Oil Catch Can, Eliminate that knock!
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by danlatu, May 22, 2017.
  1. Bay Stater
    Bay Stater Senior Member
    534
    771
    Central Mass
    Thought I share the OCC accumulation after 10K miles. Roughly 7oz. :eek:
  2. Raytheeagle
    Raytheeagle Senior Member
    11,269
    15,530
    Bay Area, California
    2019 Prius Prime
    How long was it in service?
    m.wynn and Bay Stater like this.
  3. Mendel Leisk
    42,373
    10,000 miles. Maybe that bottle is the accumulation of several dumps? Considering the typical OCC capacity, you'd want to check/empty every 5,000 miles max. Winter is worse?
    Bay Stater likes this.
  4. Fred_H
    Fred_H Misoversimplifier
    562
    488
    28
    Germany
  5. Bay Stater
    534
    771
    Central Mass
    I installed it back in March. Been emptying the can every 1K or so.;)
    Raytheeagle likes this.
  6. Bay Stater
    534
    771
    Central Mass
    Did it every 1K or so.(y) .Yes Winter is worse. That's when it accumulated the creamy white stuff.:eek:
  7. Raytheeagle
    11,269
    15,530
    2019 Prius Prime
    So this is a compellation of all the drainings for 10k miles?
  8. Civiceg94
    Civiceg94 Member
    60
    45
    Nyc
    This how much i got with aroud 4,000 miles roughly. I put the catch can after i already did my oil change and it had over 1,000 miles.
    Bay Stater, Raytheeagle and Grit like this.
  9. Bay Stater
    534
    771
    Central Mass
    Yes. (y)
  10. Georgina Rudkus
    Georgina Rudkus Senior Member
    3,576
    2,605
    Taylors, SC
    I installed the HPS short arm air intake with the truncated K&N high flow air filter. That allowed me to install the Ruen oil catch can in the space freed up by the removal of the air filter box. occ installed Prius V 001.jpg
  11. evilchargerfan
    evilchargerfan Junior Member
    24
    42
    San Diego
    sorry for the late reply!
    I eventually got rid of the inline water separator type, and went back with the more common can that everyone else is running. I cant explain why but, somehow the smaller inline one causes my Honda Fit to lose power. Going back to the original metal can alleviated the issue. (I did verify, I followed the correct flow path when installing the hoses)
    Nonetheless, I would have hated that small one anyways. Being so tiny meant, more frequent emptying of the inline water separator, whereas with the much larger metal can I can probably go 15000 miles before needing to drain
    It was NOT easy to drain, another reason why I got rid of it. From what I could tell, the drain method was to depress the needle on the bottom. I did not attempt to turn/spin anything. The plumbing is determined by a directional arrow on top to indicate flow path, I believe these inline water separators have a valve of some sorts built in, to only allow air flow in one direction. And the clear part appears to be glass
    I will say, it does appear to filter the oil much better than the other occ
  12. Mendel Leisk
    42,373
    Thanks @Georgina Rudkus for the hose clamp tip. I replaced all my screw clamps with those, looks much better. (y)
  13. Michael Mann
    Michael Mann Active Member
    167
    408
    Bay Area, CA
    I changed my oil this weekend after 9k miles and pulled approximately 3oz of oil out of the OCC. Had a bit of satisfaction seeing that not going into my manifold.
    RMB, Raytheeagle, Bay Stater and 4 others like this.
  14. Hsieh2017
    Hsieh2017 Junior Member
    Taiwan
    I have installed a Mishimoto OCC. to remove oil vapor from entering intake manifold for a year. It works well.
    However, I am always wondering that will the OCC. increases air flow resistance and reduce the vacuum (negative pressure) inside the engine?Especially for the OCC with dense filters.
    Furthermore, what happens if the filters start clogging in case of forgetting maintenance?
    Will clogging cause the seals of the enginge leaking?
    mjoo and Mendel Leisk like this.
  15. Raytheeagle
    11,269
    15,530
    2019 Prius Prime
    Closed hood maintenance or those that can be forgetful could find challenges with certain solutions ;).
    Until you have a good handle on how much material you catch, is keep a close eye on it and plan accordingly :).
    I check mine on our 2010 woth 191 k miles every Saturday just to ensure there is no surprise (y).
  16. Mendel Leisk
    42,373
    The drain tap on my moroso is at the underside, and taking the engine underpanel off for every oil change, I'm staring at it, I've mounted it on the lower cross beam. Maybe I could hang a tag on it too, saying "DRAIN ME". Kidding...
    With a 6 month interval (and 5000 kms at most) I've never got into trouble: my fall drain is an ounce or two, and spring drain a bit more, maybe due to more humidity through winter.
    I think it would be bad to let it fill up, for sure. And it's also good to monitor the condition of the interior, say every 2 years: clean out any mesh on the inside. At least till you get a feel for how quickly it clogs up.
    Bay Stater and Raytheeagle like this.
  17. Raytheeagle
    11,269
    15,530
    2019 Prius Prime
    My lower mounted can gets its dipstick checked often enough and the steel wool pad is changed every oil change;).
    Unfortunately the last round I didn’t compress the wool enough and it wrapped around the dipstick :cool:.
    Resulted in a revisit of the can at 1 k miles:).
    Got about 1 ounce out(y).
  18. mjoo
    mjoo Senior Member
    1,163
    1,334
    Michigan
    Since the cold weather moved in last month the temperatures have been in the 30s and 40s and my OCC drains have been much more frequent. We drove 180 miles north to Sleeping Bear Dunes for a color tour on October 28. The next day the engine started with a slight misfire. I found the OCC canister almost full after a week of use.
    Just for comparison, my OCC is close to the inlet of the air intake. I believe the OCC gets cooled faster by the intake air around it and distills the PCV fumes. This is desired behavior.
    #1218 mjoo, Nov 19, 2018
    m.wynn, Bay Stater, amos and 3 others like this.
  19. qettyz
    qettyz Active Member
    181
    208
    Finland
    I have taken my OCC away again for winter. I cannot live with the fact that it can freeze and then problems start.
    During warm spring days my car gets OCC back.
    #1219 qettyz, Nov 19, 2018
    Bay Stater, Mendel Leisk and mjoo like this.
  20. mjoo
    mjoo Senior Member
    1,163
    1,334
    Michigan
    From my experience, as long as you have the time to empty the OCC frequently enough it's not a problem. It gets down to around 0*F in our Michigan winters. I change it up to twice a week depending on how cold it is.
    But I imagine if you let it fill up and then freeze it would present a problem.
    When it's 0*F I've had to rinse out the can with hot water.
