Oil Catch Can, Eliminate that knock!
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by danlatu, May 22, 2017.
  1. The Critic
    The Critic Resident Critic
    3,193
    2,333
    CA
    It might happen someday. Just need to get @Raytheeagle on board with the idea.
    It is a one day job if you don’t send the head to a machine shop.
    Bay Stater, RMB and Raytheeagle like this.
  2. Mendel Leisk
    42,352
    How the owners of a generation progress, from chasing down dash rattles, to open-heart surgery, lol.
    Grit, Bay Stater, CR94 and 2 others like this.
  3. Raytheeagle
    Raytheeagle Senior Member
    11,269
    15,528
    Bay Area, California
    2019 Prius Prime
    Count me in;).
    That’ll be one of the last jobs I never get to do on a Gen3 while owned:).
    Why not pay it forward (y).
    Bay Stater and Mendel Leisk like this.
  4. Raytheeagle
    11,269
    15,528
    2019 Prius Prime
    Go low and you can use a tin can for support:).
    Then it’s a true knock out pot(y).
    Grit likes this.
  5. Raytheeagle
    11,269
    15,528
    2019 Prius Prime
    There is a “guy”:whistle:.
    He’s in San Ramon too:).
    He’s even got a catch can installed (y).
    Grit, The Critic and Bay Stater like this.
  6. Grit
    Grit Senior Member
    6,577
    4,231
    Wilkes Land
    Cheers to 2,500 mi of driving.
    Catch can used below
    mjoo, Bay Stater, RMB and 1 other person like this.
  7. Grit
    Grit Senior Member
    6,577
    4,231
    Wilkes Land
    Zip ties & an empty can of corn mounts my occ front of radiator fan, holds like a champ.
  8. Raytheeagle
    11,269
    15,528
    2019 Prius Prime
    That matches our old Prii’s green bean can well:).
    Wonder where you got that from:whistle:?
    Glad to hear it is working well though(y).
  9. Grit
    Grit Senior Member
    6,577
    4,231
    Wilkes Land
    Great vegetarians think alike? :LOL:
    OCC works fine but I don't recommend that catch can though. The gasket on the top lid expands, and once you open it, there's no way to put the lid back on with the expanded gasket. I just used high temp pipe seal tape that's seals water & gas, which I wrapped it as the gasket ring.
  10. The Critic
    3,193
    2,333
    CA
    Any update? Is it done yet?
    Mendel Leisk and Raytheeagle like this.
  11. James Powers
    James Powers Senior Member
    396
    555
    Bay Area
    Just went down to the shop this morning actually, was going to post an update. He has it all apart and says we caught it in time. Nothing was warped or bent. Sent parts to the machine shop and is just waiting on the water pump to be delivered. He did say the EGR was really clogged so, confirms for me that it was probably never cleaned out.
    While he has it apart, I also have him replacing my driver side CV axle. So far, pretty pleased with this shop, he took on the extra job, no problem.
  12. The Critic
    3,193
    2,333
    CA
    Cool. It goes to show you how small the "window of opportunity" is for these head gasket repairs. If the car has been misfiring for a week or two, it could be too late.
    I would not allow him to replace the CV axle unless he is using a Genuine Toyota axle or is rebooting the original one. The new aftermarket axles are all garbage.
    James Powers and Raytheeagle like this.
  13. theheapstoe
    theheapstoe Junior Member
    26
    Coulterville, CA
    I don't have time to read through this whole thread right now, but this looks like the best place to ask my question.
    I did the EGR cleanup. There was oil and carbon buildup from the air intake through the EGR system. You could see it gumming up the walls before the air intake too. I cleaned everything best I could and put it together. Everything ran fine. Then the slight oil burning I had experienced before went crazy. I burned 6 quarts over a 1600 mile road trip the other week. I don't know how my car is still running. Now, after all that, the burning is slowing back down. Could cleaning the EGR have changed the pressures in the engine and caused it to leak more oil past the piston rings? And now the EGR is blocked again and things are plugging back up and equalizing? Could an oil-catch can help when you are burning that much oil?
  14. Raytheeagle
    11,269
    15,528
    2019 Prius Prime
    So when did the dash light tell you the oil level was low and when did the egr cleaning occur?
    Once the dash light tells you the oil level is low, it’s too late and the engine is starved of oil. So if right after, you have the wrong root cause.
    Our old 2010 would consume more oil on road trips and that is not uncommon as the speeds are higher and things are working harder.
    James Powers likes this.
  15. Mendel Leisk
    42,352
    Something is seriously hooped; that is terminal oil consumption. Could it be a clogged PCV valve, causing high pressure in the crankcase, pushing oil up past the piston rings. Where it burns, clogs up the EGR, which raises engine temps, which makes matters worse?
    We could start a pool on when the head gasket will blow...
  16. Rebound
    Rebound Senior Member
    3,996
    2,645
    Portland, OR
    Or the piston rings are shot.
  17. James Powers
    396
    555
    Bay Area
    Shop called last night. I pick up my car today! I’ll let you guys know how the drive home goes.
    Grit, Mendel Leisk and Raytheeagle like this.
  18. James Powers
    396
    555
    Bay Area
    Good news! She runs like a champ!
    I’ll be doing the OCC install if I can figure out what material to use for the 3D printed bracket.
    Mendel Leisk, Grit and Raytheeagle like this.
  19. Raytheeagle
    11,269
    15,528
    2019 Prius Prime
    If you go low, you can use an old tin an and avoid a 3D print;).
    Just got my catch can for the Prime last night:
    869CD59D-D9D0-46C5-98D3-72A5E3CF7F0D.jpeg 65666019-0C6C-4C92-8F11-D1E7408D7FF1.jpeg 83341288-FBC4-4017-A121-9795AEA1824F.jpeg
    Good to hear she’s back up and running though (y).
    RMB and Grit like this.
  20. Hsieh2017
    Hsieh2017 Junior Member
    Taiwan
    I have tried this type of compact baffled occ(bronze filter) and it works well.
    It is pretty efficient although little oil remained in the intake manifold.
    I think it removed more than 90% of oil in the intake.
    Recently, I tried the new baffled carbon fiber occ(cyclone type baffle).
    More than twice the price and pretty good looking.
    However, the oil catch performance sucks.
    It removed less than half of oil in the intake.
    I think it suits for turbo charger and high rpm engine since seperation efficienccy is proportional to inlet air speed inside occ.
    As for eco or urban driving style, the seperation efficiency is not worth the price.
    Robert Holt likes this.
