Oil Catch Can, Eliminate that knock!
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by danlatu, May 22, 2017.
  1. capolihu
    capolihu Member
    101
    76
    Mont
    I started to think if I did something wrong, as the dipstick of the OCC shows nothing after 1k mile. So next time I put the new shiny gasket I got to the cooler-exhaust end, I will check the can itself..
  2. Bay Stater
    Bay Stater Senior Member
    534
    771
    Central Mass
    I have posted my OCC bracket solution quite awhile ago on this thread. So here is a refresher. Nearly 40K miles since install, the bracket has held up. (y)
    anon_prius, capolihu, Burna J and 5 others like this.
  3. Mendel Leisk
    42,341
    Those airplane clamps are 1/4" socket size, IIRC. little mini-ratchet, makes removal easy.
  4. Bay Stater
    534
    771
    Central Mass
    No need to tighten, just drop the OCC housing into the bracket.
    Mendel Leisk and Raytheeagle like this.
  5. anon_prius
    anon_prius Junior Member
    32
    I ended up adopting Bay Stater's mount location because it is easier to unscrew for cleaning.
    So glad the job is done and now my hands and lungs (really hit the egr circuit and manifold hard with brake cleaner) can start healing!
    Edit: I should also mention that I used 99% pure sodium percarbonate to clean out the EGR cooler. This is the active ingredient in Oxiclean. Just follow the same steps that you normally would:
    1. Fill the end of the cooler furthest from the long coolant pipe with 2-3 tablespoons of sodium percarbonate
    2. Duct tape over that end
    3. Flip cooler over and use the long coolant pipe to hang it inside a 5 gallon bucket
    4. Pour boiling water into the cooler until it starts bubbling over
    5. Wait a few hours and repeat as necessary
    I also hit it with the high pressure sprayer at the car wash but it didn't work as well as I hoped.
    #1445 anon_prius, Aug 23, 2019
    Bay Stater, mjoo and Mendel Leisk like this.
  6. cww
    cww Junior Member
    23
    2003 Prius
    I was about to order the plastic brackets, thanks for sharing this!
    Bay Stater likes this.
  7. capolihu
    capolihu Member
    101
    76
    Mont
    Bay Stater and Raytheeagle like this.
  8. Mendel Leisk
    42,341
    What is this? Something disassembled and then just "parked" there??
    RMB, Bay Stater and Raytheeagle like this.
  9. Raytheeagle
    Raytheeagle Senior Member
    11,269
    15,528
    Bay Area, California
    2019 Prius Prime
    That’s the first thing I noticed too;).
    Something definitely isn’t right:cool:.
    But it looks cleaner than everything else(y).
    RMB, Bay Stater and Mendel Leisk like this.
  10. capolihu
    capolihu Member
    101
    76
    Mont
    Gotcha! Before I installed it.
    That ist the gasket ordered for the exhaust part of the egr and that is the shiniest one, if not the OCC
  11. capolihu
    capolihu Member
    101
    76
    Mont
    The first measure after about 4k mile, if someone interested. I expected a bit more, but I'm glad it is not under the throttle body :) IMG_20190907_164345.jpeg 20190907_1645512.jpeg
    Montgomery, Bay Stater, scona and 3 others like this.
  12. Mendel Leisk
    42,341
    They tend to accumulate a lot more through winter, maybe double? And it separates: a layer of oil, and a layer (more water-based) that's a lighter cream colour.
    Montreal, Montana, or?
    Bay Stater, Raytheeagle and scona like this.
  13. Raytheeagle
    11,269
    15,528
    2019 Prius Prime
    Montpelier, , Monte Vista, Mont Bleau, etc.:whistle:
    Let the guessing continue(y).
  14. RightOnTime
    RightOnTime Senior Member
    791
    1,660
    183
    Kidnapped in OC, CA
    Here is a pic of the parts for my 3rd stealth OCC install. ‘Out of sight, out of mind’
    iPhone ?
  15. Raytheeagle
    11,269
    15,528
    2019 Prius Prime
    Go low(y).
  16. capolihu
    capolihu Member
    101
    76
    Mont
    Here and there. Utah-Colorado : Mountains
  17. Mendel Leisk
    42,341
    A semi-specific location is helpful to responders. ;)
    CR94 and Grit like this.
  18. capolihu
    capolihu Member
    101
    76
    Mont
    Btw, I read one of the youtube comments that one guy got full OCC after longer 5-600+miles trips. But I'm sort of happy it is not in my case. or was thinking it is too far from the IM so less efficient.? Probably not. I think his/her case was an exception.
  19. Mendel Leisk
    42,341
    I emptied mine spring and fall, in conjunction with twice yearly oil changes, Spring I'll get about 100 cc, fall it's around 50 cc. The spring drain is about 50/50 oil/water, fall mostly oil.
    But, we're only doing about 5000 miles a year, if that.
  20. Colton
    Colton Member
    61
    27
    Raleigh, NC
    Quick question for those who’ve installed..
    I recieved the Ruien catch can from amazon today but am wondering what all I will need to install it. I plan on mounting it by the driver side (USDM) headlight with the bracket I’ll be recieving from hybridpit this Saturday. I tried digging but my search came up unsuccessful. Thanks in advance, cheers!
