Oil Catch Can, Eliminate that knock!
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by danlatu, May 22, 2017.
  1. Mendel Leisk
    42,348
    I'd let sleeping dogs lie. :(
  2. qettyz
    qettyz Active Member
    181
    208
    Finland
    Yeah i had full bag of long zip ties but no help from those. Luckily that oil/fuel/pcv hose what i bough fall was not costing alot. More of that and maybe routing some way else is the key.
  3. Mendel Leisk
    42,348
    Yeah, routing/mounting is addictive. You pick a half-decent spot, then need to restrain yourself for a while. Engineering process is often like that.
    Bay Stater likes this.
  4. JDZILL
    JDZILL Junior Member
    28
    apple valley, ca
    Here's another go at OCC install, this time pvc style hose,on a 2011.
    amos, danlatu, Bay Stater and 4 others like this.
  5. NutzAboutBolts
    NutzAboutBolts Senior Member
    1,756
    1,789
    Bay Area
    JDZILL, you selling that custom bracket by any chance? I need one lol...
    Bay Stater, JDZILL and Mendel Leisk like this.
  6. FLYNBYU
    FLYNBYU Junior Member
    Webb City, MO
    2020 Prius Prime
    My real world results with the catch can for my 14 Prius. This is after 4k miles.
    amos, danlatu and JDZILL like this.
  7. JDZILL
    28
    apple valley, ca
    The oil catch can is a winner for the 1.8 engines, that grime would have been ingested right back into combustion chamber causing real mayhem! My brother in law has a 2011 corolla 1.8, his PVC valve same mid block location, but throttle body mounted up higher on driver side of manifold, going to install OCC and test on that set up next week.
  8. JDZILL
    28
    apple valley, ca
    Well!, this bracket was made from some scrap I found at Roswell NM, but I believe some aluminum angle from Lowe's will make quick work out of it.
  9. NutzAboutBolts
    1,756
    1,789
    Bay Area
    Lol, I will see if I can make one then. ;)
  10. Bay Stater
    Bay Stater Senior Member
    534
    771
    Central Mass
    Red hoses! Cool!:unsure:
  11. Bay Stater
    534
    771
    Central Mass
    Looks like the same substance coming out of my OCC! :eek:
    JDZILL and Raytheeagle like this.
  12. JDZILL
    28
    apple valley, ca
    Here's a install on an 2011 corolla S, bracket only required a 1" section of angle stock, mounted to battery hold down bolt.
  13. Simonak
    Simonak Member
    Looks good but must be kinda pain to remove it for cleaning. Well after second look you can just undo the 1 bolt not that bad.
  14. JDZILL
    28
    apple valley, ca
    Just the one, I did have to grind down the top of the oil catch can dip stick about 1/8", it was almost touching the hood.
  15. qettyz
    181
    208
    Finland
    Been so busy that my OCC installation back is late. But today i modded my OCC tubes little bit: removed tube clamps and secured hoses with shrink tube what also has glue.
    Gotta try to install these.
    Bay Stater, JDZILL, m.wynn and 2 others like this.
  16. qettyz
    181
    208
    Finland
    There it is again, totally different route for tubing and so so bad(long temporaly) bracket;)
  17. Stangar
    Stangar Active Member
    174
    175
    Palmdale, CA
    Yeeaaahhh Booyyy!!!, . . . . .Here's an opportunity for an entrepreneur to build some "start to finish" OCC kits for Prius Gen III's.
    Robert Holt and farmecologist like this.
  18. Mendel Leisk
    42,348
    Moroso sells kits, but it seems to be mostly, if not all, for US vehicles. Basically you get one of their OCC's, plus a custom bracket and instructions. Even if you're just buying their OCC and jury-rigging something, it's worthwhile to watch a few of the install videos.
    I kinda prefer cobbling my own; it's not that hard, and allows you to optimize, what works for you. With our low mileage and a six month oil change interval, I'm fine with a mounting bracket down below, which requires removal of the engine underpanel.
    But someone with higher mileage, longer oil change interval, I can see the need to mount it accessible from the top. It does make for more circuitous plumbing though, mounting locations are tight, and it obviously doesn't look stock, which may or may not work for you.
    Raytheeagle, Bay Stater and JDZILL like this.
  19. Raytheeagle
    Raytheeagle Senior Member
    11,269
    15,528
    Bay Area, California
    2019 Prius Prime
    At 178 k miles and a 10 k mile OCI, I still put ours low;).
    I check every weekend for spooge buildup, but a small layer exists (less than an ounce or 2):).
    Go low(y).
    #959 Raytheeagle, May 3, 2018
    m.wynn, Bay Stater and Mendel Leisk like this.
  20. qettyz
    181
    208
    Finland
    #960 qettyz, May 4, 2018
