Oil Change 2010 Prius - do it yourself
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Mr. Bill, Aug 22, 2009.
  1. Mr. Bill
    Mr. Bill Generation III
    86
    222
    Dunedin Florida
    Mobile 1
  2. Mr. Bill
    86
    222
    Dunedin Florida
    Ed - I agree with the jack points and using ramps.
    Mr. Bill
  3. Mr. Bill
    86
    222
    Dunedin Florida
  4. rrolff
    rrolff Prius Surgeon
    1,610
    246
    So Cal
    I understand at some point, people do their own oil changes... I did them for years. But now, you can get coupons for $10 changes. Bring in your own oil/filter (and you get to watch), and I'm not sure why anyone at that price would do it on their own (including disposal)..............
    My guy swaps it in 15 minutes, and charges $10 cash (YMMV)...
  5. esoniat
    esoniat Junior Member
    79
    Marietta
    I'm glad you brought that up, my mechanic added an oil change bay and I should go see if he has it up and running. But unless you have a place that lets you bring in your own synthetic it can be a huge savings to do it your self.
  6. aridon99
    aridon99 New Member
    67
    San Mateo, CA
    My cousin went to the local 10 min oil change shop and they let him drive away with no oil or drain plug installed. He got down the street and the engine gave out. It took quite a fight with lawyers to get the car running again.
    I like my Prius and love doing the oil change myself :D
  7. eric1234
    eric1234 Active Member
    392
    201
    Hamden, CT
    So, I don't want to start any flame wars - but gotta just ask - didn't he think it odd that all the while he was driving with that little red oil light illuminated?? (Yes, I'm assuming his car had one - most *usually* do...)
  8. tomlouie
    tomlouie Member
    118
    Boston, MA, USA
    2023 Prius
    If the drain plug wasn't installed, wouldn't there be a 3+ qt puddle of oil on the floor
  9. Skoorbmax
    Skoorbmax Senior Member
    2,641
    265
    Western NY
    Not if they failed to add the oil like :)
    Changed oil again yesterday. Again had to break one of the stupid plastic clips to get the flap off, leaving me with just one. I have used plastic zip ties in place of the last two. I'll just cut them off next time instead of playing around, far less painful than before so I'm happy with that!
    Irritatingly the oil filter on this is so tight to part of the car, and requires hard screwing anyway on count of the o-ring on the filter, that I can only suitably tighten it with the wrench. In all other cars i've worked in the past I loosen with the wrench but hand tighten. Oh well :(
    Anyway, oil was 9600 miles old and was not black. I know that even oil in good shape can quickly go black but this stuff really didn't seem old based on visual inspection!
  10. offroader
    offroader Junior Member
    44
    Thanks for this great post!
  11. txl146
    txl146 Member
    301
    NY
    Roughly how much does dealer charge for an oil change? Sorry, I do not have Prius yet, but I've been doing oil change on our cars for years.
  12. dustoff003
    1,371
    335
    Waianae, HI (Oahu)
    Inquire about Toyota Care it should be 2 years or 20k miles routine maintenance.
  13. Dark_matter_doesn't
    Dark_matter_doesn't Prius Tinkerer
    692
    151
    Seattle, WA
    If you've done your own oil changes, you can do it on your new Prius. Look thru this thread and you'll learn. The only tool you should need is the correct tool for removing the oil filter cover (assuming you've got a jack, jack stands and some wrenches!) That way, you'll know the job is done right.
    Good Luck!
  14. jayman
    jayman Senior Member
    13,439
    641
    Winnipeg Manitoba
    Around here is in the mid $50 range due to mandatory use of synthetic 0W-20
    Not sure how well the transition to bulk 0W-20 oil will go. The way most dealerships ignore dust and moisture ingestion of their bulk oil tanks would make me question the quality of the oil
  15. Biffer
    Biffer New Member
    Belgium
    So the people that didn't do the early oil change can have a little peace of mind. Thank you web1b for the information.
  16. txl146
    txl146 Member
    301
    NY
    Sounds like a lot of folks are changing OEM oil to M1 at around 1000 mark. Since dealer offers free oil change at 10k and 20k, you guys don't mind oil being changed from OEM to M1 to OEM?
  17. tumbleweed
    tumbleweed Senior Member
    4,067
    692
    Eastern Oregon
    The local dealer here charges about $20 for an oil change only. They supply a Toyota filter and you bring your own oil. I still do my own because then I know it is done right.
  18. Mendel Leisk
    42,343
    Our dealership offers both Toyota and Mobil. Personally I'm not that excited about Mobil, with the Toyota oil at half the price. I doubt there's much difference from the perspective of engine longevity.
    FWIW, I've also gone the DIY route, though I know it's not practical for everyone, and some prefer the security of the dealership route.
  19. Mr. Bill
    86
    222
    Dunedin Florida
  20. samsprius1
    samsprius1 Active Member
    720
    182
    2023 Prius
    Limited AWD-e
    Had the dealer do my oil change the first time and that was the last, Took a hour and a half!
    Do it myself and save $$ and time, toyota filter and mobil1.
