Oil Catch Can, Eliminate that knock!
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by danlatu, May 22, 2017.
  1. Simonak
    Simonak Member
    I think I used 3dhubs.com to make my print and it was 2.5$ + 7$ shipping. I choosed ABS for better heat rezistance. Also it nedded to be trimmed a little for better fit.
    #981 Simonak, May 7, 2018
    Bay Stater likes this.
  2. Mendel Leisk
    42,352
    For up top mounting, I like that guy that worked an aluminum angle, trimmed and bent to suit.
  3. NutzAboutBolts
    NutzAboutBolts Senior Member
    1,756
    1,789
    Bay Area
    I do too, but I don’t have the tools to bend the aluminum, and the aluminum is expensive for a long bar.
    Bay Stater and Bgustafson like this.
  4. jzchen
    jzchen Newbie!
    3,316
    1,022
    Arcadia, CA
    That person found that aluminum in Roswell, NM, I thought. Maybe worth a visit?
    It was either that or Lowe’s....
    JDZILL, Bay Stater and Mendel Leisk like this.
  5. Mendel Leisk
    42,352
    Had another look: space is really tight at top, no really optimum locations; they're all really tight.
    Raytheeagle likes this.
  6. eliteconcept
    eliteconcept 700 mile club, top tank mpg 69.5
    449
    186
    Indiana
    2022 Prius Prime
    Please do.
  7. eliteconcept
    449
    186
    Indiana
    2022 Prius Prime
    I have access to a 3d printer and ABS material for it. Did you use Danlatu's file for your print, Prius Oil Catch Can Bracket by Danlatu - Thingiverse. Curious how the abs material is holding up
  8. Raytheeagle
    Raytheeagle Senior Member
    11,269
    15,528
    Bay Area, California
    2019 Prius Prime
    Lower mounted to the cross member gave me good access from the top. All you have to do is remove 3 bolts for the intake and done ;).
    Removal of the catch can needs to be done from below, but if you get the drained style can, it would alleviate the concern :).
    But 8500 miles since the install and have only caught about 7 ounces(y).
    Mendel Leisk and Bay Stater like this.
  9. Simonak
    Simonak Member
    Yes I did. So far like 3 weeks in it looking good but summer temps just starting.
  10. JDZILL
    JDZILL Junior Member
    28
    apple valley, ca
    Those silly men in black wanted there metal back,I told them its on a Prius, go find it!
  11. Mendel Leisk
    42,352
    Thanks for that. You could come at that concept from various directions, different starting material. Steel gauge plate for example, say around 1/16" thick, at most. (y)
  12. NutzAboutBolts
    1,756
    1,789
    Bay Area
    What did you use to roll the aluminum? And what’s the length and size of it? Can I see the measurements?
  13. JDZILL
    28
    apple valley, ca
    This one started at 3' long, you can go half way around the OCC if you make it 5" long. Both can be bolted to can, or using a nice stainless steel hose clamp around can and mount.To bend, start at where you cut off at the chassis mount in a vise and slowly work outward to where you want the bend to end using a small brass or plastic hammer.
  14. JDZILL
    28
    apple valley, ca
    The stock size was 1/8" x 2" it used to be 4' long, down to about 2' now!
    Bay Stater and NutzAboutBolts like this.
  15. 12voltman
    12voltman Member
    124
    93
    I have one of danlatu's brackets and it works perfectly ......just sayin !
    qettyz, JDZILL and Bay Stater like this.
  16. NutzAboutBolts
    1,756
    1,789
    Bay Area
    Yep, waiting for danlatu to make my bracket. :)
  17. eliteconcept
    449
    186
    Indiana
    2022 Prius Prime
    He is 3d printing them? any idea what material he is using? nylon? abs? pla?
  18. NutzAboutBolts
    1,756
    1,789
    Bay Area
    He said nylon
  19. JDZILL
    28
    apple valley, ca
    I like those, very easy to empty can with, good stuff Danlatu, and good install 12voltman!
  20. eliteconcept
    449
    186
    Indiana
    2022 Prius Prime
    Does installation of this require any cutting of original lines or does installation simply bypass existing lines with new lines getting connected in their place?
