Oil Catch Can, Eliminate that knock!
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by danlatu, May 22, 2017.
  1. tri4all
    tri4all Member
    99
    Pacific Northwest
    do you have a picture of the location you chose? or a more specific location. I see a few options but want to get one for easy access probably underneath the car more likely.
    and yes this is for a 2010 prius touring.
    Raytheeagle likes this.
  2. Raytheeagle
    Raytheeagle Senior Member
    11,269
    15,528
    Bay Area, California
    2019 Prius Prime
    pjksr02, Grit and tri4all like this.
  3. scona
    scona Active Member
    225
    207
    Courtenay, BC, Canada
    2013 Prius v wagon
    There are no bad places to place the can, but some may be better than others. In actual fact
    the contents of the line from the PCV valve to the can are not in liquid form but are a vapor.
    So there is little to run back down the line to the valve. And the valve would be closed if the engine was not running so it could not go anywhere anyway.
    My thinking is that I put the can in so I could empty it often, not once every 6 months. So my
    can is up top like many others on the list. Personal choice. The important thing is to have a
    can in the system, certainly. Especially in a gen 3.
  4. Mendel Leisk
    42,331
    Hoses for high mounted oil catch cans will likely sag a bit as they come away (horizontally) from the PCV and the intake manifold. I'd think that's not a bad idea, since the interior of the hose can get oily, and then any oil condensate will collect a bit away from the PCV valve.
    If you had a long run of hose and for some reason the hoses ran relentlessly up hill away from the OCC, then yeah maybe something bad might happen, though not sure what.
    I do think that you need to be cognizant, that you're going from a simple horizontal hose, 6" long at most, to a bit of a plumber's nightmare, a much longer run of hose, with labyrinth filter material. Mainly that besides draining the can it's not a bad idea to completely remove it occasionally and clean it stem-to-stern, especially if you have some sort of brillo pad filter material.
    FWIW, my cans (two, in series) are mounted low, on a bracket attached atop the lower/front cross beam.
    Grit and scona like this.
  5. tri4all
    tri4all Member
    99
    Pacific Northwest
    Just finished installing my oil can. Nice and low and only about a foot or less for each hose. And with the ability to screw it off after removing the air filter compartment. Thanks for the tips. 20200229_195057.jpeg 20200229_195049.jpeg 20200229_195015.jpeg
    pjksr02 likes this.
  6. tri4all
    tri4all Member
    99
    Pacific Northwest
    Why two in series? How often and how much do you get on the second can?
    Grit likes this.
  7. Grit
    Grit Senior Member
    6,577
    4,231
    Wilkes Land
    Try mounting the can in plain view in CA and get a smog check / state inspection :LOL:
  8. Raytheeagle
    11,269
    15,528
    2019 Prius Prime
    Rebound and Grit like this.
  9. Grit
    Grit Senior Member
    6,577
    4,231
    Wilkes Land
    There's a saying "Go big, or go home." Mendel never goes home.
  10. Mendel Leisk
    42,331
    For one thing, because I had two (picture me drumming my fingers, looking at the yet unused second one).
    Long story why I had two, but thought might as well. I suspect (from a testing/comparison video I watched) that my can is maybe 70% efficient?
    So if 100 cc of oil/water is passing through, it would catch 70 cc. And maybe a second one in series, would scavenge an additional 21 cc (70% of 30 cc).
    That's so far just a theory, I've only just installed the second can, a month or two back. About mid-April I'll do an oil change and see what they've collected.
  11. tvpierce
    tvpierce Senior Member
    951
    883
    Maine
    2013 Prius v wagon
    Belt and suspenders! :)
  12. scona
    scona Active Member
    225
    207
    2013 Prius v wagon
    Regrettably, until we find a method to filter the EGR system, the catch can or multiples thereof offer the only possible protection to engine self-pollution.
  13. SFO
    SFO Senior Member
    5,302
    4,251
    Northern California
    Two cans, one prius o_O
  14. ASRDogman
    ASRDogman Senior Member
    8,058
    4,085
    I would prefer 2 Prius and 1 OCC! :)
  15. Mendel Leisk
    42,331
    #1775 Mendel Leisk, Mar 1, 2020
    RMB likes this.
  16. mjoo
    mjoo Senior Member
    1,163
    1,334
    Michigan
    Nice Setup, Mendel. Out of curiosity, how many clips do you remove to access them?
    Pixel XL ?
  17. Mendel Leisk
    42,331
    I pull the engine underpanel off every 6 months for an oil change, drain the OCC at same time. There's 6 bolts (#2), 11 regular plastic fasteners (#3), and 2 larger ones at the rear (#5). It takes about 5 extra minutes, either removing or reinstalling. The 2 plastic-to-plastic fasteners (#4) just hold the hinged part in place, I don't need to touch those.
    SFO likes this.
  18. tri4all
    tri4all Member
    99
    Pacific Northwest
    I'll be waiting to hear back when you check the second can... I am sure your theory will play out in practice, especially after 6 months of driving.
  19. tri4all
    tri4all Member
    99
    Pacific Northwest
    sorry not the best pictures. I basically installed it on the motor mount, just underneath the PCV valve. there was already a hole for the OC to be securely mounted with a bolt.
  20. tri4all
    tri4all Member
    99
    Pacific Northwest
    so does the newer prius come with an oil can already? or is this still a problem? or has the technology advanced that oil can is no longer needed?
    #1780 tri4all, Mar 2, 2020
