Oil Change By Evacuation Instead of Drain Plug
Discussion in 'Gen 4 Prius Care, Maintenance and Troubleshooting' started by padroo, Jan 27, 2018.
  1. padroo
    padroo Senior Member
    2,763
    2,253
    I bought one for my 2008 Prius and never installed it. It looks like a good idea but I was worried about it getting sheared off and then loosing oil. We have a lot of ice clunkers on the road here in the winter, sometimes you can't go around them.
    RCO likes this.
  2. Mendel Leisk
    42,383
    Does it slow the drain? I've never had a problem with drain bolt, fwiw.
  3. Adam1a
    Adam1a Member
    50
    59
    Three Touring
    With the cover that you have to remove in order to get to the drain plug, it provides enough protection for me plus the drain is on the back side of the oil pan so the pan would take any hit first before it would hit the drain valve. Fumoto makes a short, medium and long drain valve so the model that I listed is the short one as it is about an inch long.
    As long as the oil is hot, it will flow out about the same rate as the plug. I did file a v-notch on the inside bottom of the drain valve to help get every last drop that I could but really is not needed.
    RCO and Mendel Leisk like this.
  4. padroo
    2,763
    2,253
    I'm sorry I was referring to my 2008 Gen 2 where the drain plug was completely exposed unlike the Gen 4.
    It would be ideal for a Gen 4.
  5. farmecologist
    farmecologist Senior Member
    1,960
    1,801
    Southern MN
    I almost used a Fumoto in our Hyundai vehicles but 'thought better of it' ( i.e. - overthought it ). I think some of us are somewhat paranoid and think something might happen to it..even though nothing ever will. :whistle:
    RCO, Raytheeagle and padroo like this.
  6. douglasjre
    douglasjre Senior Member
    2,250
    751
    Null, NL
    In a word: Why
