Oil Catch Can, Eliminate that knock!
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by danlatu, May 22, 2017.
  1. Higgins909
    Higgins909 Member
    289
    71
    Does anyone know the specs of the PCV valve and where it connects to? I bought a cheap Ruien 0046 off amazon and need to make sure I have all the proper fittings and hoses. I'm also planing to clean the EGR valve finally and do my oil change at the same time as well as get a new PCV valve.
    Also what type of hose to look for and who sells it? I have a nearby Lowes, Home Depot, Auto Zone, O'Reillies.
  2. Mendel Leisk
    42,331
    Have you read through this thread? Yeah I know, 71 pages...
    Do you mean the PCV valve part number? If you phone the dealership and just tell them what you need, they'll sort it out. If that's not in the cards, go to somewhere like McGeorge Toyota Parts online and search for it. Save you a search:
    PCV Valve - Toyota (12204-37010) | Toyota Parts
    What a lot do is cut the original hose between the valve and intake manifold, around the middle, push in 3/8" brass couplers*, then push 3/8" Inside Diameter fuel line hose onto the couplers, run that to their OCC. The hose I'm using is spec SAE-30R7. I believe if it ends in 6 it's more or less the same. Part number for that OEM hose that gets cut, it's a little obscure:
    12261-37060
    The main reason for cutting the OEM hose, is because it's ID's are a little tricky: it flares out at the intake manifold end. So the simplest route is to cut it and splice in.
    * The brass couplers are either brass barb hose couplers, readily available in any hardware store, or similar PEX couplers. I would say the latter are preferable, because they have much less tenacious couplers, can be pulled off. The barb couplers are like their name, very hard to pull off.
    I couldn't find PEX within walking distance, so have taken to getting barb style and "blunting" the barbs. Chucking them iinto a drill press and using it like a lathe is a simple way to do this: get it spinning, then just knock the sharp edge off the bars with a file.
    While at the hardware store pick up hose clamps. It's pretty close to the smallest size will do, but bring a long a piece of hose to verify. You can get kosher automotive clamps, but with all the couplers being brass, hose clamps are fine.
    A picture of my setup, a while back. I've since put automotive clamps on, but it's overkill:
    You can see the OEM hose cut in half, connected to couplers. Note the flare-out at one end. Also, I use the screw-clamps only on the new connections; continue to use the OEM spring clamps on the original hose ends. Note the screw-clamps can put a point load on the spigot, and if it's plastic might crack it. That's the case at the intake manifold connection.
    #1402 Mendel Leisk, May 17, 2019
    Colton, scona and Raytheeagle like this.
  3. Higgins909
    Higgins909 Member
    289
    71
    I will do exactly that. Though I wonder how people get to the valve and the OEM hose. I've seen people take the intake manifold and more off to get to it, but I've heard you can get to it from under the aero cover.
    I read about 2-3 pages and wasn't seeing the info I was looking for. I knew someone possessed the info I needed, saving me 70+ pages of reading. If I can, I will measure the intake manifold part, with my calipers. Will measure the new and old PCV valve nipple, too.
  4. Mendel Leisk
    42,331
    You probably should take intake manifold off anyway, clean it thoroughly. Watch @NutzAboutBolts video on that. Texting with my left thumb, you'll have to search lol.
    NutzAboutBolts likes this.
  5. Grit
    Grit Senior Member
    6,577
    4,231
    Wilkes Land
    Throughly reading is for old people, the hip and new age is to ask and set a notification when replies are received. Diiiiiiing.
    RMB, mikey_t and StarCaller like this.
  6. cww180
    cww180 Junior Member
    28
    34
    Virginia
    Is anyone printing and selling these, I need both the bracket and line holder.
  7. Colton
    Colton Member
    61
    27
    Raleigh, NC
    You make any more of thise brackets to sell?
  8. Behailu Sheferaw
    Behailu Sheferaw Junior Member
    2015 Prius v wagon
    Hi danlatu,
    How can I get the Oil catch can bracket? Please let me know I need two. Thanks!
  9. danlatu
    danlatu Senior Member
    533
    1,367
    maryland
    I am not making these, I was not 100% happy with how fdm materials hold up to engine temps. The 3d printed material sags with heat or becomes brittle.
    Colton likes this.
  10. schmuber
    schmuber Member
    115
    85
    Georgia
    …by design.
  11. Mendel Leisk
    42,331
    You can cobble: slotted angle, pipe hanger strap, zip tied pop can, whatever.
    James Powers likes this.
  12. mjoo
    mjoo Senior Member
    1,163
    1,334
    Michigan
    Would something like this work?
    Moroso 63401
    BTW, has anyone seen replacement o-rings for the Ruien Can?
    #1412 mjoo, Jul 29, 2019
  13. James Powers
    James Powers Senior Member
    396
    555
    Bay Area
    I bet you could make this work if you can find a place to mount it. Solid clamp for sure.
    Bay Stater and Raytheeagle like this.
  14. Mendel Leisk
    42,331
    Huh, Moroso part. (y)
  15. tvpierce
    tvpierce Senior Member
    951
    883
    Maine
    2013 Prius v wagon
    This would work too. And it's an OEM part! :)
  16. Grit
    Grit Senior Member
    6,577
    4,231
    Wilkes Land
    How is a pictured square box with a red ‘X’ supposed to work with the catch can?
    #1416 Grit, Jul 31, 2019
  17. StarCaller
    StarCaller Senior Member
    1,284
    733
    Cedar Crest, NM, USA
    picture not showing /
  18. Mendel Leisk
    42,331
    Moroso has "kits" for a lot of US domestic cars, basically their universal can plus car specific bracket(s) and complete install instructions. They typically hitch-hike on some existing connection. Hoses layouts are thought out and explained too.
    Unfortunately such a kit does not exist for the Prius, but you can get the universal can, which comes with a ring bracket, and a bent bar piece with holes for connecting to a vertical face. It's up to you to sort it out though, use what you can, figure out a secure mounting location.
  19. tvpierce
    951
    883
    Maine
    2013 Prius v wagon
    The red 'X' has magical powers! ;)
    Here's what should have been linked. (and since it's Toyota Racing Development, it adds 15hp!)
    RMB likes this.
  20. will the engineer
    will the engineer Active Member
    238
    119
    LA
    2019 Prius Prime
