Oil Catch Can, Eliminate that knock!
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by danlatu, May 22, 2017.
  1. Montgomery
    Montgomery Senior Member
    2,254
    2,244
    Orange County, CA
    This is a must do routine for our cars. Seems like it should be a service at around 70k to get it cleaned and have someone (or yourself) install the Oil Catch system.
    danlatu and Tbkilb01 like this.
  2. Rebound
    Rebound Senior Member
    3,996
    2,645
    Portland, OR
    Do you have any photos of your install?
    PRIUS STAR SHIP and Tbkilb01 like this.
  3. Swampy
    Swampy Junior Member
    30
    23
    NorCal
    My 2011 Prius hasn't seen a dealer since I bought it used. The prior owner had regular services done at the dealer and this may have been initial cause of my car's EGR/PCV/Misfiring/goop and sludge woes. My intake manifold does get a nice puddle of random chemical goop at the bottom of the intake manifold after just a 1,000 miles (which is just a few weeks for me) and because of this I'll be installing a sizeable Moroso catch can with a drain on it. I have it already and tested the drain valve to see if it can hold both pressure and vacuum without leaking.
    With over 250,000 miles and more than just a few of those at high rpm in Power Mode on mountain roads, my car may have seen more heavy right foot than most on here and consequently possibly more engine wear. Add to that the TRD springs, swaybar and Koni shocks and the mountain road fun may end up giving the car PCV fun in the corners too, something not helped my years of prior car and bike racing ;) That said, it religiously gets the oil changed between 5,000 and 8,000 miles whenever it starts looking more than just light amber, with Mobil 1. My oil changes are frequent given the 40,000+ miles per year I drive.
    Tbkilb01 and danlatu like this.
  4. Swampy
    30
    23
    NorCal
    I find it hard to believe that a head gasket swap in a Prius costs more than a head gasket replacement in a Scoobydo, given the location of the boxer engine.
  5. mjoo
    mjoo Senior Member
    1,163
    1,334
    Michigan
    I installed danlatu's oil catch can last month. It was a 20 minute install with the manifold and air cleaner off of the car. A lot of space opens up when you remove the intake resonators after the air filter box. I'll post pictures of my mods when my "field testing" is complete. First need to get a license plate!
  6. Swampy
    30
    23
    NorCal
    Mjoo,
    A license plate would be useful. Whilst a dirty EGR isn't the best, nor is a goopy PCV system, I suspect that being stopped by the cops and stuck in the back of a cruiser is a shittier ending to the day than either of those Prius woes...
    mjoo likes this.
  7. Jkan2001
    Jkan2001 Member
    201
    63
    Dallas TX
    Do you have a picture or video for this?
    PRIUS STAR SHIP likes this.
  8. mjoo
    mjoo Senior Member
    1,163
    1,334
    Michigan
    Here are all my engine improvements before I got the new car purchase on the road:
    This is @danlatu's suggested PCV catch can (bottom left). The CC was initially above the coolant pump but I moved it lower. My idea is to have it lower than the PCV so that it quickly drains away from this valve. An improvement would be to use a 3/4" ID hose for the outlet side to lower the pressure drop and increase flow. I just need to find a 3/4" nipple with straight 1/4" pipe threads. There's also a sock pre-filter (bottom right) for the air intake that I used on my previous car. This is a simple, quick mod that can be emptied and has proven to remove a large amount of debris. Lastly there's a filter minder (top right) connected to the air box. The 2010 has about 73k miles.
    That's what you can see in this picture. Aluminum window screen was installed over the HVAC inlet.
    As for results, the engine has been noticeably smoother and quieter with the intake manifold, EGR system cleaned even with the air intake muffler removed. I'm averaging 55 mpg over the last 80 miles.
    #108 mjoo, Jul 18, 2017
    James Analytic, Soh, TheeWood and 5 others like this.
  9. CR94
    CR94 Senior Member
    2,831
    1,243
    Northwestern S.C.
    My Prius consumes very little engine oil overall so far, like (as I understand) most others that haven't yet attained serious oil-guzzling stage. The amount leaving via PCV must be miniscule, given that all engines must use at least a little through the rings and cylinder walls. I'm having a little trouble understanding why oil in Prius PCV system is so much worse than in other engines.
    The PCV valve and valve-to-manifold tubing in my Mazda were always very oily, yet no ill effects ensued in 606K miles. I don't know how much oil was leaving by that route, but would bet it was a lot more than in the Prius. (Overall consumption was about 3K miles/quart at best.)
    hotelprisoner and Raytheeagle like this.
  10. danlatu
    danlatu Senior Member
    533
    1,367
    maryland
    How many miles are on your engine? If a car is pushing oil through the pcv system it will get into the combustion chamber. This oil gums up components that make the engine run smooth. If you take an engine apart, you will see oil is caked everywhere hindering performance. Your mazda that has 606k miles on it is impressive. Original everything? I see the prius' manifold holding oil right below the throttle body and during start up it then is thrown into the combustion chamber. If your car is running fine, I would not worry about it. When rings, wear out on older engine's, it will create more blow-by and increase crankcase pressure. This pressure then pushes more oil through the pcv system. Turbo charged cars have a really big problem when it comes to burning oil and aftermarket oil catch cans are a must. The oil coming out of the pcv system in direct injection motors are ruining intake valves on newer cars requiring a walnut blasting or detergent.
    I see the oil catch can as insurance and preventative maintenance for catching the majority of oil before it is dumped into the combustion chamber. I also think it should be an emission's requirement because burning oil causes increased air pollution. Combustion engine's will be done in 15-20 years. Eu is already signing deals now to stop the sales of combustion powered cars and fuel will be no longer for sale by 2040. All due to air pollution. We are aslo on the verge of a subprime auto loan meltdown.
    The good news, My prius is still getting 52mpg avg. with 2.19$ gallon. I really like saving money.
    The prius has loose engine tolerances making it have less internal resistance. When the tolerances wear out. The motor drinks engine oil. It is simple. Your mazda has a tight engine tolerance like my honda does. I hope I can get 606k on my ridgeline.
    #110 danlatu, Jul 22, 2017
  11. Buderim
    Buderim Junior Member
    28
    Queensland Australia
    i-Tech
    Do you need to get a new intake manifold gasket or can you re-use the old one ?
  12. danlatu
    533
    1,367
    maryland
    You can reuse the old, unless it is ripped. I had 297k on mine and I could have reused it.
    Mendel Leisk and Buderim like this.
  13. DrTrivia
    DrTrivia Member
    44
    27
    Haha, I jumped the gun on this one. Decided I would add an OCC to my 11' Prius while I had some time off this week. Bought the kit, then realized I couldn't make heads or tails of the pictures or descriptions in this thread. Also can't seem to find any instructions online elsewhere. If anyone is doing this soon, it would be greatly appreciated if you could post some pics of where you are connecting those hoses. There are pics of the job finished, there's one pic with a hose running from one port to another without connecting to an OCC, but I just can't seem to put the two together well enough to risk starting the job.
    PS: thanks to the OP and all other contributors for this, I had no idea this problem existed before coming across this post.
    PRIUS STAR SHIP and mjoo like this.
  14. mjoo
    mjoo Senior Member
    1,163
    1,334
    Michigan
    It's actually easier than it seems. I'm on vacation with no access to my laptop or manual but here's my procedure:
    1. Remove the air filter box it's three 10 mm bolts. The snorkel clamps are also 10 mm.
    2. There's a rubber elbow underneath the throttle body on driver's side. Connect the catch can's outlet hose to this elbow
    3. The PCV valve is behind the throttle body and connected to the engine and this elbow from #2. Connect your can's inlet hose to this valve.
    Pixel XL ?
    Rebound likes this.
  15. Yippeekyaa
    Yippeekyaa Active Member
    137
    160
    North Carolina
    Just finished the 100k service on my Prius. Plugs,egr removal and cleaning, etc. installed a catch can while it was apart. Made my own can from a metal drink canister and two brass fitting. Have it zip ties in under the air cleaner snorkel and above the ac compressor. Fits perfectly and is hidden. Takes less than two minutes to pull the snorkel out to access it for cleaning. Found the canister at the dollar store bargain bin. Set me back .99 cents. 1.50 each for the brass fittings. Bit of quickset epoxy I already had on hand plus another 4 bucks for the hose. A home made catch can installed for under 10 bucks.
    I started to paint the can but with its location no one will see it. Besides its officially labeled as awesome.
    While figuring out the hose routing I didn't have to cut the original pcv hose. Simply rotated it about 90 degrees, added a brass hose coupler and ran new hose from there, under the intake to the can. Simple job.
  16. Montgomery
    2,254
    2,244
    Orange County, CA
    I haven't had it done. I am waiting for the infamous crew at HybridPit to dial in their service for this. I am willing to pay for them to do it because they have access to the parts and the crew can do it. I will let all know once I have it done. HybridPit is in orange county in the city of Buena Park. I received and email from them stating they are putting a program together to do this service.
  17. Montgomery
    2,254
    2,244
    Orange County, CA
    Of course, detailed photos will follow!!
    Raytheeagle likes this.
  18. Montgomery
    2,254
    2,244
    Orange County, CA
    And, we need to thank those how found out about this issue and found the "fix". Pruischat members care about each other!!
  19. Tbkilb01
    Tbkilb01 Active Member
    218
    187
    Louisiana
    I meant the HV PLUG ...I always unplug HV PLUG when I work on hybrid.
  20. Tbkilb01
    218
    187
    Louisiana
    I reached across thru hoses straight to PCV. Dont see lifting Prius for that
    Plus the shield stuff...I just remove the 6 screws and pull air box out of way to get maneuver room. Tight fit for hands but once you know where you'd heading to you can feel it! Of course a battery power tool makes quick work of it all!
    RMB and Mendel Leisk like this.
