Oil Catch Can, Eliminate that knock!
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by danlatu, May 22, 2017.
  1. NutzAboutBolts
    NutzAboutBolts Senior Member
    1,756
    1,789
    Bay Area
    Bypassing with new lines, always keep oem. They’re expensive.
  2. eliteconcept
    eliteconcept 700 mile club, top tank mpg 69.5
    449
    186
    Indiana
    2022 Prius Prime
    I just didn't know if installation required cutting of any existing lines, cool thank you. Please make a video on installation! Your videos are always so helpful and clear.
  3. qettyz
    qettyz Active Member
    181
    208
    Finland
    I think most of us have cutted the original PCV tube.
    I bought extra tube what i cutted and saved the original.
  4. Raytheeagle
    Raytheeagle Senior Member
    11,269
    15,530
    Bay Area, California
    2019 Prius Prime
    I cut the original and have a spare;).
    Easy to go back stock and low cost(y).
    Bay Stater likes this.
  5. Mendel Leisk
    42,369
    You could just put a barb splice in, to restore the original if cut. I snapped and bought a spare, it was a lot for such a small item though, $26 up here.
    You can avoid cutting that hose, but the one wrinkle is that it flares out at the intake manifold: I finally caved and cut it for this reason: it seemed the easiest way.
    Bay Stater and scona like this.
  6. jzchen
    jzchen Newbie!
    3,316
    1,022
    Arcadia, CA
  7. TheChip
    TheChip Senior Member
    388
    1,211
    Misissippi
    One week of oil in the catch can. I'm glad I decided to do this, because that is WAY too much oil! The manifold was coated when I cleaned it out.
    I'll be pulling it off again this weekend to fix that kinked hose :( IMG_20180509_172202520_HDR.jpg IMG_20180509_172205760.jpg IMG_20180509_172055990_HDR.jpg
    Bay Stater, RMB and Mendel Leisk like this.
  8. Mendel Leisk
    42,369
    Black rubber fuel line, spec SAE-30R7 or SAE-30R6 is good. Readily available at automotive specialty stores, about $1.50 per foot.
    Bay Stater, RMB and qettyz like this.
  9. Bay Stater
    Bay Stater Senior Member
    534
    771
    Central Mass
    Hey, just wondering if any of you OCC installers notice a slight odor coming from your OCC installation area.
    Situation: My prius is garaged and when entered, can detect a slight odor that smells like the substance the OCC collects. The odor is strongest around the OCC housing itself. Maybe it's the flex hoses emitting the odor? There are no leaks. I have the Ruien OCC. :unsure:
    Thanks for any advice.:(
    My OCC installation.
    #1009 Bay Stater, May 10, 2018
  10. RMB
    RMB Senior Member
    406
    642
    Oakland, CA
    I do smell the odor you described, I am guessing either from the dipstick seal or the big top bolt, as I recall, the top bolt that replaces the air vent didnt have an o-ring. Didn't really bother with it though, maybe I should find the leak and fix it. Let's see if others have similar situations.
  11. Mendel Leisk
    42,369
    None with my Moroso.
  12. qettyz
    181
    208
    Finland
    Are the hoses fuel specs? Those start to giving up?
  13. qettyz
    181
    208
    Finland
    OCC emptying time again. This is what i get in about a week.
    Not so much but better to not burn that stuff out to EGR system.
  14. TheChip
    388
    1,211
    Misissippi
    Interesting...what is that? It looks too clear to be oil unless you just changed it.
  15. Mendel Leisk
    42,369
    Mixture of oil and some water/gas mix? I drained some similar, and 6 months later it looked like this:
    danlatu, Bay Stater and qettyz like this.
  16. JDZILL
    JDZILL Junior Member
    28
    apple valley, ca
  17. jzchen
    jzchen Newbie!
    3,316
    1,022
    Arcadia, CA
    JDZILL, I’d do the OCC mod in a heart beat, except for the concern come smog check time. Can you imagine a Prius not passing smog test?!
    Yes, very good pricing, although compare with what you can get at Walmart. (That’s where I usually buy Mobil oil).
  18. qettyz
    181
    208
    Finland
    Smells fuel and there is clearly water what does not "mix" in. Little oil bringing that brownish color. Thats what my Auris/Corolla with gen3 tech cooks some soup:)
    Temps here around currently morning +6C and day +16C.
  19. qettyz
    181
    208
    Finland
    Hello guys,
    Please forgive me borrowing some of your pictures and taking few beers while i done this :)
    Really do not know if this helps anyone, but i'll be happy if even one person finds this useful and helps her/him somehow.
    I gathered some OCC info to one document.
    Simtronic, Bay Stater, JDZILL and 3 others like this.
  20. Mendel Leisk
    42,369
    That's fantastic! I see my sketch, and my fingers in another picture. (y)
