Oil Catch Can, Eliminate that knock!
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by danlatu, May 22, 2017.
  1. danlatu
    danlatu Senior Member
    533
    1,367
    maryland
    Oil smell is from an air leak in a connector, hose or occ. Burning very small amounts of evenly distributed oil/water/fuel vapor is not terrible, it just causes fouled spark plugs, clogged piston rings, dirty valves/seats, decreased mpg, early egr failure, clogged egr ports in intake manifold, dirty map sensor (lack of power/stalling) carbon build up on pistons/heads with irregular compression and burning oil. It is the cold start knock from oil/water/fuel that is pooled up in the intake manifold that will blow a head gasket.
    Grit, mjoo, Bay Stater and 2 others like this.
  2. Grit
    Grit Senior Member
    6,577
    4,231
    Wilkes Land
    I have an oil extractor with a 6ft straight tip, is that something worth syphoning out the oil pool on the terms that no oil gets on the throttle plate and any other surface on engine parts?
    RMB likes this.
  3. Mendel Leisk
    42,347
    Who knows how much stuff goes through, doesn't pool there?
    scona likes this.
  4. The Critic
    The Critic Resident Critic
    3,193
    2,333
    CA
    You will have to enlighten us on how that is possible...
    CR94 likes this.
  5. The Critic
    3,193
    2,333
    CA
    This post does not help your credibility. ATP205 has a conditioning effect on rubber seals. Piston rings are metal. ATP205 cannot “swell” piston rings.
  6. danlatu
    533
    1,367
    maryland
    Where did I say piston rings???
    5C4BED55-DEA9-47FB-978E-C87E8E404514.jpeg 880F8E45-89FD-48C1-86D3-A188CABC9ECF.jpeg
  7. The Critic
    3,193
    2,333
    CA
  8. danlatu
    533
    1,367
    maryland
    Seals and “O” rings are the same. I just replaced 2 rubber “O” rings on my power steering pump on my truck. Did not need to replace the whole power steering unit.
    Bay Stater and mjoo like this.
  9. danlatu
    533
    1,367
    maryland
    14 parts air 1 part fuel is how combustion works. When an engine has fluid (oil/water/fuel) that is sucked into the combustion chamber, the ratio is no longer 14 parts air 1 part fuel. This creates a temporary knocking/hydro lock inside the combustion chamber that can destroy a head gasket, bend rods and stretch head bolts. Fluid is an incompressible solid. Oil/water/fuel is not suppose to be in the intake manifold. The gen3 prius has an intake manifold that likes to trap this fluid in two area's from the pcv system. Prii in cold, humid, short driving trips will experience more build up in the intake manifold than others. Oil/water/fuel rests in the area's circled in brown.
    Bay Stater, Robert Holt and ASRDogman like this.
  10. danlatu
    533
    1,367
    maryland
    Oil/water/fuel accumulates under the throttle body. You can either remove the entire intake plenum to clean, use a rag or vacuum pump it out when throttle body is open.
    Bay Stater and Mendel Leisk like this.
  11. Mendel Leisk
    42,347
    I'm trying to ditch my Oil Catch Can accumulations, mixed it in with drained engine oil, took the mix to Mr. Lube to be poured into their waste oil tank. Trouble is, the OCC stuff settles to the bottom. I'll have to give it a swirl just before handing the container to them next time. It's pretty sorry-looking stuff.
  12. Raytheeagle
    Raytheeagle Senior Member
    11,269
    15,528
    Bay Area, California
    2019 Prius Prime
    Swirl away;).
    At least there’s a way to get rid of it (y).
    Bay Stater likes this.
  13. Mendel Leisk
    42,347
    Yeah, beats shooting it into the combustion chamber, not exactly Top Tier gas. :rolleyes:
    Bay Stater and Raytheeagle like this.
  14. Raytheeagle
    11,269
    15,528
    2019 Prius Prime
    Probably similar to the stuff you buy at a place like Rotten Robbie’s:whistle:.
    How fast does it separate when in the waste can?
    You could always change it up and get a non transparent container;).
    That’d save the swirl before return(y).
    Bay Stater, RMB and Mendel Leisk like this.
  15. Bay Stater
    Bay Stater Senior Member
    534
    771
    Central Mass
    Or you can take the OCC fluid collections to the recycling center. :eek:
    Raytheeagle likes this.
  16. Mendel Leisk
    42,347
    I think you're kosher to add OCC accumulations to waste engine oil. The stuff is coming from a a pcv valve on the crankcase wall, and that valve is at the end of a crude labyrinth, that catches some of the gunk and returns it to the oil, so you're just being a bit more efficient at waylaying the stuff.
    It's not a very nice brew though.
  17. James Powers
    James Powers Senior Member
    396
    555
    Bay Area
    Welp, fellas.... It happened... Got the knock that set off a check engine light with a misfire code on cylinder 1... Took it in, compression test, blooooown head gasket.... The OCC was on my list of mods to do! Looks like after it gets fixed, it will be expedited to the top of the list!
    Bay Stater, RMB, Raytheeagle and 2 others like this.
  18. scona
    scona Active Member
    225
    207
    Courtenay, BC, Canada
    2013 Prius v wagon
    Ouch, how to get your day spoiled. What is the mileage?
  19. Grit
    Grit Senior Member
    6,577
    4,231
    Wilkes Land
    Sorry to hear that, was hoping to see your blizzard pearl at some SF meet up. If there’s any mods your parting out, let me know if decide to pass on the Prius.
    James Powers likes this.
  20. James Powers
    396
    555
    Bay Area
    Big time, right? It has 147k on it but I bought it with 82k and while I am pretty sure the regular maintenance was done, but the EGR was probably never cleaned (it was a fleet vehicle so it had all maintenance) - which was on my list to tackle this weekend...
