knows where. Extra expense too.
    Bay Stater and Lightning Racer like this.
  15. mjoo
    mjoo Senior Member
    1,163
    1,334
    Michigan
    Yeah I don't trust the click-type torque wrenches either. I have a couple of the beam type torque wrenches that I bought from either Ebay or pawn shops about 10 years ago. They were both really cheap $10-20 and are always accurate. This works for most parts but the clicker type can be useful in tight quarters. If I had a clicker I'd calibrate it with my other beam-type torque wrench.
  16. JDZILL
    28
    apple valley, ca
    QUOTE="Raytheeagle, post: 2711715, member: 146078"]The one consideration would be the braided hose holding up as the one I installed on our 2010 collapsed:(.
    Good mod though (y).[/QUOTE]
    Thanks, the hose that came with OCC were very flexible, you could pinch it together, I could see it being sucked shut, the hose I replaced it with is very stiff, will keep an eye on it as heat may loosen the lines up a bit.
    Bay Stater and Raytheeagle like this.
  17. evilchargerfan
    evilchargerfan Junior Member
    24
    42
    San Diego
    Hi everyone. I come all the way from the land of the Lexus CT200h crowd. (which lacks the knowledge, and activity of this wonderful place)
    I've been a long time lurker on here. Huge thanks, to everyone on this forum, for being so informative, and thorough.
    Thought I'd share my oil catch can install.
  18. JMJCATH
    JMJCATH Member
    91
    52
    Here
    Took the car to run some errands today and it runs much more quieter and smoother than before. Here are some pictures from the cooler I took off of my ~38K v.
    Bay Stater, Raytheeagle and mjoo like this.
  19. Tbkilb01
    218
    187
    Louisiana
    Mine was worse first time I did it but it was late in the game... already had rattling going on at cold start up.
    IMG_0599.JPG IMG_0600.JPG IMG_0601.JPG IMG_0602.JPG Cooks on and Accumulates. Mine was nearly clogged at 165ish K?
    I visited mine after 20k... Just moist oily on parts.but then again I drive 3.5k/month... Nothing a quick douche of carb cleaner/gas/brake clean or whatever can't spray off then blow nozzle out! Your right doing it early! Glad to here your prius is happy again!
    Some attribute blown gaskets due to pressures built up around ICE attempt BURN/compress oil getting past valves into cylinders..makes sense...
    #919 Tbkilb01, Apr 17, 2018
    farmecologist, JDZILL and Bay Stater like this.
  20. Bay Stater
    Bay Stater Senior Member
    534
    771
    Central Mass
    Was that a home made fabricated bracket? Nice install. Hopefully those Home Depot style braided hoses hold up. I also used them in my OCC installation. So far so good.(y)
