Oil Catch Can in prius 2010
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Tariq87, Apr 26, 2018.
  1. Tariq87
    Tariq87 Member
    87
    28
    jordan
    Hii all ..please any one has a video or PDF how to change oil catch can in prius 2010 ?
  2. tankyuong
    tankyuong Senior Member
    1,555
    662
    Central MO
    do a search here there are pics and instructions
  3. Mendel Leisk
    42,347
    This is the main thread:
    Oil Catch Can, Eliminate that knock! | PriusChat
    To clarify: there isn't an Oil Catch Can on the car from the factory, it's an aftermarket install, basically spliced in along the hose between the Positive Crankcase Ventilation valve (kinda buried, under intake manifold), and a spigot on the intake manifold, just downstream of the throttle body.
    It's a good idea to do OCC install in conjunction with intake manifold cleaning; that hose from the PCV valve to intake manifold is pretty much the main source of oil/gunk fouling in the intake manifold. So, clean the manifold, then install OCC.
    Watch @NutzAboutBolts video on intake manifold cleaning here:
    Nutz About Bolts Prius Maintenance Videos | PriusChat
    He hasn't done one on OCC install, yet...
    #3 Mendel Leisk, Apr 26, 2018
    DogDaze, sumguy, j12piprius and 4 others like this.
  4. NutzAboutBolts
    NutzAboutBolts Senior Member
    1,756
    1,789
    Bay Area
    Will make one once I have the bracket made lol
    Michael Mann, qettyz, Tariq87 and 3 others like this.
  5. Seymour1
    Seymour1 Member
    272
    36
    I think that I read that the banging is caused by a buildup of oil in the intake manifold and is sucked into the engine. Liquids will not compress. Does the OCC prevent the oil from getting to the IM and thus prevents the banging? And, how does the redesigned IM prevent buildup of oil?
  6. Mendel Leisk
    42,347
    More likely water or water/coolant, long story.
    As far as I know, it doesn’t. It’s reputably to provide more equitable allocation of exhaust gas to the cylinders, and perhaps not very effective at that either
    I empty my oil catch cans (two Moroso 85474’s in series) in conjunction with oil changes, and having gone to once-a-year changes (roughly 4000~5000 kms), so this is a full year’s catch. First can is on the left, is mostly an oil/water purée, with layer of mainly water at the bottom. Second can is pretty much the inverse, thin layer of oil at top, the rest water.
    each is about 60 cc’s:
    #6 Mendel Leisk, Apr 12, 2024
